| Mark65 |
 Mark65 World Chat Champion
 Posted: 20:17 - 16 Apr 2014 Post subject: CG Cush Rubber Removal |
What a crazy design, how the hell do you get them out???
Surely they must have known how tight they would be?.
Stinkwheel,Teffers, Anyone I need your knowledge please.
Thanks
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| Commuter_Tim |
 Commuter_Tim World Chat Champion
 Posted: 20:51 - 16 Apr 2014 Post subject: |
Use a HACKSAW  ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
| moonzoomer |
 moonzoomer World Chat Champion
| Commuter_Tim |
 Posted: 21:44 - 16 Apr 2014 Post subject: |
In all seriousness though man, I'm sure I read in another thread your buying more? large pliers and MTFU.
I monkey around and break stuff by accident on my bike all the time, but that's my point, if you're throwing them, who cares how they come out? ____________________ The above post is most likely nonsensical.
| johnsmith222 |
 johnsmith222 World Chat Champion
 Posted: 22:06 - 16 Apr 2014 Post subject: |
| SnowTigeress |
 SnowTigeress Brolly Dolly
 Posted: 22:30 - 16 Apr 2014 Post subject: Re: CG Cush Rubber Removal |
| Mark65 wrote: | What a crazy design, how the hell do you get them out???
Thanks
Mark |
Oh what fun these were to get out.
Attack rubber with a drill to get the inner sleeve out,then to get the outer Sleeve out, cut through the sleeve in 3 places with small triangle file or hacksaw blade snapped in half so you have teeth all the way to the end,and can cut through the bottom,where hole ends,use chisel or an old screw driver to lever out sections ____________________ Real bikers build their own Renovated and Riding a 1986 Honda CB125TD-C called the Pup. Full Licence 13/09/2012, 1994 Moto Guzzi 750 Strada
Can-Do Girl that does spanners TOO!
TheSmiler: binning it is better than going around a roundabout the wrong way |
| Pete. |
 Pete. Super Spammer
 Posted: 10:59 - 17 Apr 2014 Post subject: |
If the rubbers are largely intact with no gaps you could fill the holes with a heavy grease, or candle wax and hammer a close fitting pin or bolt into the hole. The bush will be pressed out by hydraulic action. If te rubbers are holed his won't work and you'll have to resort to snowtigress' method above. You could possibly grind a heavy screwdriver the wrong way to make a sharp tapered tool that you might be able to use to fold in the outer shell of the bush, depending on how strong it is. ____________________ a.k.a 'Geri'
| Mark65 |
| sickpup |
 sickpup Old Timer
| Pete. |
 Pete. Super Spammer
| Mark65 |
| kestrel |
 kestrel Nearly there...
| Mark65 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:03 - 20 Apr 2014 Post subject: |
Crikey, that does look nice.
I wonder how many CBF125s will still look that good at that age.  ____________________ Biking is 1/20th as dangerous as horse riding.
| Pete. |
 Pete. Super Spammer
 Posted: 14:43 - 20 Apr 2014 Post subject: |
Chain looks too tight there Mark. ____________________ a.k.a 'Geri'
| TheSmiler |
 TheSmiler World Chat Champion
 Posted: 15:03 - 20 Apr 2014 Post subject: |
Nice that you got them out, when I replaced my sprocket set I ended up taking it to a local biker. All he did was use a drift and a hammer to knock them out. ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
A2 completed 23/07/15 Ready for the Golden Crisp Packet |
| Ariel Badger |
 Ariel Badger Super Spammer
| Mark65 |
 Posted: 18:26 - 20 Apr 2014 Post subject: |
The Smiler, I don't now how unless earlier ones could be accessed from the rear, the disk version cannot be accessed from behind to drift out.
Ariel, it has a few scratches and marks here and there but mechanically its bang on and well looked after, Ive done 7k since I got it last March, drive train is nice and smooth now with no clicking of sprocket.
Pete, lol, 25mm at tightest point
Roger, not to many i would guess.
The last post was made 12 years, 214 days ago. Instead of replying here, would creating a new thread be more useful? |
