Best thread lock for air system
The Artist
PostPosted: 19:27 - 27 Apr 2014    Post subject: Best thread lock for air system Reply with quote
What would anyone recommend for sealing threads air tight.
Connections are things like 3mm plate with a 1/4 BSP hole and a 1/4" BSPT fitting screwed in.
Is normal locktite air tight? PTFE tape + locktite? This is single use so not going to be undone most likely.
Nexus Icon
PostPosted: 19:44 - 27 Apr 2014    Post subject: Reply with quote
https://www.henkelna.com/us/content_data/141299_LT5557_5452SSF448695.pdf
Ignore the US site. It's a list of loctite's pneumatic sealants.
Greetings from Shitsville!
The Artist
PostPosted: 20:03 - 27 Apr 2014    Post subject: Reply with quote
I have some 545 available so that will do then. Thumbs Up Karma
Islander
PostPosted: 20:15 - 27 Apr 2014    Post subject: Reply with quote
Don't be tempted to combine Loctite and PTFE tape though. PTFE is Teflon - it'll stop the Loctite from doing its job. Thumbs Up
janner_10
PostPosted: 20:32 - 27 Apr 2014    Post subject: Reply with quote
Just PTFE is fine - The whole air system at work is sealed with it and most fittings have been there for years - we don't use any form of threadlock with it - it just isn't required.
lukamon
PostPosted: 20:44 - 27 Apr 2014    Post subject: Reply with quote
indeed. threadlock not required. Thumbs Up
killa wrote: Im an ass man myself
Aff
PostPosted: 20:46 - 27 Apr 2014    Post subject: Reply with quote
As above, If you're using a BSPT fitting, just PTFE is fine, that's what its made for.
Electric Bike Project
Llama-Farmer
PostPosted: 21:05 - 27 Apr 2014    Post subject: Reply with quote
I've just used some PTFE tape that I found in the toolbox, seems to do the job on all my compressed air stuff, no problems up to 12 bar. Three times round the male thread, wound the correct way round so that it doesn't unravel as you screw male into female.
I did replace the "quick release" (chinese monkey metal non-standard fitting) connectors on my compressor and separate tank for some decent PCL connectors, and got PCL connectors on all the hoses and tools so I know the connectors are all good quality and will fit each other, most of the original connectors had terrible thread lock stuff which didn't seem to help seal it, just prevent the original connectors ever being removed without rounding them off with the spanner.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
PostPosted: 21:42 - 27 Apr 2014    Post subject: Reply with quote
As said, the taper thread ought to do it by itself.
PTFE tape is belt and braces.
I've fitted high and low pressure oxygen systems and we just used taper-thread brass fittings on them.
Ariel Badger
PostPosted: 22:32 - 27 Apr 2014    Post subject: Reply with quote
It depends very much if you need to ever take it apart again, if it is permanent use cotton and araldite.
janner_10
PostPosted: 04:40 - 28 Apr 2014    Post subject: Reply with quote
or boss and hemp if you want to be really old fashioned
Rncv
PostPosted: 11:42 - 01 May 2014    Post subject: Reply with quote
Just PTFE tape.
We use BSP fittings with PTFE tape on our HP compressors which are around 3-400Bar (4-6,000 PSI)
Make sure you put the tape on the right way Laughing
Current: 01' Bandit 600, 92' Goose 350
Previous: Lots!
The last post was made 12 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 72.9 Kb
