| ian505050 |
 ian505050 Traffic Copper
 Posted: 08:19 - 21 Apr 2014 Post subject: Yamaha R6 Not Starting Issues with Video |
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%203/DSC09833_zps0764d334.jpg
Basically I have had my 2006 Yamaha R6 5SL for a few years problem free and i did not use it for 4 months over winter.
It has a DataAlarm fitted which killed the battery fitted so i bought a new battery and fitted and the bike worked fine the first 2 times i used the bike this year.
I then left the bike for 2 weeks and went to start the bike again and it did not start but the battery sounded like it had plenty of power. I have uploaded a video to you tube to show the issue.
https://www.youtube.com/watch?v=ucK6O4jt8m0&feature=youtu.be
I have checked the following so far:-
1. Battery reads 13.1 V and seems fine. I removed it and charged it anyway and put it back in the bike which had no effect. I have another brand new battery that i will be putting in the bike today to see if it starts but my thoughts at this moment in time are that its not a battery issue.
2. I removed all the Ignition Coil Spark Plug Caps cleaned them and removed all the spark plugs and cleaned them as well. I rubbed a bit of sand paper on the spark plug connections and replaced them. I also checked the gaps and checked the spark plugs for damage, none was found. The spark plugs were wet with petrol so i dont think its a fuel issue.
3. I checked the 2 x main 40 amp fuses under the seat with a multimeter and they both are fine.
4. I checked the side stand switch
5. I checked the kill switch
6. I checked i have fuel and i have about 7 litres of fresh fuel in the tank. I used the previous 10 litres of fuel that were from the same source on the last ride, so its not bad fuel.
Can anyone point me in the right direction of what i should be checking next? I need to find the main fuse box and i could really also do with a workshop manual for the bike but cant seem to find on that i can download.
| P.addy |
 P.addy Red Rocket
| Aff |
 Aff World Chat Champion
| ian505050 |
| ian505050 |
| ian505050 |
 Posted: 08:35 - 21 Apr 2014 Post subject: |
The new battery was only £20!!! so it may be a bit shit. Its the same part number as the old one and reads the correct voltage but maybe its the ampage that is an issue?
I have a brand new motobat battery that i can test on the bike today to see if its my cheap battery thats causing the issue
I have found some other videos which seem to be the same issue
https://www.youtube.com/watch?v=9oDCU_Oz6L0
https://www.youtube.com/watch?v=i4nbH89KCNU |
| P.addy |
 P.addy Red Rocket
 Posted: 10:20 - 21 Apr 2014 Post subject: |
Yours doesn't sound like its even turning the engine though. No ba dum ba dum ba dum from the engine, just rapid spinning.
You'll need to be running fast, I have to bump the Blackbird in 2nd cruising down a hill, so get running for 5+ seconds, run and jump onto the bike and bounce your arse on the seat as you dump the clutch and give it some go go juice.
I'm going to hold with that one for now as it is spinning just as fast as my 24v setup.
https://www.youtube.com/watch?v=K1cMhlrAKn0 |
| P.addy |
 P.addy Red Rocket
| P.addy |
 P.addy Red Rocket
 Posted: 10:23 - 21 Apr 2014 Post subject: |
This is an R6 spinning normally.
https://www.youtube.com/watch?v=Q9RAuH5val4 |
| LaurenceR46 |
 LaurenceR46 Renault 5 Driver
| ian505050 |
| ian505050 |
| Nb |
 Nb World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 18:49 - 21 Apr 2014 Post subject: |
Can you do this even when the killswitch is off?
I had NC27, when the killswitch was off, it let me to spin the starter but it wouldn't turn the engine.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| P.addy |
 P.addy Red Rocket
| ian505050 |
| Wull |
 Wull Crazy Courier
| P.addy |
 P.addy Red Rocket
| ian505050 |
| P.addy |
 P.addy Red Rocket
| _Iain_ |
 _Iain_ Banned
 Posted: 09:01 - 22 Apr 2014 Post subject: |
Worth noting that it probbably wont bump unless its got your weight on the seat.
It'll just lock the wheel. ____________________ Please be aware that the above post may be full of complete nonsense.
| LaurenceR46 |
 Posted: 17:01 - 23 Apr 2014 Post subject: |
How's it going? Got her started?  ____________________ Yamaha R6 (R46) Rossi Replica Edition |
| ian505050 |
 Posted: 18:32 - 23 Apr 2014 Post subject: |
I am currently unemployed so i have have been job seeking the past few days(even though the bike is obviously my main concern ) . I am going to try and bump start it next time i have a dry day a friend that can give me a bit of a push. |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 18:47 - 23 Apr 2014 Post subject: |
It's only a 600, piss easy to bump start. I used to do them in first personally, but whatever works for you. ____________________ My Flickr |
| davebike |
 davebike World Chat Champion
 Posted: 08:11 - 24 Apr 2014 Post subject: |
Sounds like just low compression from standing
Charge the battery
I would find the air intake
Crank it and spray easy start into the intake with about half throttle on this will burn very easily hopefully the engine will fire
Warm it up and give it a run and hopefully all will be well
We have this sort of game several time every spring with bikes that have been left over winter
DAve ____________________ Dave
NC750Xdct + others at work !
[email protected] |
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
