Aprilia Rs 125 12K And 14K Rpm?
DEADmetal
PostPosted: 22:23 - 26 Apr 2014    Post subject: Aprilia Rs 125 12K And 14K Rpm? Reply with quote
Hello, i've noticed that some (newer) 2 stroke RS 125 have 12K max RPM readout and others have 14K max RPM readout. What does this difference mean? What RPM can these bikes rev to? Are powerbands different?
Scythe
PostPosted: 22:42 - 26 Apr 2014    Post subject: Re: Aprilia Rs 125 12K And 14K Rpm? Reply with quote
The bikes could have slightly different engines fitted dependent on age.
The 14k max would imply it has a red power band fitted for max power, the 12k max would suggest to be a yellow powerband, which is a detuned red band for reliability purposes.
2009 Yamaha YBR125 -> 2000 SV650S -> 2005 Kawasaki ZX6R 636
Az
PostPosted: 22:56 - 26 Apr 2014    Post subject: Reply with quote
As mentioned above, I believe different model RS125's had different colour power bands fitted.
If you wanted your bike to rev even higher than standard, go into your local dealer or mechanics and ask what colour power band you can fit to increase the power of your bike and it's RPM.
DEADmetal
PostPosted: 23:10 - 26 Apr 2014    Post subject: Reply with quote
Does it have anything to do with "fullpower"?
Scythe
PostPosted: 23:11 - 26 Apr 2014    Post subject: Reply with quote
Yes, yellow (12k) = restricted, red (14k) = full power. Just be careful in case a black power band is fitted, this is tuned beyond full power and can make the bike extremely difficult to control, even for experienced riders.
DEADmetal
PostPosted: 23:27 - 26 Apr 2014    Post subject: Reply with quote
Let me put it this way. All factory RS 125 are restricted, right? When properly derestricted, they are fitted with new tacho readout to match their new RPM limit, right?
What's with the black powerband btw? Higher level of derestriction?
Eddie Hitler
PostPosted: 23:40 - 26 Apr 2014    Post subject: Reply with quote
The black powerband simply allows more air through, along with a higher voltage to the spark plugs. Like Scythe mentioned, it's not recommended for inexperienced riders. Generally, the black powerband is used on the track when raced, not for the road.
Scythe
PostPosted: 00:31 - 27 Apr 2014    Post subject: Reply with quote
Not all, you can buy a RS125 de-restricted provided you have the adequate licence. It is usually a special request at the Aprilia dealers to specifically order a de-restricted model.
Eddie Hitler summarised the black powerband up quite nicely.
DEADmetal
PostPosted: 02:00 - 27 Apr 2014    Post subject: Reply with quote
Could you guys also give me a full list of altered / replaced parts in red and black powerbands (fullpower modes) in respect to yellow powerband (restricted version)?
Also, is the powervalve active in restricted version?
Scythe
PostPosted: 02:21 - 27 Apr 2014    Post subject: Reply with quote
I don't have much knowledge of what is undertaken to restrict these specific bikes, but usually it's the CDI unit and exhaust system. It could also have changes at the intake side in the airbox but I'm not sure about the RS125 specifically.
Powervalve will still be present, and you'll have to change the spark plug upon derestriction to either a red or black powerband. Red and black powerbands will also need an R&G air filter, R&G oil filter and a racing exhaust system such as Arrow fitted to maximise performance.
If you fit a red or black powerband without these mods, it will degrade into a blue powerband over time, leaving you with less power than you started with, but better fuel economy.
Shaft
PostPosted: 02:30 - 27 Apr 2014    Post subject: Reply with quote
https://i1235.photobucket.com/albums/ff426/zedheadchap/hA04965001.gif
DEADmetal
PostPosted: 05:52 - 27 Apr 2014    Post subject: Reply with quote
This is hardly related but what's the way to tell if the power valve is working? Does it "kick" the bike forward when accelerating at around 6k RPM?
speedy
PostPosted: 06:21 - 27 Apr 2014    Post subject: Reply with quote
It's like falling in love.. You'll know when you hit the power band Thumbs Up
On a more helpful note bike will sound better, have more power and will go faster
PostPosted: 12:07 - 27 Apr 2014    Post subject: Re: Aprilia Rs 125 12K And 14K Rpm? Reply with quote
Do you mean the end of the red line? Then no difference at all. They could mark the rev counter up to 20k, but it is the start of the red line that is important.
DEADmetal
PostPosted: 14:32 - 27 Apr 2014    Post subject: Re: Aprilia Rs 125 12K And 14K Rpm? Reply with quote
I mean this picture
https://i1127.photobucket.com/albums/l628/skully70-4/Aprilia%20SVX%20550/20130606_160814.jpg
And this picture
https://maximumjed.pwp.blueyonder.co.uk/images/Bikes/RS125/07.JPG
The redline isn't even marked. I have red that it has to do with CDI. Supposedly, Piaggio CDI bikes have 14K RPM reading. I don't even know what that means tho.
PostPosted: 20:23 - 27 Apr 2014    Post subject: Reply with quote
Probably just a cosmetic change when they did some retooling.
12k is a long way past peak power so no point revving anything like that high
The last post was made 12 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 93.09 Kb
