MOT brake question
bamt
PostPosted: 17:24 - 23 Apr 2014    Post subject: MOT brake question Reply with quote
I'm coming up to needing an MOT on my Divvy 900 (just over a month left, so time to start checking it out). I know that front brakes binding is a fail (apart from being generally not good anyway). But what is classed as "binding"? My front was starting to bind badly a couple of months ago, I gave everything a good clean up and it is now almost perfect. Spinning the wheel it runs for a good amount of time, however I guess one of the disks isn't quite true as there is a very light rubbing noise of the pads on the disk every rotation (but, as I mentioned, the wheel spins many times before stopping).
So, does it have to be silent running for an MOT pass, or just spinning freely, or is it entirely down to the tester's judgement?
WD Forte
PostPosted: 17:44 - 23 Apr 2014    Post subject: Reply with quote
I reckon they'd have to be pretty harsh to fail for a light scuffing
between disc and pads.
If a wheel wont spin for more than one revolution because of warped
discs or sticky pistons/pads, that's usually a fail.
bikers smell of wee
gavcarter
PostPosted: 17:45 - 23 Apr 2014    Post subject: Re: MOT brake question Reply with quote
Ive only hung around for a couple of mots lately and they used a roller with a digital readout to measure how much the brakes where binding by.
bamt
PostPosted: 18:08 - 23 Apr 2014    Post subject: Reply with quote
Thanks. Together with WD Forte's MOT link I feel OK about that now.
moonzoomer
PostPosted: 20:49 - 23 Apr 2014    Post subject: Reply with quote
The brake will fail after the new rules are introduced in GB, the new rules are currently being applied to NI and are a bit of a nightmare as the rider/owner must do the test.
ADSrox0r
PostPosted: 06:11 - 24 Apr 2014    Post subject: Reply with quote
Mine just went through with a mild bind on the front, a slight "Hssssshhh" as you spin. Passed, not even mentioned.
andym
PostPosted: 12:48 - 24 Apr 2014    Post subject: Reply with quote
I took my bike for it's mot last time I was in Glasgow and the guy failed it for the brakes binding and warped discs, after several caliper strips and rebuilds to me they were fine, but every time I took it back the guy just tilted the bike up, spun the front wheel, forced the brake lever back to the handlebars, let it go and spun the wheel again and kept saying they are still binding.
Took it to an MOT station in Bristol and explained the problem it had failed on, so before even doing the MOT the guy took it on the rolling road thing and tested the brakes thoroughly and said there wasn't a problem with them.
So I need to find a new MOT station up here before September as I'm not going back to that guy again
janner_10
PostPosted: 20:38 - 24 Apr 2014    Post subject: Reply with quote
Take it in and get it mot'd, they give you a fail list and you have 10 days to sort it out. If in fact it is really a problem.
PostPosted: 00:35 - 25 Apr 2014    Post subject: Reply with quote
Find an MOT station you are happy with and stick to them.
They should all apply the rules the same but they obviously don't.
Anyone who spins a wheel on a bike with discs should be well aware there will be contact between wheel and pads.
bamt
PostPosted: 05:35 - 25 Apr 2014    Post subject: Reply with quote
That's the thing. Yes, I can take it in and see what fails, but I'd rather not have to make time for two trips to a garage when a bit of tinkering that I'd end up having to do anyway will sort it out. In this case, I'm more than happy with the brake myself (no appreciable difference in pad wear in several thousands of miles, no warming of the disk, and it is only a very slight rub). However, not having put a bike through an MOT before I don't have either a good idea of what is acceptable for the tests hence asking here.
I'm probably just being a little paranoid about this as it is an old-ish (2001) bike. Nor do I have a trusted MOT station (yet). The one I use for cars, who is very good and definitely not inclined to make work, doesn't do bikes.
ws4936
PostPosted: 07:19 - 25 Apr 2014    Post subject: Reply with quote
All stations should be testing fairly, but as mentioned they don't.
The GPZ is notorious for front brake binding, the calipers designed in such a way all the crap gets in there and ceases the pistons when the brake is applied. A swift kick to the caliper will free it. Temporarily
I had a fail for a binding brake, rode it home, rode it there the next day, and kicked the caliper before turning the last corner - tester praised my efforts in addressing his concerns.
It's just one of those things.
If everything seems under control, you're just not going fast enough.
bodger
PostPosted: 08:00 - 25 Apr 2014    Post subject: Reply with quote
As already mentioned, the test is done on a rolling road and that will sense if the brakes are binding excessively. Also if the disc is warped excessively it would be a fail. You can normally feel the
brake lever pulsing if the disc is warped when you apply the brake.
c_dug
PostPosted: 10:27 - 25 Apr 2014    Post subject: Reply with quote
If it spins more than once I can't see it being an issue, at least I hope not, my divvy 900 is due it's MOT too and I have the same concern, my SV650 passed a few weeks back with not fantastic brakes though so it should be fine.
map
Mr Calendar
PostPosted: 10:58 - 25 Apr 2014    Post subject: Reply with quote
I agree with the discrepancies in MOT stations.
For many years I took my bikes to a testing station. Usually passed ok except where I'd missed something like too much worn brake pads.
However, they got a new tester, some Polish guy. I think he's maybe out to prove himself (although still the same after about 4 years). He is picky-picky-picky. Example one of my bikes had silver bolts heads in the number plate. Rejected, failed MOT, had to replace with the plastic coloured ones. This on a bike that'd passed 3 years on the trot at same place.
Now take bikes to another tester. He's human and knows the difference between safety and cosmetic nit-picking. Cosmetic goes on advisory, safety gets a fail. Like others above though he'll actually fix something then effectively re-test for you. A man who knows customer service / loyalty.
janner_10
PostPosted: 14:35 - 25 Apr 2014    Post subject: Reply with quote
Your worrying like a old woman to be honest, my bike is older and sat in a barn for 4 years, I just took it in, sat for 30 mins with a coffee. As it happens it passed, but I didn't fret like this.
Join the local forums / plenty of groups on facebook for bikers in any locality where you could get recommendations from.
To me booking and turning up for an MOT is a simple straight forward thing - certainly not worth of fretting and worrying about - get it done.
Bunny Lingus
PostPosted: 20:27 - 25 Apr 2014    Post subject: Reply with quote
Trouble is with brakes they can't really let you off with an advisory. My guy has a good writing arm on him but even he didn't like my brake binding. When you kick the caliper does it free off? If so, you can get it failed then strip & grease. As long as there's improvement he should pass it.
Bunny Lingus & The Flipside Faggots
clancy
PostPosted: 20:44 - 25 Apr 2014    Post subject: Reply with quote
My rvf had very warped discs, rubbed at all points when rotating the wheel and had a strong judder in the brake lever
Never mentioned over 3 mot's for some reason
KLX 300r
moonzoomer
PostPosted: 21:02 - 25 Apr 2014    Post subject: Reply with quote
Vincent wrote:
Unfortunately, some MOT stations will either exaggerate, or completely fabricate problems with bikes and cars in the hope that they can make a bit more money out of the customer. They employ the "if you can't blind 'em with science, baffle 'em with bullshit" work ethic and see someone with perhaps less knowledge about mechanics than others as an opportunity to blag them out of what's in their wallet.
As Polar says, you need to find somewhere that you can trust..... and stick with them. I've used the same stations, different ones for cars and bikes, for the last 20 years or so, even though one is 100 miles away, (although somewhere I regularly visit anyway).
They both offer free re-tests and, if the problem is a small one, for eg a blown bulb, would rectify before proceeding with the MOT. Neither place would pass a vehicle with a serious fault but both exercise a bit of common sense and, most importantly, don't try to rip me off.
Try a post asking for recommended stations in your area, someone on here may know of one.
If you feel you've been targeted, I'd consider naming and shaming this particular garage so others can avoid.
You make a good point about variation of test results from different testers, perhaps GB should follow the NI test system which is totally computer controlled thus removing almost all human input.
clancy
PostPosted: 21:13 - 25 Apr 2014    Post subject: Reply with quote
Vincent wrote:
I'd like to see more MOT stations and garages being investigated by undercover "customers" and once found guilty of fabricating faults to make profit, not be allowed to work in the trade again.
It's bloomin' expensive enough to drive/ride as it is....without being ripped off by garages.
If they look too close they'll get rid of the "friendly" mot places however Thumbs Down
KLX 300r
Bunny Lingus
PostPosted: 21:16 - 25 Apr 2014    Post subject: Reply with quote
Then there's no discretion. Building up a rapport with the tester has always been my favourite. He gets all your business, you get the job done. For example, my bloke had a quiet word that my steering bearings were past their sell by date but he failed it on a binding brake 'cos he knew that a couple of hours with a spanner & it would be back for retest. £40 for head bearings is a different kettle of fish. A computer is just gonna say nooooooooo. Gimme a humanoid anytime.
moonzoomer
PostPosted: 21:24 - 25 Apr 2014    Post subject: Reply with quote
TBH I would never treat a GB MOT cert as anything other than a worthless piece of paper and would always get a NI test done when I purchase a vehicle from GB regardless if the vehicle has just passed an MOT, I found this out the hard way when I bought a Saab car from England only to find it was totally unroadworthy including none existent rear brakes, a broken front spring and more holes than a teabag but still had a full years GB MOT, having a rapport with your mate down at the test station is one thing (which I agree with) but to allow wrecks on the road is a whole different story.
Bunny Lingus
PostPosted: 21:28 - 25 Apr 2014    Post subject: Reply with quote
Yeah, agreed. Then it'll start becoming expensive for those of us with older rides. It shouldn't be too hard for peeps to find "friendly" places. If "customers" start getting uppity they'll all start to tighten up & then we'll all suffer the consequences. I've been to a place, one of the wanker showroom gaffs, where the dude wheeled a fucking great machine over to my ride, gave it a rectal probe & failed it on emissions. Give me a shabby ol' workshop every time...
The last post was made 12 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 134.26 Kb
