How much 'mayo' is ok?
maxp
PostPosted: 15:23 - 23 Apr 2014    Post subject: How much 'mayo' is ok? Reply with quote
As a preface, I probably only use my bike once or so a week, and with that, each trip usually varies between 10 miles to 50 miles in overall distance.
Anyway, I noticed a white hazing over the oil glass window last week, and it appears to be a very thin film of what we all know as mayo. I popped the filler cap off, and a few small blobs of white mayo were on the filler cap also.
After peering down filler neck, the oil colour looks totally fine, im not losing any, plus the expansion level is also fine, with no contaminants. The temperate needle also behaves as expected (moves up when im at a standstill otherwise sits in the blue)
The bike is a ZXR400, which is seemingly prone to HGF, and has covered ~15k miles.
Is this white gunk something that will 'burn off'? is a little bit okay? or could this be the end of the gasket?
DrSnoosnoo
PostPosted: 15:30 - 23 Apr 2014    Post subject: Reply with quote
I've had some over the winter months from just short rides. Since having longer blasts it's all burned off. Go for a long run now it's warmer.
Northern Monkey
PostPosted: 15:33 - 23 Apr 2014    Post subject: Reply with quote
Since an oil change will only take you 20 minutes, and cost about a tenner, why not change the oil, then you can quickly tell if it re-appears.
orac
PostPosted: 16:11 - 23 Apr 2014    Post subject: Reply with quote
the white stuff is actually caused by water in the sump - not dont be too allarmed, change the oil for started. however due to the low usage of the machine it no that unusaly depending on where the machine is kept.
it oftern caused by condestation in the casing, this is actually a side afftect of the internal combustion engine, it make water from the buring of patrol. the more you use the bike, the less there will be.
it can also be affteced but the distance you ride, i ride 20 miles (10 there, 10 back) 5 time a week and i dont have any issue, but the bike always get hot to get the water to evaporate out thought the breather and there isnt enough tiem between rides for a signifacant amount to build up.
so in other words, ride, ride alot more you know you want to, while you are at it, ride harder - insert opropiate joke here
ws4936
PostPosted: 21:11 - 23 Apr 2014    Post subject: Reply with quote
A little condensation never hurt anyone, but as mentioned, the bike needs a good ride. If your commute is short, once a month or so, you should ride for pleasure - give it some beans, enjoy yourself. It'll soon burn off.
If it keeps happening or if the bike starts overheating, then you now it's not condensation. Could be gasket, could be impeller. You'll just have to ride it and see.
If everything seems under control, you're just not going fast enough.
kramdra
PostPosted: 23:36 - 23 Apr 2014    Post subject: Reply with quote
It will burn off, go for a long ride on a hot day. After, let the bike idle until the fan has cut in for a min or two, and it will be gone - happened to me a month ago.
If the oil is old, it may be a good idea to change the oil and filter as well - mine was very new, so I did not.
In cold or excessively wet-cold weather a bike is not going to get above 60c. In winter or for short journeys it may be worth covering half the radiator - this make a huge difference on the cbr6. I did think my thermostat was broken, but this is normal.
The last post was made 12 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 48.33 Kb
