Head Stock Bearings
FrankGill
PostPosted: 17:40 - 24 Apr 2014    Post subject: Head Stock Bearings Reply with quote
I think the head stock bearings on my KLE 500 need changing, is this an easy DIY job or best left to the experts ?
TUG
PostPosted: 18:10 - 24 Apr 2014    Post subject: Reply with quote
If you haven't done it before, I suggest watching a lot of how to videos. It's a bit of a shit job to do, it's time consuming and you need a grinder/blow torch to remove the old races from the stem.
I need to do mine soon, not looking forward to it either! Laughing
Haz ER-5, innit!
pepperami
PostPosted: 19:02 - 24 Apr 2014    Post subject: Reply with quote
It`s not that hard , it`s just a bit of a sod having to pull all the front end off to get at the headstock.
The ball race seats should come off without having to resort to a grinder?, mine always have.
I have always managed to get a little bit of leverage on/under them to push them off the stem.
PlusGas is your friend Thumbs Up as are some thin gash screwdrivers that you no longer want/need that you can use to try and get under the ball-race cup.
I have always found that it`s easier to replace them with taper roller bearings.
On my Superdream it was cheaper to replace with taper roller bearings than it was to replace with original Honda ball-bearings and new cup
TUG
PostPosted: 01:30 - 25 Apr 2014    Post subject: Reply with quote
Yea if you have heat at your disposal then it's much easier I don't though so cutting into them until they are weakened then persuading them off is the best option for me Laughing
Haz ER-5, innit!
CaNsA
PostPosted: 01:51 - 25 Apr 2014    Post subject: Reply with quote
pepperami wrote:
It's not that hard, it's just a complete ballache
EFA.
Ariel Badger
PostPosted: 20:41 - 25 Apr 2014    Post subject: Reply with quote
If the outer races will not come out run a bead of weld around them, it will contract and they drop out of the frame.
FrankGill
PostPosted: 13:37 - 27 Apr 2014    Post subject: Head set bearings Reply with quote
Thanks for your replies. Having read elsewhere now that changing to taper roller bearings that done properly will last a lifetime I thinks I'll get it done at a small bike garage I know.
The last post was made 12 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 56.19 Kb
