Car engine oil in bikes?
biggeeman
PostPosted: 18:54 - 22 Apr 2014    Post subject: Car engine oil in bikes? Reply with quote
Any ideas any one do it?
To cut a long story short bike has high oil consumption ( another story ).
10w50 for bikes is expensive a lot cheaper for cars and especially good for tops up as it being cheaper and i do a lot of topping up.
My mate runs a r1 on car oil with no probs i have a ktm vtwin i know the clutches can be a issue with car oil think its worth a go?
lol your funny
Clutchy
PostPosted: 18:56 - 22 Apr 2014    Post subject: Reply with quote
You could really of searched this, it's been done so many times.
Basically yes it's fine as long as it doesn't have any friction modifiers which can make your clutch slip
biggeeman
PostPosted: 18:57 - 22 Apr 2014    Post subject: Reply with quote
Friction modifiers how would i know that cheers.
lol your funny
Northern Monkey
PostPosted: 19:06 - 22 Apr 2014    Post subject: Reply with quote
Expensive oils have them, and have phrases like 'fuel economy' written on the tub
Stick with the cheap semi-synth from Halfords, Asda, or Wilkinsons.
smegballs
PostPosted: 20:03 - 22 Apr 2014    Post subject: Reply with quote
I've been putting car oil in countless bikes without a problem. My approach to oil is cheap oil changed often. As said, avoid anything that boasts of improving fuel economy. I got usually go for whatever generic semisynth is cheapest in my local motor factor.
andym
PostPosted: 21:16 - 22 Apr 2014    Post subject: Reply with quote
Oh.... Oh... does this mean there'll be a spate of 'do you nod', 'how fast have you gone', 'how to get a knee down', 'which tyres should I buy' threads? Razz
Moo.
PostPosted: 21:31 - 22 Apr 2014    Post subject: Reply with quote
Go for it, whats the worst that could happen? This subject has been done to death and to be honest it all comes down to rider preference. I've been using car oil for ages and it works great! Only recently have i had a go at bike specific oil to try and cure an annoying gear problem with the bike to see if it would smooth it out.
It will protect the engine just the same and as stated, because its cheaper you can change it more often! Always a great way to prolong that engine Wink
Atleast with the oil consumption and you having to put more oil in, you'll know its getting more fresh oil haha!
A2 Passed 18/6/10
1cyl
PostPosted: 21:33 - 22 Apr 2014    Post subject: Reply with quote
I have in the past used car oil without problems.
But as I now own fairly expensive more modern engines, which I push fairly hard daily. I feel inclined to use the right syrup for the job just for peace of mind.
usually look for the JASO.
Here's a brief smattering of info:
https://www.oilspecifications.org/jaso.php
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Moo.
PostPosted: 21:34 - 22 Apr 2014    Post subject: Reply with quote
A2 Passed 18/6/10
arry
PostPosted: 21:37 - 22 Apr 2014    Post subject: Reply with quote
I have a data sheet somewhere with the additive pack data, tbn and tan of a lot of synthetic car oils. I'd love to get a bike oil analysed and see what the differences really are
Robby
Dirty Old Man
PostPosted: 21:43 - 22 Apr 2014    Post subject: Reply with quote
10W50 is a fairly unusual grade, so a 10W50 car oil is likely to be a high end one and will have a high probability of causing clutch slip.
Those of us that use car oil tend to buy cheap 10W40.
Why do you need 10W50?
biggeeman
PostPosted: 22:23 - 22 Apr 2014    Post subject: Reply with quote
Ktm recommends 10w50 and i think most vtwins are the same,
i think heavier oil may help my oil consumption.
lol your funny
-Matt-
PostPosted: 23:02 - 22 Apr 2014    Post subject: Reply with quote
As a side note to whats been said already. My bike needs the wet clutch friendly oil (JASO-MA spec i think it is).
'Halfords motorcycle oil' as an example which ive used doesnt specify this on the minimally labeled tub. But i contacted comma who made/make? their oils and they confirmed all the oils they produce meet that requirement as standard, so may be more cheaper oils than it first appears that would be fine.
gavbriggs
PostPosted: 23:18 - 22 Apr 2014    Post subject: Reply with quote
So which are these oils?
A search for: jaso ma/ma2 rated car oil just brings up loads of 4t oils.
What brands/grades can be used?
biggeeman
PostPosted: 23:33 - 22 Apr 2014    Post subject: Reply with quote
I think its any cheap shit semi synthetics from asda or halfords my mate has the asda one blue tub £16 for 5 litres in a r1 with no clutch slipping but then again he would piss in it if it ran!
So i wanted this double checked think i will go buy this tomorrow.
https://m.direct.asda.com/ASDA-10W40-Semi-Synthetic-Oil---5L/001021119,default,pd.html
lol your funny
PostPosted: 23:45 - 22 Apr 2014    Post subject: Reply with quote
Not had a problem with any I have used (including fully synthetic 5W40 car oil). Used a 10W40 BP oil for years, and then a 10W40 Rock Oil semi synthetic car oil.
A few people have had problems, and one that does crop up as causing issues is the Castrol Magnetec range (rather than normal GTX).
gavbriggs
PostPosted: 00:05 - 23 Apr 2014    Post subject: Reply with quote
Might be worth a good scout around and a sticky on car oils suitable for bikes? If someone can be arsed it will save a lot of cash
arry
PostPosted: 08:15 - 23 Apr 2014    Post subject: Reply with quote
Just had a look at the data sheet off my phone so difficult to read but oils with high molybdenum content are in order of content levels:
Castrol RS 10w 60
Valvoline max life 10w 40
Castrol Magnatec
Mobil 1 motorsport 15w 50
Motul 20w 50
Other friction modifiers are available and may be present. And bear in mind the data here is just a limited number of oils tested.
Halfords motorsport 5w 50 has no molybdenum content when tested, nor does Carlube Triple R. Shell Helix and Valvoline Synpower appear to have very low levels.
Shinigami
PostPosted: 10:44 - 23 Apr 2014    Post subject: Reply with quote
topic has been done to death, I currently use cheap halfords 10w40 which I stocked up on when they flogged it off dirt cheap, no problems at all
DrSnoosnoo
PostPosted: 12:26 - 23 Apr 2014    Post subject: Reply with quote
just my Penny Coin Penny Coin worth.
I used ASDA 10w40 in the ZZR at the last change. This year I might go for some morrisons - it's closer.
MarkJ
PostPosted: 12:37 - 23 Apr 2014    Post subject: Reply with quote
This. I can't remember the last time I bought motorcycle specific oil, been using Halfords and Castrol GTX (NOT magnatec) when it's on offer in ASDA for years.
biggeeman
PostPosted: 13:22 - 23 Apr 2014    Post subject: Reply with quote
Just done a oil change with asda brand 10w40 semi synth
Just gonna nip out n test heres hoping. Sad
lol your funny
MarkJ
PostPosted: 13:52 - 23 Apr 2014    Post subject: Reply with quote
It's fine, I've used that in the past too.
biggeeman
PostPosted: 15:50 - 23 Apr 2014    Post subject: Reply with quote
Hahaha job done runs sweet as a nut £16 and ive got 1.5 litres left for top ups.
No probs with clutch either, still clutch wheelies as it did before Thumbs Up
Thats Asda price ching ching
Cheers for the help.
lol your funny
weasley
PostPosted: 18:11 - 23 Apr 2014    Post subject: Reply with quote
Castrol RS 10w 60
Castrol Magnatec
Motul 20w 50
Molybdenum is not a way of determining friction modifier presence. More often than not they are organic compounds with no metallic elements. Mo is usually present as MoDTC, which does have a frictional effect, but is far from the only or most common one.
The last post was made 12 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 128.64 Kb
