1980's Honda H100 A Voltage problem
AzzA1990
PostPosted: 17:17 - 28 Apr 2014    Post subject: 1980's Honda H100 A Voltage problem Reply with quote
Hi i am new here so first of all let me start of by saying a big hello Very Happy
I have an old 1980's Honda H100 A that i have only just recently brought as a project i got it yesterday and i have got it running today i gave the carb a good clean and put fresh fuel in her and she fired up nicely and sounds sweet!
I am a little concerned about the voltage coming from the bike that's going into the battery it's a 6 volt system however when i put the volt meter on the battery when the engine is started but on idle the volt meter is only reading 4.6 volts? at first i thought it was the battery but now the voltage going into the battery is quite low it has to be something else right?
Now i believe this could be a number of things but i am hoping it's the Regulator/Rectifier so that is why i am on here asking for other peoples opinions
Thanks in advance!
smegballs
PostPosted: 17:51 - 28 Apr 2014    Post subject: Reply with quote
If the battery is old and shagged, it will pull down the voltage the big is trying to feed it hence the low reading. I imagine that the energy for the spark is magneto/cdi then if it runs with such low voltage?
Take the battery out, then put the voltmeter across where the battery would go (assuming the ignition is self generating) this should give you a good idea of what the actual bike is putting out charging voltage wise.
AzzA1990
PostPosted: 20:18 - 28 Apr 2014    Post subject: Reply with quote
Thanks for the reply
I have just done it without the battery in the bike and it's putting out exactly the same voltage as to when the battery was in the bike
Strange? if it's not the regulator/rectifier then it would be the stator plate and magneto I'm guessing?
smegballs
PostPosted: 20:22 - 28 Apr 2014    Post subject: Reply with quote
Can you post a wiring diagram for the bike?? Being a small 6 volter it probably has some perverse system of tapped lighting/charging coils along with dirty half wave rectification (at least thats what rxs100 has Wink ).
I'll go take a look to and see what I can find. Once I have a diagram I'll be able to suggest a logical test sequence to find the issue.
AzzA1990
PostPosted: 20:50 - 28 Apr 2014    Post subject: Reply with quote
I do have a haynes manual for the bike that has a wiring diagram I'll ry and upload a photo, i am no good when it comes to reading wiring diagrams Confused
I don't think this will be of any help until i get a clearer camera tomorrow but here goes Confused[/img]
A100man
PostPosted: 21:04 - 28 Apr 2014    Post subject: Re: 1980's Honda H100 A Voltage problem Reply with quote
I am a little concerned about the voltage coming from the bike that's going into the battery it's a 6 volt system however when i put the volt meter on the battery when the engine is started but on idle the volt meter is only reading 4.6 volts? ..
Does it increase when you rev it a bit ?
AzzA1990
PostPosted: 21:11 - 28 Apr 2014    Post subject: Re: 1980's Honda H100 A Voltage problem Reply with quote
It does but not by much i think it went from 4.6v to 4.8 but i was having to rev it quite high
smegballs
PostPosted: 21:28 - 28 Apr 2014    Post subject: Reply with quote
Okay then. Here's the first test. Locate the main connector from the stator to the loom. You might have a two connectors, one for the cdi wires and one for the charging/lighting wires. Or it might all be one connector.
Break the circuit where I've marked in red, and test between the generator side of the yellow and grey wires and ground with the multimeter set onto AC volts. See what the voltage is both at idle and with some revs.
I've drew a little diagram of what is the most likely arrangement inside the lighting/charging coil. One end of the coil is tied to earth, then halfway up the coil it is tapped off for charging purposes. When you turn the lights on, it switches in the rest of the coil to power the lights.
https://i.imgur.com/ZZ87Ttr.png
This test will show whether we are getting enough juice from the stator in the first place, You should probably see at least 10V AC with some revs on.
AzzA1990
PostPosted: 21:38 - 28 Apr 2014    Post subject: Reply with quote
Wow thanks a lot you have been a great help i really appreciate it
I will report back tomorrow after trying this! neighbours wouldn't be happy with me if i done it now Laughing
smegballs
PostPosted: 21:54 - 28 Apr 2014    Post subject: Reply with quote
No worries mate, auto-electrics probably my best area of tinkering. I've been teaching myself the electronics knowledge needed to build radio gear from scratch so by comparison auto-electricals are piece of piss!
Once thing to consider is that these 6v systems are marginal at best. The low voltage means that good connections are especially critical than on a 12V machine.
What is your intended outcome from this? These 6V bikes run their ignition system separate to the lights so getting them to run isn't an issue. How is your light output on the headlights? With my rxs, the charging system was shagged with an ancient battery. Despite wild fluctuations on a cold engine (discharged battery, nothing to do with engine warmth), after a few mins riding the battery has absorbed some semblance of charge so the indies flashed sort of acceptably.
The battery on these bikes typically only runs the indies, horn and rear/brake light. You could spend loads of time and money trying to get it to work to the normal standards of a 12V vehicle but IMO if you can get the instrumentation to work reasonable then that is a "win".
Protip: Attach one of those old stylee 6v lantern batteries (disconnect the charging wires) for the MOT and your indies will flash at the proper rate. Wink
smegballs
PostPosted: 22:14 - 28 Apr 2014    Post subject: Reply with quote
Another thing I suspect could be a problem is this "resistor" in the lower left corner. I have no idea if it is literally just a resistor or a poorly labelled AC regulator like what the RXS100 has. Either way it's job is clearly to try and limit voltage to keep bulbs blowing.
It occured to me that if it has failed in closed-circuit (or close to), it would present a big load to the stator and pull the voltage right down. Might be an idea to locate it and disconnect that pink wire and measure your voltages again.
If you can, try getting a focussed photo of the bottom of that page when you get access to a camera. It would make it a lot easier to diagnose Thumbs Up
https://i.imgur.com/gmNotx4.png
AzzA1990
PostPosted: 14:05 - 30 Apr 2014    Post subject: Reply with quote
Hi sorry it's been a while i tried what you said and i think i must have done it completely wrong because i couldn't get a reading from my multimeter i think the meter it's self is going up the creek too, I am waiting for a new one too arrive, i can confirm though all of the lights work but the indicators are a bit dull and not that bright but they get a bi brighter when i rev the engine obviously, i wanted to put some more modern looking indicators on the bike but i can't find any online that are for 6 volt bike?
I have come across another couple of problems too it's going a bit off topic but there is a very minor crack at the top of the float bowl on the carb it doesn't leak fuel but it could be taking in to much air and also the tube going from the air box to the carb doesn't actually sit over the carb it goes up against it and some numpty has put electrical tape around it to seal it, might explain why the bike want's to die when it's on idle
The idle screw it's as if it's not working very well, it's like problem after problem at the moment
The last post was made 12 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 78.66 Kb
