Left handlebar is dodgy
notbike
PostPosted: 15:40 - 24 Apr 2014    Post subject: Left handlebar is dodgy Reply with quote
This is kind of a simple thing, but I've never done any kinda mechanics at all so bare with me. Embarassed
Was setting off today for uni, and realized my left handlebar felt really weird, looked down, and it was actually bent inwards towards the tank cause the bolt isn't there... Well, the bolt head isn't there - The actual screw is lodged into the thread so its like completely stuck in there. This allows the handlebar to move around pretty much.
With a little force I pushed the handlebar back to it's normal position and it stays there and didn't cause problems today but I'm worried it could suddenly come loose mid ride. That would suck, my steering would be totally screwed.
It's a YZF R125, second hand, it's been dropped by previous owner (it seems to run fine) but the bolt on that handlebar is one thing I missed.
Also I got MOT coming up like this week, would it fail..?
How do I get this screw out, and where can I get replacement screws? Can a garage do it for me lol?
This pic shows the thing that the screw for the handlebar is stuck in:
https://i.ebayimg.com/t/Yamaha-YZF-R125-top-yoke-upper-fork-Ignition-clamp-2008-2009-2010-2011-2012-/00/s/MTE5OFgxNjAw/z/JGEAAMXQVs1Rm91U/$T2eC16RHJGsFFMmSm84tBRm91TtS2Q~~60_35.JPG
I hope I ain't gotta buy a new one of those ^ or something Thumbs Down
CaNsA
PostPosted: 15:41 - 24 Apr 2014    Post subject: Reply with quote
Take the bar off and look to see if there is any of the screw to grab hold of with some mole grips.
PostPosted: 15:48 - 24 Apr 2014    Post subject: Reply with quote
Regardless of whether it is an MoT failure it needs to be fixed. It should be fairly easy an independent garage would probably charge £30-50 to fix it.
Mole grips will be no use. If the clip on (not handlebar Wink ) can rotate around the fork, there won't be enough thread to grip. You should be able to get the thread out by knocking a slot into the thread with a chisel or just tapping it round if you can get some purchase with a screw driver.
Where are you based I'm sure a local BCF'er can help if you are having trouble.
edit:- You look local to me, I could probably fix that in less than an hour and have plenty of spare bolts that should fit. I'm in RM12.
notbike
PostPosted: 15:53 - 24 Apr 2014    Post subject: Reply with quote
Ahh cheers guys, yeah I can't take off the bars now but likely will give it a go after work. yeah it's bugging me now D: I think the bolt is stuck in there like rusted in and what not. I'm based in hendon/london if anyone wants to have a go at some point haha.
If I somehow screw it up tonight I'll probably take it to a garage but I can't justify paying £30-50 for that!
Edit: thats NW4
PostPosted: 15:56 - 24 Apr 2014    Post subject: Reply with quote
It really should be easy and bolts are pennies.
It shouldn't be stuck and should turn easy I'd did a flat head screw driver on one side and tap it round with light blows from a hammer.
Good Luck Thumbs Up
notbike
PostPosted: 15:59 - 24 Apr 2014    Post subject: Reply with quote
okie doke haha I'll give it a go then, thanks mate, I'll start looking for bolts for it too then Razz
sickpup
Old Timer
PostPosted: 17:47 - 24 Apr 2014    Post subject: Re: Left handlebar is dodgy Reply with quote
Of course it will fail, it's dangerous to ride.
PostPosted: 18:24 - 24 Apr 2014    Post subject: Reply with quote
Looking at pictures of an R0.125 handlebar setup, they are standard clip-ons with an additional lug. That bolt is presumably there as an additional point to prevent the bar rotating on the fork but ought to be pretty much redundant if the clamp is done up properly.
It would still probably fail an MOT if the head is sheared off but the clamp ought to be doing the majority of the task of holding the handlebar onto the fork leg.
I'd go so far as to say, the clamp being loose is probably why that bolt sheared in the first place. Tighten your clamp.
notbike
PostPosted: 16:07 - 25 Apr 2014    Post subject: Reply with quote
Ahh so today I had some free time and managed to fix it. In the end I used a screw driver and tapped it and the bolt started coming out. Thank fck I wont fail an MoT due to something silly like this Very Happy
Ty for your suggestions and help Thumbs Up
bolt was stuck in that hole in pic 3 only took 10 minutes after all Rolling Eyes
https://i.imgur.com/yN5BRl4.png
PostPosted: 23:36 - 25 Apr 2014    Post subject: Reply with quote
Something looks horribly wrong with that handlebar clamp. Anyone else?
The pinch of the clamp has bottomed out (red arrow). Suggesting either the clamp itself has become stretched/fractured or the top of the fork stanchion is deforming.
Possibly both?
Red circle: Defect, could be a casting mark but check for cracks in the metal.
Blue circle: This looks ovalled to me.
notbike
PostPosted: 00:18 - 26 Apr 2014    Post subject: Reply with quote
Reckon I should get a new one? You got me worried now lol I didn't even notice anything at all D: inexperienced eyes I guess. Could this screw the handling of the bike or something? Or indicate a bigger problem?
PostPosted: 00:33 - 26 Apr 2014    Post subject: Reply with quote
Could be an optical illusion, always the trouble with photos of bike parts. How does it compare to the one on the other side? Especially with regard to the gap in the clamp shown by the red arrow?
The screw you replaced ought to be redundant, you shouldn't be able to move the handlebar once it's clamped up tight even without that screw in.
notbike
PostPosted: 10:46 - 26 Apr 2014    Post subject: Reply with quote
Ah I see, I mean it's slightly tighter than the other handlebar. It seems to be pinched together a fair bit more where you show the red arrow in the pic. But there doesn't seem to be anything wrong with the red circle, and that black thing wasn't pushed all the way in when I took the pic, I think. Hmm.
Ballpien
PostPosted: 16:56 - 26 Apr 2014    Post subject: Reply with quote
For comparison, this is what they should look like. Never touched, removed, adjusted or dropped.
https://i58.tinypic.com/vwshus.jpg
https://i61.tinypic.com/4u9s88.jpg
Aff
PostPosted: 17:00 - 26 Apr 2014    Post subject: Reply with quote
Possibly both?
This, something is definitely wrong.
Electric Bike Project
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 89.75 Kb
