GPZ 500 oil leak hah
Mez
PostPosted: 16:46 - 22 Apr 2014    Post subject: GPZ 500 oil leak hah Reply with quote
Riding home from work today I get to about 2 miles from home and some dimwits try to cut me off from merging by driving bumper to bumper, so I let rip and race ahead when I get chance (naughty, I know). Not long after I start to notice a smell that isn't normal.... actually, I don't remember at what point I noticed the smell... err... anyway I pull up outside my garage to see steam/smoke from RHS of the engine. Looks like oil is seeping from my clutch cover, dripping down onto the frame and eventually hitting the floor. I can only assume the gasket is gone... I don't have the time or heat-resistant skin to investigate further just yet.
Did my aggressive riding blow it? IIRC it has about 25k miles on the clock, should I expect it to go anyway for wear & tear? I've not had this bike long, and also I'm still a bit thick Karma
My deviantArt gallery - My Youtube profile
Honda CG125 -> Baotian BT49 -> AJS JS125 -> Honda CG125-> Kawasaki ZL400 -> Kawasaki GPZ500
PostPosted: 16:55 - 22 Apr 2014    Post subject: Reply with quote
Sometimes the mechanical seal behind the water pump lets go.
FIrst find where the oil is coming from. It's not always coming from where the most oil is. Cleaning the engine thoroughly will help. I've even scattered a small amount of cemet dust over the outside of an engine before to isolate an oil leak.
For example, if you're seeing oil on the clutch cover, it could easily be coming from a perforated oil filter and blowing back along the engine then trickling down the outside of the clutch cover.
Mez
PostPosted: 17:03 - 22 Apr 2014    Post subject: Reply with quote
Yeah, I figured. From what I could quick glance, the oil appears to be seeping from the joint between the engine and clutch cover on the bottom edge. More investigation later.
TheManWithThe...
PostPosted: 17:07 - 22 Apr 2014    Post subject: Reply with quote
is it similar looking to the oil leak in this thread?
https://www.bikechatforums.com/viewtopic.php?t=288563
I had a rhs oil leak on my er5 and assumed it was a bad clutch gasket, but a rebuild (not because of the leak) proved it wasn't, so now thinking it's the seal behind the water pump, as suggested above.
MBK Nitro 50, Sold. Kawasaki ER-5, Honda ST1100
"Anyone can jump a motorcycle! The trouble begins when you try to land it..."
TUG
PostPosted: 04:44 - 23 Apr 2014    Post subject: Reply with quote
We have the same engine, leak in the same place maybe? Mine looks like it's coming from the oil pressure tester port bolt but I can't be 100% sure, it only leaks when the engine is running and the previous owner wondered if it's due to the oil pressure relief valve, im tempted to just replace all the gaskets to be honest and replace said valve.
Haz ER-5, innit!
PostPosted: 08:51 - 23 Apr 2014    Post subject: Reply with quote
The clutch is not pressurised (or it shouldn't be) so a leaky clutch cover gasket ought to leak all the time, not just when the engine is running (unless it is a very small leak which only happens when the oil is hot and runny).
So if it is leaking from there only when the engine is running it means the crankcase has become pressurised and therefore the crankcase breather is blocked. There is (obviously) a pressurised oilway behind the pressure guage blanking screw. Just a fiber gasket as I recall.
Anyway, an oil leak only when the engine is running pretty much has to be coming from a pressurised part of the engine. It shouldn't be from either if the side cover gaskets unless the breather is blocked.
Do have a good look at the oil filter. They can be hit by stones or rust through very easily and they are part of the pressurised oil circulation system. From experience, you can have a pinhole in your oil filter that mists oil out only at high revs. That oil can land up anywhere. In my case it was on my right foot and the mainstand.
lihp
PostPosted: 08:53 - 23 Apr 2014    Post subject: Reply with quote
Good point, oil filter is due to be changed though.
Stink, TUG's description was misleading, the leak is from the main gallery bolt, where oil pressure is tested the bolt is a banjo bolt and is under pressure.
lihp
PostPosted: 08:57 - 23 Apr 2014    Post subject: Reply with quote
TUG
PostPosted: 14:36 - 23 Apr 2014    Post subject: Reply with quote
This, Phil is 100% sure its from the oil pressure testing port/main gallery bolt which makes me believe it is down to the oil pressure relief valve.
Haz ER-5, innit!
Mez
PostPosted: 21:02 - 23 Apr 2014    Post subject: Reply with quote
Wise ones, it turns out it is the water pump. If the seals are so damaged that water is making it to the outside of the bike, should I be doubting the bearing in the pump? I just ask for peoples' past experiences, as I don't have the privilege of being able to leave a job and come back to it. Having the garage 100yds from the house I try to start and finish a job in one go. Fffffff.... Mad
TUG
PostPosted: 08:18 - 24 Apr 2014    Post subject: Reply with quote
Did you get some pics of the leak?
Haz ER-5, innit!
Mez
PostPosted: 08:59 - 24 Apr 2014    Post subject: Reply with quote
Have done now. On Nokia Potato HD. Hope the upload worked.
TUG
PostPosted: 09:06 - 24 Apr 2014    Post subject: Reply with quote
Yours is definitely coming from the cover mine is the big bolt to the left of yours.
Haz ER-5, innit!
Mez
PostPosted: 09:19 - 24 Apr 2014    Post subject: Reply with quote
Yarp. Just read through your post while work is quiet. I see the difference.
If I'm changing both seals, the mechanical and the oil, I'll need to drain the oil off won't I? Or should the angle on the sidestand give me enough clearance as it were?
TUG
PostPosted: 09:24 - 24 Apr 2014    Post subject: Reply with quote
Personally? I'd give it fresh fluids all round and tick it off as a service, 2 birds, one stone. Thumbs Up
Haz ER-5, innit!
Mez
PostPosted: 09:47 - 24 Apr 2014    Post subject: Reply with quote
True. Oil filters getting tatty anyways so it'll be due. Thanks folks for all feedback. Hope you get/got sorted Tug Thumbs Up
PostPosted: 12:29 - 24 Apr 2014    Post subject: Reply with quote
Just to warn you. Getting the water pump apart to get at the seals is not easy. It can be well corroded in there.
Mez
PostPosted: 08:34 - 27 Apr 2014    Post subject: Reply with quote
I've noticed. Any helpful tips?
The last post was made 12 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 102.8 Kb
