Brake pads too thick?
Dave M
PostPosted: 16:44 - 24 Apr 2014    Post subject: Brake pads too thick? Reply with quote
Evening All,
Just tried to put in new pads. Tried a brand called Kyoto (I know). A few people have recommended them. Problem is they were binding really bad. I gave pistons a good clean and they move easily in and out so I think they are ok. What I've noticed is when I put the caliper back on one of the bracket bolt tips is touching off all of the disc bolts as the wheel spins. I took the bracket off to gain better access to clean the pistons. In the end I just put the old pads back in. Everything is clean and greased up as it should be. What can I do now with these pads? Could I sand fook out of them to take some of the material off? Could it take a long time? Bike is a Hyosung gt125 comet 2010.
RhynoCZ
PostPosted: 16:58 - 24 Apr 2014    Post subject: Reply with quote
Open the fluid reservoar and reduce the amount of brake fluid in there. Then push the pots back into the caliper as far as you can. If that won't work, then you've got a problem. Thumbs Up
Dave M
PostPosted: 17:01 - 24 Apr 2014    Post subject: Reply with quote
Yeah I tried that. What problems could I be looking at 😕. Cheers.
RhynoCZ
PostPosted: 17:03 - 24 Apr 2014    Post subject: Reply with quote
That is odd, are you sure you pushed the pots completely in? Thinking
Also, is the brake disc up to specs/OEM?
EDIT: Post some pics. Thumbs Up
Dave M
PostPosted: 17:22 - 24 Apr 2014    Post subject: Reply with quote
That was the same with my bracket. Tried to compress it but couldn't. It only compresses in and out on one pin. It's fine with old pads in but they are very low now. Slider pin is greased up and moves ok. Should the other slider pin move or should that be stuck into the caliper body? I have never come across this problem before. Pistons were all the way in. Don't know how to post pics? Rear brakes were binding badly as well.
andys675
PostPosted: 17:24 - 24 Apr 2014    Post subject: Reply with quote
some pads do come in different thickness's for different bikes, if you've ever seen EBC part numbers you'll have seen some pads with /3 after them, like FA69/3 which means the pad is thicker, so might have to 'adjust' them
sickpup
Old Timer
PostPosted: 17:37 - 24 Apr 2014    Post subject: Reply with quote
What is the FA part No. of the pads.
Various pads come in different thicknesses.
Dave M
PostPosted: 17:45 - 24 Apr 2014    Post subject: Reply with quote
So should I start sanding ☺
The last post was made 12 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 58.13 Kb
