| GSTEEL32 |
 GSTEEL32 Traffic Copper
 Posted: 21:32 - 22 Apr 2014 Post subject: Just bought a RSV Mille for £1400 - What to look for? |
Its a Cat D (meh!), and has obviously had a low speed drop on its side, but its just done 40 miles around the north circular without missing a beat. Its got a Power commander 3 fitted, but no idea what map its got. Is the PC3 with an original exhaust a bit pointless ?
I might give it a once over this weekend and a quick service. Is there anything in particular I should be keeping an eye on ? I've got no service history, so what jobs should I definitely tackle first ?
I've not had it long , but would definitely say the engine feels less "agricultural" than my previous Ducati twin....
https://i.imgur.com/qa6nq1t.jpg
https://i.imgur.com/CH0VR6Y.jpg |
| _Iain_ |
 _Iain_ Banned
 Posted: 21:42 - 22 Apr 2014 Post subject: |
Rear shock linkage.
It likes to seize & snap the bottom off the shock at a cost of some serious wonga (more than half what you paid for the bike) ____________________ Please be aware that the above post may be full of complete nonsense.
| spikenipple |
 spikenipple Crazy Courier
 Posted: 21:45 - 22 Apr 2014 Post subject: |
It's pretty important with these bikes to keep the battery charged properly so it has a good chance of starting properly. The starter sprag clutch breaking is a common fault when the battery is a bit weak. It's worth fitting a 14v battery with high CCA (Cold Crank Amperage) to avoid this.
Smear all and any exposed electrical connectors with dielectric grease as you might have trouble with it in the wet otherwise. I did these to my RSVR and it was right as rain for the time I had it!
I also fitted a Scottoiler, which was the best thing I've ever done to a bike
You got yourself a bargain, I'm a bit jealous! ____________________ C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike |
| mentalboy |
 mentalboy World Chat Champion
| MarJay |
 MarJay But it's British!
| MarkJ |
 MarkJ World Chat Champion
 Posted: 22:54 - 22 Apr 2014 Post subject: |
As above, grease both bearings in the dogbone linkage and the lower bearing on the swingarm (where it attaches to the triangle shaped bracket), and keep the battery in tip top condition. If the engine kicks back it bangs against the sprag clutch (you'll know when this happens, it not a nice sound). If this happens too many times it knackers the sprag clutch and you need a new one. If you do, there's a BMW sprag you can fit that's cheaper than the Aprilia part, but the sprag is nestled away inside the engine so best not to have to do this job
As Marjay said it's a dry sump, but still easy to do an oil change, you just drain the oil tank first, then the engine oil drain (next to the filter cap) then undo the filter cap and change the filter. The large oil filter O ring squashes quite easily and can start to dribble oil a bit so stick your hand down there and see if it's doing this. New O ring is a few quid off ebay. There's no washer between the main oil drain bolt and engine, so the torque setting is relatively low. No need to tighten it massively because then they're a real pain to undo again next time.
I think you also measure the engine oil with the engine running, and hot. Double check this though as my Mille is a track bike and gets an oil change before the levels get anywhere near low.
I always start the bike like so, to avoid the sprag getting a hammering:
In neutral
Clutch in
All lights off
Full 'choke' (fast idle)
No throttle
The engine is very lumpy low down, it should be smoother after 4-5k or so though. Most people just get a custom EPROM made rather than a PC |
| CHR15 |
 CHR15 Turbo nutter bastard
 Posted: 21:16 - 23 Apr 2014 Post subject: |
with the bike level, and the engine hot but not running, you want about 20-25mm of oil showing on the sight tube.
any more than that and it starts to blow it though the breather into the airbox.
if the battery goes low whilst cranking it resets the clocks, which includes defaulting the rev limiter to like 5.5k you adjust the limiter with the ignition on but engine not running.
the stock exhaust weighs eleventy billion kilos. aprilia did a titanium race can which is the same bore as the link pipe all the way through (rather than all the aftermarket ones which step the link pipe down to 2" and run a 2" bore can)
the rear brake does fuck all. this is normal. ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
| GSTEEL32 |
| MarkJ |
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
 Posted: 01:00 - 24 Apr 2014 Post subject: |
Really good forum here (although Mainly for Falco's which is what I have) https://www.ridersite.ws/rs/index.php?sid=65b3319326c1b8bea77ad579d14a3fc9
Essentially the same bike. Definately check the rear linkages/bearings. Just had to do mine and has cost a fair bit (Dont ever buy Aprilia stuff theres always a much cheaper way to get the exact same part). ____________________ Pictorgraphicalfantastical |
| nerald |
 nerald Borekit Bruiser
| P.addy |
 P.addy Red Rocket
| chris-red |
| chris-red |
| GSTEEL32 |
| CHR15 |
| MarkJ |
 Posted: 21:09 - 24 Apr 2014 Post subject: |
Mille's are ace for filtering if you can get used to the riding style the standard boat anchor exhaust may be heavy, but it's pretty loud for standard. Like parting the red sea  |
| GSTEEL32 |
| P.addy |
 P.addy Red Rocket
 Posted: 22:08 - 24 Apr 2014 Post subject: |
Filtering under 30mph? That isn't filtering. That is parked
Looks a steal with the carbon etc. |
| devojunior |
 devojunior Brolly Dolly
| GSTEEL32 |
| chris-red |
The last post was made 12 years, 187 days ago. Instead of replying here, would creating a new thread be more useful? |
