| maxp |
 maxp Renault 5 Driver
 Posted: 15:23 - 23 Apr 2014 Post subject: How much 'mayo' is ok? |
As a preface, I probably only use my bike once or so a week, and with that, each trip usually varies between 10 miles to 50 miles in overall distance.
Anyway, I noticed a white hazing over the oil glass window last week, and it appears to be a very thin film of what we all know as mayo. I popped the filler cap off, and a few small blobs of white mayo were on the filler cap also.
After peering down filler neck, the oil colour looks totally fine, im not losing any, plus the expansion level is also fine, with no contaminants. The temperate needle also behaves as expected (moves up when im at a standstill otherwise sits in the blue)
The bike is a ZXR400, which is seemingly prone to HGF, and has covered ~15k miles.
Is this white gunk something that will 'burn off'? is a little bit okay? or could this be the end of the gasket? |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| Northern Monkey |
 Northern Monkey World Chat Champion
| orac |
 orac World Chat Champion
 Posted: 16:11 - 23 Apr 2014 Post subject: |
the white stuff is actually caused by water in the sump - not dont be too allarmed, change the oil for started. however due to the low usage of the machine it no that unusaly depending on where the machine is kept.
it oftern caused by condestation in the casing, this is actually a side afftect of the internal combustion engine, it make water from the buring of patrol. the more you use the bike, the less there will be.
it can also be affteced but the distance you ride, i ride 20 miles (10 there, 10 back) 5 time a week and i dont have any issue, but the bike always get hot to get the water to evaporate out thought the breather and there isnt enough tiem between rides for a signifacant amount to build up.
so in other words, ride, ride alot more you know you want to, while you are at it, ride harder - insert opropiate joke here ____________________ Current rides - 2016 Triumph Street Triple Rx, 1994 Suzuki Bandit 400 VM, TGB 204 Classic 125cc
"with nothing left to lose, there is everything to gain. It's not the size of the dog in the fight, it's the size of the fight in the dog" |
| ws4936 |
 ws4936 World Chat Champion
| kramdra |
 kramdra World Chat Champion
The last post was made 12 years, 210 days ago. Instead of replying here, would creating a new thread be more useful? |
