Yamaha R6 Not Starting Issues with Video
ian505050
PostPosted: 08:19 - 21 Apr 2014    Post subject: Yamaha R6 Not Starting Issues with Video Reply with quote
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%203/DSC09833_zps0764d334.jpg
Basically I have had my 2006 Yamaha R6 5SL for a few years problem free and i did not use it for 4 months over winter.
It has a DataAlarm fitted which killed the battery fitted so i bought a new battery and fitted and the bike worked fine the first 2 times i used the bike this year.
I then left the bike for 2 weeks and went to start the bike again and it did not start but the battery sounded like it had plenty of power. I have uploaded a video to you tube to show the issue.
https://www.youtube.com/watch?v=ucK6O4jt8m0&feature=youtu.be
I have checked the following so far:-
1. Battery reads 13.1 V and seems fine. I removed it and charged it anyway and put it back in the bike which had no effect. I have another brand new battery that i will be putting in the bike today to see if it starts but my thoughts at this moment in time are that its not a battery issue.
2. I removed all the Ignition Coil Spark Plug Caps cleaned them and removed all the spark plugs and cleaned them as well. I rubbed a bit of sand paper on the spark plug connections and replaced them. I also checked the gaps and checked the spark plugs for damage, none was found. The spark plugs were wet with petrol so i dont think its a fuel issue.
3. I checked the 2 x main 40 amp fuses under the seat with a multimeter and they both are fine.
4. I checked the side stand switch
5. I checked the kill switch
6. I checked i have fuel and i have about 7 litres of fresh fuel in the tank. I used the previous 10 litres of fuel that were from the same source on the last ride, so its not bad fuel.
Can anyone point me in the right direction of what i should be checking next? I need to find the main fuse box and i could really also do with a workshop manual for the bike but cant seem to find on that i can download.
PostPosted: 08:24 - 21 Apr 2014    Post subject: Reply with quote
That sounds remarkably fast, like my 24v setup...
Iain said possibly sprag clutch? I say its definitely not engaging. A bump start will work first time in 2nd gear.
Definitely sounds far too fast so not engaging.
Aff
Does the pump prime when you turn on the ignition?
Take the plugs out and see if they are sparking.
Electric Bike Project
ian505050
PostPosted: 08:31 - 21 Apr 2014    Post subject: Reply with quote
I tried bump starting this bike in 2nd gear in the past and i only managed to lock up the rear tyre.
It does sound a little fast when its trying to start but i think its always sounded like that. Its just not firing up. I put my hand over the exhaust and occasionally it has a little pressure as if its trying to start slightly. The exhaust also stinks of fuel.
ian505050
PostPosted: 08:32 - 21 Apr 2014    Post subject: Reply with quote
The fuel pump primes when starting and you can here the fuel flowing fine.
I will check the spark plugs are sparking next.
ian505050
PostPosted: 08:35 - 21 Apr 2014    Post subject: Reply with quote
The new battery was only £20!!! so it may be a bit shit. Its the same part number as the old one and reads the correct voltage but maybe its the ampage that is an issue?
I have a brand new motobat battery that i can test on the bike today to see if its my cheap battery thats causing the issue
I have found some other videos which seem to be the same issue
https://www.youtube.com/watch?v=9oDCU_Oz6L0
https://www.youtube.com/watch?v=i4nbH89KCNU
PostPosted: 10:20 - 21 Apr 2014    Post subject: Reply with quote
Yours doesn't sound like its even turning the engine though. No ba dum ba dum ba dum from the engine, just rapid spinning.
You'll need to be running fast, I have to bump the Blackbird in 2nd cruising down a hill, so get running for 5+ seconds, run and jump onto the bike and bounce your arse on the seat as you dump the clutch and give it some go go juice.
I'm going to hold with that one for now as it is spinning just as fast as my 24v setup.
https://www.youtube.com/watch?v=K1cMhlrAKn0
PostPosted: 10:23 - 21 Apr 2014    Post subject: Reply with quote
This is an R6 spinning normally.
https://www.youtube.com/watch?v=Q9RAuH5val4
LaurenceR46
PostPosted: 11:50 - 21 Apr 2014    Post subject: Reply with quote
I agree with the above I have the same bike and it sounds like it isn't turning over right. I know you said it was wet but does it still prime the fuel pump when you turn the ignition on (make sure kill switch is not set to kill)?
Get someone to push you as it's much easier for push starting I've had bad experiences trying to push it myself with my short ass legs lol. It doesn't take a big push in 2nd gear anyone should be able to do it.
Yamaha R6 (R46) Rossi Replica Edition
ian505050
PostPosted: 12:57 - 21 Apr 2014    Post subject: Reply with quote
Yes it primes the fuel pump and the kill switch is not on.
I will have a go at bump starting it later today.
ian505050
PostPosted: 17:29 - 21 Apr 2014    Post subject: Reply with quote
Right,
I have removed all the spark plugs and tried holding them against the frame and turned all the lights off in the garage. When i try starting the bike i get no spark on any of the plugs.
So i can confirm that i dont have a spark so at least i have found something. What would be causing this?
EDIT--- IGNORE THIS, I DO HAVE A SPARK
Nb
PostPosted: 18:41 - 21 Apr 2014    Post subject: Reply with quote
If the engine is not actually turning over you wont get a spark, can you feel any puff out of the exhaust as you crank it?
RhynoCZ
PostPosted: 18:49 - 21 Apr 2014    Post subject: Reply with quote
Can you do this even when the killswitch is off?
I had NC27, when the killswitch was off, it let me to spin the starter but it wouldn't turn the engine. Thumbs Up
PostPosted: 18:51 - 21 Apr 2014    Post subject: Reply with quote
I'm voting for sprag clutch/starter clutch.
That engine is not spinning. It needs to spin for spark to occur.
ian505050
PostPosted: 19:37 - 21 Apr 2014    Post subject: Reply with quote
Right, i need to correct my statement i made before about the there being no spark at the plugs. I was trying to test one at a time which resulted in no spark but when i plugged all 4 spark plugs into the coils at the same time i got a very strong spark at all spark plugs.
I put the spark plugs into the bike and tried to start the bike again but had no luck.
So i now know i have a strong spark at all spark plugs.
Wull
PostPosted: 19:45 - 21 Apr 2014    Post subject: Reply with quote
Have you tried bumping it?
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
PostPosted: 19:49 - 21 Apr 2014    Post subject: Reply with quote
IT IS NOT TURNING THE ENGINE.
Simple as that, pull the cover off, most likely the left hand case if its similar to most Jap sports.
There will be a little oil, nothing mental though. Check for any damage.
It is not spinning the engine, it is far too fast. It has zero load.
I know this, I've spent far too long with a Blackbird in bits and have recharged my battery about 100 times in a week to diagnose a starting issue, this is not spinning the engine.
Bumping with a very decent run up and proper bumping method will start the bike, if it doesn't give it to another bump start lover.
ian505050
PostPosted: 20:10 - 21 Apr 2014    Post subject: Reply with quote
Right,
I will be bumping it tomorrow as I need food and bed now, thanks for all your thoughts so far.
PostPosted: 20:11 - 21 Apr 2014    Post subject: Reply with quote
ian505050 wrote:
food and bed
Laughing Definitely top of my list also. Bump start should be fine, if so its the mechanical side of the starter.
LaurenceR46
PostPosted: 17:01 - 23 Apr 2014    Post subject: Reply with quote
How's it going? Got her started? Cool
ian505050
PostPosted: 18:32 - 23 Apr 2014    Post subject: Reply with quote
I am currently unemployed so i have have been job seeking the past few days(even though the bike is obviously my main concern Smile ) . I am going to try and bump start it next time i have a dry day a friend that can give me a bit of a push.
PostPosted: 18:47 - 23 Apr 2014    Post subject: Reply with quote
It's only a 600, piss easy to bump start. I used to do them in first personally, but whatever works for you.
davebike
PostPosted: 08:11 - 24 Apr 2014    Post subject: Reply with quote
Sounds like just low compression from standing
Charge the battery
I would find the air intake
Crank it and spray easy start into the intake with about half throttle on this will burn very easily hopefully the engine will fire
Warm it up and give it a run and hopefully all will be well
We have this sort of game several time every spring with bikes that have been left over winter
DAve
Dave
NC750Xdct + others at work !
[email protected]
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 130.09 Kb
