mechanical advice
graysam1
PostPosted: 11:47 - 19 Apr 2014    Post subject: mechanical advice Reply with quote
Hi, I have a yamaha aerox yq100 100cc, it ran like a dream until someone tried to steal it and jabbed a screwdriver in the ignition.
I replaced the ignition and couldnt get it to start, took it to a mechanic who said it was the CDI unit, had new one fitted and still couldnt get it to start, he said it was the variator, new one fitted and still wouldnt start.
Took it to 2nd mechanic who said it was the generator stater plate, new one fitted and still wouldnt start, said it was the starter relay, new one fitted and it still wouldnt start.
Its had new rectifier & regulator, resistor, leads, spark plug, clutch, flasher relay, lever and switches - all genuine yamaha new parts. the mechanic said its sparking but not holding it.
Its my pride and joy, I am now depressed, angry and broke
Any suggestions on what it could be will be appreciated
sj etheridge
berzerker
PostPosted: 13:51 - 19 Apr 2014    Post subject: Reply with quote
Does it have an immobiliser?
Has the wiring been damaged when the ignition was messed with?
Why on earth did your mechanic change the variator? Sad
DrSnoosnoo
PostPosted: 14:53 - 19 Apr 2014    Post subject: Reply with quote
Don't pay the mechanic for saying he'd fix it but then not fix it.
c_dug
PostPosted: 14:56 - 19 Apr 2014    Post subject: Reply with quote
Sounds like you've been a bit shafted if you've paid for all those bits and pieces!
Can you work a screwdriver? Can you afford a multimeter?
If the answer to those two questions is yes then you can probably diagnose and fix the issue yourself with a little help.
c_dug
PostPosted: 14:57 - 19 Apr 2014    Post subject: Reply with quote
Also more info needed on the not starting, does it do anything? Any lights on the dash? Does it crank over but not fire up? Fire up but dies?
More info.
WD Forte
PostPosted: 15:04 - 19 Apr 2014    Post subject: Reply with quote
Huh?
Not a scooter expert but played with and fixed a few
whats puzzling me is
How the hell can a bad variator prevent the thing starting?
the variator is the pulley thing right?
what the hell is that got do with ignition and starting?
sounds fishy to me
just guessing of course but as it was an attempted nick
and theivin bastards often fiddle with wires
a lot of ignition switches have a wire to the cdi to allow
and stop the motor
I'd be checking this first
Also CDIs are usually easy to test, did any of these guys actually test
it or just swap and hope?
Sounds like you need a good (proper) mechanic
bikers smell of wee
graysam1
PostPosted: 15:15 - 19 Apr 2014    Post subject: Reply with quote
Fortunately the mechanics havent charged me because they havent fixed it and I havent purchased any parts from the mechanics I like to buy genuine from yamaha dealers. the wires were damaged, but have been replaced and checked twice. Its also had a new battery. It doesnt have an immobliser on. Its turning over just not catching. The mechanic said the spark is there
sj etheridge
WD Forte
PostPosted: 15:17 - 19 Apr 2014    Post subject: Reply with quote
cant find the 100 diagram but the aerox 50 has a black/white wire
from the ignition switch to the CDI
Hoping/assuming Yamaha use the same colour conventions
this is the stop wire and often held high ( open circuit)
to allow the motor to run
an earthed grounded to stop it
Check this cable with meter
Also, I'm assuming again
when you say 'wont start' I assume you mean its spins over but doesnt fire up?
or do you mean it wont spin over?
thats a very different fault.
bikers smell of wee
graysam1
PostPosted: 15:43 - 19 Apr 2014    Post subject: Reply with quote
It does turn over just wont fire up, the mechanics have both said they have checked the wiring, the light are working
sj etheridge
Bunny Lingus
PostPosted: 06:06 - 21 Apr 2014    Post subject: Reply with quote
Connect the black wire to the red wire at the ignition. If it still doesn't start you might have an immobiliser somewhere else on the bike. A mate had a Speedfight two with an identical prob. We never found the immobiliser until we stripped most of the plastic off. Some scooters have a red key (his did), which somehow resets the immobiliser. If you still can't boot it up try connecting all the ignition wires & removing one at a time. You sure you got juice in it? Is there an engine kill switch? Check that isn't corroded.
Bunny Lingus & The Flipside Faggots
graysam1
PostPosted: 14:27 - 21 Apr 2014    Post subject: Reply with quote
Thanks will give that a go and let you know how I get on.
Had an auto electrician come and test all the wiring he said everything was ok but he didnt know why it wasnt working
sj etheridge
smegballs
PostPosted: 14:33 - 21 Apr 2014    Post subject: Reply with quote
Okay first off.
Here's the service manual for your bike.
https://zsebog.com/wp-content/uploads/yamaha-yq100-2000-en.pdf
So now you have access to the wiring diagrams at least. I'll take a quick look and see what kind of ignition system you have.
Ignition wiring diagram is on page 194. From the looks of things, its a self-generating cdi system, as I'd expect on small bikes like this. Just follow the diagnosis chart that is after the ignition wiring diagram. Get yourself a multimeter too. You can get one for a tenner or so, which will do all the auto-electrical jobs. Continuity buzzer is very useful, so I recommend making sure it has that feature.
https://www.rapidonline.com/Test-Measurement/Rapid-318A-Digital-Multimeter-519309
This is my one, I'm well pleased with it. Does all my auto-electrics as well as my electronics hobby projects.
evoboy
PostPosted: 14:38 - 21 Apr 2014    Post subject: Reply with quote
If its got spark then it should start.
Is it getting fuel?
If you buy bits from a Yamaha dealer then no wonder your skint.
APT Motorcycles
PostPosted: 14:54 - 21 Apr 2014    Post subject: Reply with quote
DON'T do this. You'll be pouring 12V into a wire that is supposed to be connected to ground.
smegballs
PostPosted: 16:01 - 21 Apr 2014    Post subject: Reply with quote
https://i.imgur.com/Zv1ULJr.png
Okay OP, I've highlighted the ignition system in red.
If it ran fine until someone tried to do the ignition barrel, my guess is that that BW wire isn't being grounded properly/intermittently connection.
As you can see its a very simple system with not a lot of connections. The key just earth a cdi wire to start/stop the sparks.
It's a shame you have bought loads of parts that are totally unneeded for the ignition system like R/R, flasher relay etc.
This is what I would do if I was working on it.
1. Get a length of wire and make a direct ground for the BW wire on the cdi, to rule out a dodgy ignition barrel. If everything was a go
2. Check resistances of HT coil, as per manual I linked.
3. Check CDI source coil. One of these will the (BR) Black and Red wire going into the CDI. I don't know model specific whether it is referenced to ground or not, so I'd first check between ground and BR: you should see about 200-300V AC with the engine spinning over. You may have to test between BR and GW (green and white) though, should see the same voltage. Test against BR and ground first though.
That should give you a good indication of what is going on.
WR and WL will be the cdi pick-up coil wires, testing between these and spinning the engine will give a low pulse of AC. This is a pulse and not a constant generator (like the cdi source coil) though so you probably won't pick it up on a multimeter, you'd see it on an oscilloscope though.
The last post was made 12 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 90.39 Kb
