CG Cush Rubber Removal
Mark65
PostPosted: 20:17 - 16 Apr 2014    Post subject: CG Cush Rubber Removal Reply with quote
What a crazy design, how the hell do you get them out??? Shocked
Surely they must have known how tight they would be?.
Stinkwheel,Teffers, Anyone I need your knowledge please.
Thanks
Mark
Commuter_Tim
PostPosted: 20:51 - 16 Apr 2014    Post subject: Reply with quote
Use a HACKSAW Razz
I ride a Bandit 600... badly.
moonzoomer
PostPosted: 21:05 - 16 Apr 2014    Post subject: Reply with quote
Petrol and a match.
Commuter_Tim
PostPosted: 21:44 - 16 Apr 2014    Post subject: Reply with quote
In all seriousness though man, I'm sure I read in another thread your buying more? large pliers and MTFU. Smile
I monkey around and break stuff by accident on my bike all the time, but that's my point, if you're throwing them, who cares how they come out?
johnsmith222
PostPosted: 22:06 - 16 Apr 2014    Post subject: Reply with quote
I tend to think this, when users are singled out for advice.
https://3.bp.blogspot.com/-NobktKjV95g/Uyz407i0nvI/AAAAAAAAFa4/MZeVzUxxf04/s1600/we%2527re+not+worthy.png
SnowTigeress
PostPosted: 22:30 - 16 Apr 2014    Post subject: Re: CG Cush Rubber Removal Reply with quote
Thanks
Mark
Oh what fun these were to get out.
Attack rubber with a drill to get the inner sleeve out,then to get the outer Sleeve out, cut through the sleeve in 3 places with small triangle file or hacksaw blade snapped in half so you have teeth all the way to the end,and can cut through the bottom,where hole ends,use chisel or an old screw driver to lever out sections
Real bikers build their own Renovated and Riding a 1986 Honda CB125TD-C called the Pup. Full Licence
13/09/2012, 1994 Moto Guzzi 750 Strada
Can-Do Girl that does spanners TOO!
TheSmiler: binning it is better than going around a roundabout the wrong way
Pete.
PostPosted: 10:59 - 17 Apr 2014    Post subject: Reply with quote
If the rubbers are largely intact with no gaps you could fill the holes with a heavy grease, or candle wax and hammer a close fitting pin or bolt into the hole. The bush will be pressed out by hydraulic action. If te rubbers are holed his won't work and you'll have to resort to snowtigress' method above. You could possibly grind a heavy screwdriver the wrong way to make a sharp tapered tool that you might be able to use to fold in the outer shell of the bush, depending on how strong it is.
a.k.a 'Geri'
Mark65
PostPosted: 11:51 - 17 Apr 2014    Post subject: Reply with quote
Thanks, I got two out so far by ruining a good medium screwdriver and sharpening the flat while rounding the back.
I removed the center then worked the edge away.
Mark
sickpup
Old Timer
PostPosted: 14:02 - 17 Apr 2014    Post subject: Reply with quote
Reattach sprocket, hit sprocket.
Pete.
PostPosted: 14:15 - 17 Apr 2014    Post subject: Reply with quote
Mark
I kinda meant cutting across the flat at an angle to create a thin wedge. There are many ways to tackle it depending on your tools available and level of mechanical acumen.
a.k.a 'Geri'
Mark65
PostPosted: 19:25 - 18 Apr 2014    Post subject: Reply with quote
The bastards are out, my god, I'm surprised at the Japanese on that design, still lets hope they go back in ok.
kestrel
PostPosted: 22:06 - 18 Apr 2014    Post subject: Reply with quote
The easiest way to remove these is to use a blind bearing puller and a little heat in the hub.
Isle of Man.........Road Racing Capital Of The World
Mark65
PostPosted: 11:06 - 20 Apr 2014    Post subject: Reply with quote
All done and now with Oxford bag on seat to carry my stuff, stops me getting a sore back. Not bad for 18k and 7 years old.
PostPosted: 14:03 - 20 Apr 2014    Post subject: Reply with quote
Crikey, that does look nice. Thumbs Up
I wonder how many CBF125s will still look that good at that age. Thinking
Pete.
PostPosted: 14:43 - 20 Apr 2014    Post subject: Reply with quote
Chain looks too tight there Mark.
a.k.a 'Geri'
TheSmiler
PostPosted: 15:03 - 20 Apr 2014    Post subject: Reply with quote
Nice that you got them out, when I replaced my sprocket set I ended up taking it to a local biker. All he did was use a drift and a hammer to knock them out.
Ariel Badger
PostPosted: 15:39 - 20 Apr 2014    Post subject: Reply with quote
That is in very nice condition, looks new.
Mark65
PostPosted: 18:26 - 20 Apr 2014    Post subject: Reply with quote
The Smiler, I don't now how unless earlier ones could be accessed from the rear, the disk version cannot be accessed from behind to drift out.
Ariel, it has a few scratches and marks here and there but mechanically its bang on and well looked after, Ive done 7k since I got it last March, drive train is nice and smooth now with no clicking of sprocket.
Pete, lol, 25mm at tightest point
Roger, not to many i would guess.
Mark
The last post was made 12 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 96.72 Kb
