triumph tiger cub,electrics.
knitinglee
PostPosted: 19:28 - 13 Apr 2014    Post subject: triumph tiger cub,electrics. Reply with quote
Hi to you all,
I`m a forum virgin,and I need help,I have a 1960 triumph tiger cub,I`ve rebuilt it from the ground up,everything was going well until it came to the electrics,its 6 volt,positive earth,with a combined ignition/lighting switch,when I turn on the lights to the first position,I get parking lights front and rear,if I go to position two,I get front dip and main beam,but no rear light,if I turn on the ignition the main power feed from the battery starts melting also the rectifier gets really hot,I know I`ve done something stupid but I can`t find out what,all the wires are following the wiring diagram,I`ve checked and checked,but I cant find out whats wrong,any help would be great,thanks mandy.
WD Forte
PostPosted: 20:42 - 13 Apr 2014    Post subject: Reply with quote
Mandy, the Tiger cub has pretty basic electrics but
without offering up some pics and diagrams
you're not giving many clues and considering the age/rarity of the bike thats a big ask.
I had a cub many years ago and cant remember much about the wiring
other than that combo switch is the 'brain' of the system
in that just about everything goes through and is controlled, by that switch.
Any wiring errors here can bugger things right up
I'm looking at a '64 Tiger Cub wiring diagram now but without knowing what you've done cant really make an informed guess.
Dont connect the battery until everything has been properly
checked, not just given a visual once over.
I'd map/label the switch functions whilst checking it against the diagram then selectively connect and test as I went.
Its got something like 20 terminals so easy to make a mistake
if you dont follow a systematic fit/test procedure.
Also I there's more then one model of Cub with variations in the wiring between T20, T20C, T20S and the T20T
You (and others) need to know what you're working on.
bikers smell of wee
Islander
PostPosted: 20:43 - 13 Apr 2014    Post subject: Reply with quote
First thing to do is check the rectifier wiring. It sounds like you've miswired it and it's passing a massive current when the ignition is switched on.
The rear light should be easy enough to sort out - it's just not getting a feed. A few minutes with a meter should tell you what's going on there.
Triton Thrasher
PostPosted: 21:25 - 13 Apr 2014    Post subject: Reply with quote
Wire it according to a late 1960s Triumph (or any Brit bike) 12V system, using a Zener diode or a solid state regulator.
The 6V layout is complicated and ineffective and you are baffled by it.
Rrrrrrrrrrrrrrrrrr
WD Forte
PostPosted: 23:39 - 13 Apr 2014    Post subject: Reply with quote
I'd convert it to 12v too but some classic folk get all fussy about
stuff being original as if it lends some obscure quality to it.
Well I remember these bikes before they were 'classics'
and the 6v electrics were shite!
If it was mine I'd rip it all out and fit modern electricules
With some canny work you could keep it looking original
but have an up to date/better/reliable electrical system.
bikers smell of wee
knitinglee
PostPosted: 16:15 - 14 Apr 2014    Post subject: Reply with quote
Hi again to you all,
Many thanks for your help,after posting my thanks,I will venture into the garage and armed with your advice,I will triumph,good pun there,thanks again,mandy.
Lone-Wolf
PostPosted: 16:23 - 14 Apr 2014    Post subject: Reply with quote
Wotcha.
That just about sums it up.
All my alternator equipped bikes ( five of 'em ) have been re-wired for 12 volts.
A regulator / rectifier is cheaper than a Zener diode and heat sink.
This is how all mine are wired . . . . . .
https://www.moonshiners.org.uk/showme/wiring%20-%20issue%20003.jpg
Cheers.
L.W. - www.moonshiners.org.uk
knitinglee
PostPosted: 09:10 - 21 Apr 2014    Post subject: triumph tiger cub electrics,again, Reply with quote
After spending four days locked away in my garage,I must admit defeat,and once again throw myself on your mercy,1960 tiger cub,200cc,frame and engine number T20, 67561,I have three wires coming from the alternator,dark green,mid green,light green,the wiring was complete up to the combined ignition/lights switch,the only thing I have done is to wire the combined switch up to a wiring diagram from the haynes tiger cub book,it shows external links,from 12=10,on the combined switch,everything is good power to lights,but no power to ignition,but once I bridge 2=12,the rectifier gets hot,the power cable gets hot,no 1 =pilot light,No2 from battery,links to no12,no 3 =dip switch,no7 alt,no8 tail light,10 linked to 12,12=horn=2=10,13=rectifier,14 coil sw,15coil cb,16 alternator,any help or mystic spell to the prince of darkness ,would be great,thanks people from Mandy.[/img]
WD Forte
PostPosted: 14:17 - 21 Apr 2014    Post subject: Reply with quote
Edit:
prev post deleted may not be that useful
found another diagram, hopefully accurate
and according to that
Wiring routes from alternator/generator
Dark green:
to rectifier terminal 1 and switch terminal 7
Light green:
to rectifier terminal 3 and switch terminal 4
(Rectifer 2 goes to switch terminal 13)
mid green:
to switch number 16
EDit again
While I'm looking at it
here's the multi switch connections according to the diagram I have
No. - To - colour
1 - pilot light - red?
2 - battery - - brown
3 - dip switch - blue
4 - rectifier - light green
5 - NC
6 - NC
7 - Rectifier - dark green
8 - Tail Lamp - Maroon
9 - ? can t see any connection
10 - NC
11 - Speedo light -Maroon
12 - NC
13 - rectifier - Buff
14 - coil sw - White
15 - coil cb - black
16 - rectifier - mid green
17 - NC
18 - NC
19 - NC
bikers smell of wee
knitinglee
PostPosted: 17:31 - 26 Apr 2014    Post subject: Reply with quote
Thanks for all your help everyone,especially WD forte,
I`ve tested the alternator,rectifier,wiring,combined ignition/light switch,each checks out on its own,put it all together,exactly the same,rectifier immediately gets very hot,I`ve used the wiring diagram from the haynes manual,this diagram checks out,with my wiring,but I will try out the diagram from WD forte,will let you know when I find out what the fault is,thanks again mandy.
Lone-Wolf
PostPosted: 20:28 - 26 Apr 2014    Post subject: Reply with quote
Wotcha.
This is why I *ALWAYS* change to 12 volt.
More helpful info HERE
Cheers.
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 70.85 Kb
