fork swap ground clearance problem pls help
ninoBFU
PostPosted: 12:11 - 21 Apr 2014    Post subject: fork swap ground clearance problem pls help Reply with quote
hi guys just installed a new set of forks on my bike and they are 5inch shorter than the original non usd forks which leaves me with 2.5inch ground clearance......not good.
what would be the easiest way to extend the forks with 3-4inches?
Someone suggested to get round blocks machined to screw on to the top of the fork leg after setting the forks and move the triple tree up.
is that the easiest and cheapest option available
thanks in advance
https://i202.photobucket.com/albums/aa161/nino__/Mobile%20Uploads/A8CDA9D6-2F02-4FB7-B775-FCC95974DDA3_zpsrkvs7yeu.jpg
https://i202.photobucket.com/albums/aa161/nino__/Mobile%20Uploads/A569875A-F47E-420E-A4E1-20792F942D8A_zpshn2kmkbq.jpg
<a href="https://www.bikechatforums.com/viewtopic.php?p=3879192#3879192/">My GSX 750 1981 Cafe Racer Project build</a>
SQL
PostPosted: 12:17 - 21 Apr 2014    Post subject: Reply with quote
I'd move the exhaust to a scrambler type, or sell the forks and get longer ones
CaNsA
PostPosted: 12:19 - 21 Apr 2014    Post subject: Reply with quote
I was just thinking the same thing.
SQL
PostPosted: 12:21 - 21 Apr 2014    Post subject: Reply with quote
Something like this but less shit looking
https://www.motorrad-news.com/wp-content/uploads/2007/11/derbi-mulhacen-659-nieto.jpg
CaNsA
PostPosted: 12:29 - 21 Apr 2014    Post subject: Reply with quote
https://www.picsauto.com/images/derbi-mulhacen-659-01.jpg
I doubt it can be any less shit than a failed post.
SQL
PostPosted: 12:31 - 21 Apr 2014    Post subject: Reply with quote
No failed post here Laughing
Shows up on my screen
Edit
PostPosted: 12:38 - 21 Apr 2014    Post subject: Reply with quote
There isn't an easy way. There are several hard and bad ways, most of which will not work (including your extended top cap idea) on account of there being a taper just above the bottom yoke clamp.
I'd put those forks on ebay and get in touch with the oldskool suzuki guys to find out what will fit properly.
SQL
PostPosted: 12:46 - 21 Apr 2014    Post subject: Reply with quote
CaNsA wrote:
Strange now its gone
ill reedit
sickpup
Old Timer
PostPosted: 19:26 - 21 Apr 2014    Post subject: Reply with quote
The easiest way for you to sort this would be to phone ABE on 0208 858 9052 and ask them to make you a set of stanchions that are 4inches longer, fit them and fit a 4inch spring spacer.
hmmmnz
PostPosted: 20:30 - 21 Apr 2014    Post subject: Reply with quote
custom made yokes, different forks
or new sanctions https://www.allbikeengineering.co.uk/forks.php
are really good as sick pup mentioned,
that would probably be the best option, they can do all the work
the humans are dead
I kick arse for the lord
PostPosted: 20:42 - 21 Apr 2014    Post subject: Reply with quote
I still bet you'll get something from another model off ebay that'll bolt straight in for the same price as you could sell the bits you have.
I know a few guys racing in post-modern classics and those air-cooled suzukis are, to a greater or lesser extent, pick-n-mix when it comes to parts.
CaNsA
PostPosted: 21:02 - 21 Apr 2014    Post subject: Reply with quote
Are they zxr400 forks?
69chris
PostPosted: 21:37 - 21 Apr 2014    Post subject: Reply with quote
a stepped top yoke is the normal cure Thumbs Up
sickpup
Old Timer
PostPosted: 22:36 - 21 Apr 2014    Post subject: Reply with quote
For a 4inch increase. You're talking rubbish.
The usual way around this is to use GSXR1100 forks as they are relatively tall but as the work is already done just get a pair of longer stanchions.
moonzoomer
PostPosted: 22:51 - 21 Apr 2014    Post subject: Reply with quote
BURN the witch
69chris
PostPosted: 06:59 - 22 Apr 2014    Post subject: Reply with quote
whatever you say Laughing
not the same forks or bike but you get the idea.....
https://www.billetbikebits.com/shop/index.php?main_page=product_info&products_id=90
and as the gsx is a fair bit heavier than the doner bike i reckon something like the above along with some up=rated fork springs would do the trick Smile
also iirc fzr1000 ru forks are prob a bit longer than most but as you say the hard works been done now so.........
evoboy
PostPosted: 07:51 - 22 Apr 2014    Post subject: Reply with quote
This is what my ZRX uses to overcome the shorter USD's.
Gives the same front ride height as the stock forks.
APT Motorcycles
sickpup
Old Timer
PostPosted: 09:28 - 22 Apr 2014    Post subject: Reply with quote
69chris wrote:
[whatever you say Laughing
The bit you seem to have missed is 3-4inches. Those yokes are suitable for about a 2 inch difference. Most head tubes are less than 8inches so to use a stepped yoke for 4inches...
ninoBFU
PostPosted: 23:44 - 22 Apr 2014    Post subject: Reply with quote
CBR 954 fireblade 2003 front end
ninoBFU
PostPosted: 23:45 - 22 Apr 2014    Post subject: Reply with quote
Thanks mate for the contact numer .. I'll ring him and hope for the best ....no point selling and buying new ones I thinks and this pair is a good one light big breaks
lihp
PostPosted: 23:46 - 22 Apr 2014    Post subject: Reply with quote
Because of that taper you would also need to taper the bottom yoke.
If you had clip-ons you would have them 4inches below the top of steering stem, going to near impossible to get a usable lock to lock on the road, without anything fouling.
ninoBFU
PostPosted: 23:48 - 22 Apr 2014    Post subject: Reply with quote
Thanks very much to all of you for the help...very much appreciated
Hope everything goes well with the longer stanchions ... I'll keep u posted
ninoBFU
PostPosted: 23:53 - 22 Apr 2014    Post subject: Reply with quote
https://i202.photobucket.com/albums/aa161/nino__/Mobile%20Uploads/7ED33AC2-60EF-4553-95E3-E14F102DD40E_zpsht1lgvfl.jpg
c_dug
PostPosted: 07:18 - 23 Apr 2014    Post subject: Reply with quote
I have sod all experience with this sort of thing, but the stance looks really cool, I'd rather change the exhausts than have longer forks.
I presume re-routing the exhaust is just as doable.
hmmmnz
PostPosted: 07:26 - 23 Apr 2014    Post subject: Reply with quote
i must admit, the rake angle looks pretty good like that,
it must have pretty lazy steering with the longer front end,
you might be forced to put a turbo on it and run the exhaust off to the side Wink
the humans are dead
The last post was made 12 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 130.53 Kb
