electrical problems :(
toddyhell
PostPosted: 18:38 - 25 Apr 2014    Post subject: electrical problems :( Reply with quote
Hi there help needed. I have a suzuki x5 200 and my battery is not getting charged when the headlight is on. It's ok when the park light is on battery charges when bike is revved but when you put headlight on voltage drops to 11.9v and won't increase with revs. Have disconnected both front and rear lights but fault still there. Have checked resistance of charge coils and they are as the manual says. Help!!!
Clutchy
PostPosted: 18:48 - 25 Apr 2014    Post subject: Reply with quote
How many volts do you get when revved to 4k with the lights off?
and then with the lights on...
davebike
PostPosted: 18:52 - 25 Apr 2014    Post subject: Reply with quote
I think most all X5 still had a mechanical regulator for the starter / generator
If so it may be the points in the regulator or the brushes / slip rings in the starter /generator itself
Not worked on an X5 for soooooo long
But saw the SB200 version a few years ago
Dave
Dave
NC750Xdct + others at work !
[email protected]
toddyhell
PostPosted: 19:16 - 25 Apr 2014    Post subject: Reply with quote
Hi there , yes the battery seems ok fully charged at 13.10v left for a week and still had 12.5volts. With the lights off and the bike reved I got about 14.5 volts but with the head light on I got about 11.9v and when reved it went down slightly.
toddyhell
PostPosted: 19:58 - 25 Apr 2014    Post subject: Reply with quote
Have cleaned up all earth connections on bike and electrics not to bad. Was thinking if it was charging without headlight on why would regulator be knackered? I thought if it was knackered it wouldn't charge whether lights were on or off.
moonzoomer
PostPosted: 20:18 - 25 Apr 2014    Post subject: Reply with quote
might help
https://i1142.photobucket.com/albums/n604/mawlarky/X7-X5-Wiring-Diagram_zps6733aba4.jpg
toddyhell
PostPosted: 20:27 - 25 Apr 2014    Post subject: Reply with quote
Thanks for the diagram. Certainly better in colour : )
The last post was made 12 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.12 - MySQL Queries: 13 - Page Size: 59.21 Kb
