battery/charging issues
mattyjohn93
PostPosted: 17:07 - 24 Apr 2014    Post subject: battery/charging issues Reply with quote
When I bought the bike the battery was flat so I got one off my mate. Still wouldn't charge. Would run fine with a kick though. Just replaced the rectifier as everything works when it's running (rulling out stator), albeit dim
Connected the battery to the car battery to try put some charge in. Displays 12.7 (same as car, turned off) but I disconnect the jump leads and the battery voltage drops to 5.5v. Going to leave it a little bit longer to see if it stays charged. It's not even enough power to sound the horn etc
RhynoCZ
PostPosted: 17:10 - 24 Apr 2014    Post subject: Reply with quote
I think the battery is dead and you should get another one. It only showed 12.7 because of the car battery plugged in the circuit. Ask a mate if he could lend you his battery.
EDIT: Your charging system might be OK. Just try another battery. Thumbs Up
EDIT 2: There's no way the bike would drain a healthy battery to 5.5v that fast, unless there was a ''huge'' short circuit and you'd noticed that already. I did 60 miles with no charging. Thumbs Up
mattyjohn93
PostPosted: 17:26 - 24 Apr 2014    Post subject: Reply with quote
Dropping to 5 is with nothing connected. I pulled it off to make sure it wasn't shorting on the bike. Still drops as soon as disconnected
Scotsman37
PostPosted: 10:31 - 26 Apr 2014    Post subject: Reply with quote
Duff battery it has been left for far to long depleted and therefore it ruined it, and if it's a sealed battery you need to buy a new one otherwise if its the older kind where you can open them up to refill try refreshing the cells with new battery fluid, as that may help it?
merquis00
PostPosted: 03:48 - 27 Apr 2014    Post subject: Reply with quote
this Thumbs Up
Just had the same problem with my Gilera, was sat for months and it killed the battery - would start of a boost pack and run without, but would not charge or start the bike on its own Surprised
like Scotsman37 said, take it to your local recycling centre/tip and buy another (assuming its sealed/non serviceable)
Current: 2010 WR125X, Carrera crossfire-E.
Project's: '88 GL1500 Trike, Chinese 170cc Monkey
Previous: X9-500, XT125, DNA125, CBF125, YZF-R125, '98 K1200RS, '99 St1100, fantic245
mattyjohn93
PostPosted: 14:20 - 07 May 2014    Post subject: Reply with quote
New battery should arrive today. Found a guide to checking the stator and rec but I recon these are fine as electrics work fine when running (allbeit bit dim on idle)
The last post was made 11 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 47.38 Kb
