Puncture!
Charloam
PostPosted: 11:23 - 28 Apr 2014    Post subject: Puncture! Reply with quote
So I managed to get a slow puncture on my YBR, tubeless tyres.
As far as I can tell from the tyre, there are 2 spots where it looks particularly dodgy, the first image shows a hole which has a stone or something lodged inside it, the second is larger, but I can't make out anything inside it so maybe it hasn't gone all the way through.
I can pump up the tyre, and it stays reasonably inflated for a day or two. So from someone more knowledgeable with motorcycle punctures - is this repairable? Or do I need a new tyre?
I've seen youtube videos of people fixing their punctures with rubber 'strings':
https://www.youtube.com/watch?v=zaa5yIwyxpo
I'm not sure if that will work for me though, since my hole isn't quite so round...
https://i.imgur.com/iFHB9yx.jpg
https://i.imgur.com/qcgzM3m.jpg
doggone
PostPosted: 11:28 - 28 Apr 2014    Post subject: Reply with quote
You make the hole more regular with a supplied reaming tool in the repair kits, but agree a more slit-style hole could be a problem.
Have you checked for leaking from those spots with some soapy water?
A slow leak could be a bit of grit in the tyre bead or valve.
Scotsman37
PostPosted: 11:31 - 28 Apr 2014    Post subject: Reply with quote
Looks like a new tyre before your next MOT is due!!!!
From pics you've either gone over something like a piece of glass or slither of metal or the other possibility a neighbour doesn't like the sound of your bike at nights and stuck a knife into it?
You could use Tyre Weld till then which will seal the leak from within and re-inflate it for you, then run it for a few miles to heat the tyre up then it sets to seal to it, but you may need to recheck the pressure and pump at bit more air in it to correct pressure!
You can get it at Asda, and sometimes they have it on special offer or you could find it at any other store that stocks it nearby you?
I've went three months one time without having any problems with it after having a nail punctured my rear tyre!
Holts Tyre Weld it's capable re-inflating a car tyre from flat!
p.s. If you do use it as it fully re-inflates the tyre you will see some foamy stuff come out of the hole, and don't worry just wipe of the excess and wipe off the excess. Wait a little as it instructs then ride it for a few miles, recheck tyre pressure and add more air as necessary then you're done!
Sorry you'll no doubt need a new tyre just before next MOT, but at least the quick fix will keep you going for quite sometime until you can afford a replacement!
https://www.holtsauto.com/images/products/repair-and-maintenance/tyre-repair/holts-tyreweld-500ml-hi.jpg
Scotsman37
PostPosted: 11:39 - 28 Apr 2014    Post subject: Reply with quote
This one looks like it's got something stuck in it? Have you tried using long pliers to get in there and pull it out?
stirlinggaz
PostPosted: 11:45 - 28 Apr 2014    Post subject: Reply with quote
hi,
if you do go down the road of using some sort of gunk/slime as a temporary repair, remember to tell the tyre fitter/mechanic when you get round to replacing that tyre. (regardless of how long its been in there)
i've heard of some places refusing to replace tyres on wheels with that stuff, as seemingly its a bloody mess when you take the old tyre off.
on a side note, i used one of those products (wasnt tyre weld but something purple) + i used it for months + at m/way speeds.
so make sure you read the instructions as some are less temporary than others.
cheers,
GAZ
raesewell
PostPosted: 12:03 - 28 Apr 2014    Post subject: Reply with quote
Use Ride on
google it
Yamaha FJR 1300 Normanton West Yorkshire
Charloam
PostPosted: 13:01 - 28 Apr 2014    Post subject: Reply with quote
Just tested, it doesn't really look like they're leaking an awful lot to be honest, I pumped up the tyre to 60psi before I took this fairly boring video:
https://www.youtube.com/watch?v=cHIjKlreb4s
I also splashed some soapy water on the tyre valve and it didn't bubble either. It was on its centre stand at the time, had a look whilst it was on the side stand too and it didn't bubble either.
Note that I did ride the bike a couple of times anyway, and it survived the 40 minute jouney to hyde park, sat there for a few hours and got back home fine - that was last monday and when I checked the tyres again today they were not registering on my track pump (though they still a normal tyre shape).
Ah slime! that might be worth a go, the puncture seems to be small enough that slime would fill the gaps. Plus I doubt I'll be hanging onto the bike forever, I feel like it'll soon be time to do my test and get something a little meatier. I'd pull the grit from the tyre, but I don't have pliers handy.
Scotsman37
PostPosted: 13:22 - 28 Apr 2014    Post subject: Reply with quote
It may not pass the MOT with the current state it is in due to safety?
Sounds good that you're not registering any leaks but those are bad deep cuts, and it is wise of you to remove anything possibly sharp as it may get more pushed in over time....!
MOT checks for tyres and wheels on motorcycles are divided into just two sections. Please click one of the links below to skip to the section of interest.
tyres :: wheels
Tyres
Tyres must be of suitable type and in good repair
Tyres must be seated correctly in their rims
Tyres must be fitted in accordance with direction indicators on the sidewall
All tyres must be either cross ply or radial, not a mixture
Tread must be clearly visible over the whole tread area
Tread must be at least 1mm deep throughout the circumference and 75% of the width of the tyre*
Other reasons for your tyres failing the motorcycle MOT test
It shows a cut longer than 25mm or 10% of the section width of the tyre that reaches the ply or cord
It shows a bulge, lump or tear caused by partial failure of its structure
It fouls another component of the motorcycle
Ply or cord is exposed
The valve is seriously damaged or misaligned
The tread has been recut
https://mot.fasttrackmotorcycles.co.uk/81/motorcycle-mot-checks-tyres-wheels/
Charloam
PostPosted: 13:38 - 28 Apr 2014    Post subject: Reply with quote
Oh I'm not too worried about the MOT for a couple of reasons. It's not for another 10 months, and I still have the old rear tyre which is still technically legal to ride with anyway (it's just pretty low on tread).
I'm not planning on keeping it 10 months. Because as nice of a bike as it is, and as fuel efficient as it is, I've been using it as learning tool more than anything.
I haven't heard of using an inner tube to aid repair, I don't think I'll go down that route though since it's such a faff to remove put back a motorcycle tyre.
Bunny Lingus
PostPosted: 00:14 - 29 Apr 2014    Post subject: Reply with quote
Nowt wrong with sticking a tube in. I like those Michelin Pilot Sporty tubeless tyres but both my current rides have spoked wheels so I always use tubes. You're right though, it is an arsehole changing M/C tyres with tyre levers but there is a knack to it & it gets a lot easier once you've done a few. I do a bit of courier work so I carry a heavy duty tube with me & a bicycle pump. Only had to fix a puncture once at the roadside & it took me just over 45 minutes which ain't bad going considering it was raining.
Bunny Lingus & The Flipside Faggots
The last post was made 12 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.12 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 71.39 Kb
