Theory test questions
djrikki
PostPosted: 09:39 - 29 Apr 2014    Post subject: Theory test questions Reply with quote
Hello.
Going for the theory test soon and been using one of the ipad apps to test myself.
After 15 years of car driving I know precisely, dick.
So studied the highway code cover to cover over the last 2 days and repeated the mock test questions.
All kinds of questions are popping up that are not mentioned anywhere in the highway code...
What problems would you get leaving the choke on your bike active
You need to top up your battery, so which level do you fill with water
etc.
Where do I find out all this kind of stuff. Pretty much aceing the normal road craft stuff, signs, what ifs, first aid etc just these ones are all new to me.
Thanks.
Rikki
PostPosted: 09:55 - 29 Apr 2014    Post subject: Reply with quote
If you cannot find the answers in the highway code then the best advice is to use the "safest" option.
You'll get a question like.
What would you do if a lorry was turning left in front of you and it had moved over to the right?
A. Overtake on the outside
B. Overtake on the inside
C. hold back and give the lorry plenty of room
D. Pull a wheely, flash your bollocks and wave
Always go for the safest seeming answer if you are in doubt so in this case it would obviously be D! Flash your bollocks.
recman
PostPosted: 10:03 - 29 Apr 2014    Post subject: Reply with quote
And don't forget to wave. Thumbs Up
Northern Monkey
PostPosted: 10:44 - 29 Apr 2014    Post subject: Reply with quote
The DSA pass your theory test book has all the answers to all the questions.
Scotsman37
PostPosted: 10:46 - 29 Apr 2014    Post subject: Reply with quote
The answer is found in the question!
dydey90
PostPosted: 10:55 - 29 Apr 2014    Post subject: Reply with quote
The way I passed both my theory tests was to illegally download buy one of those "pass your test" things for PC. The mock tests are the exact same questions and format as the actual test and the hazard perception practise is worth doing.
recman
PostPosted: 11:00 - 29 Apr 2014    Post subject: Reply with quote
Agreed, if only to learn how to 'play the game'.
djrikki
PostPosted: 11:12 - 29 Apr 2014    Post subject: Reply with quote
Where?
https://i.imgur.com/z1bWgTgl.jpg
PostPosted: 11:17 - 29 Apr 2014    Post subject: Reply with quote
djrikki wrote:
Where?
Most sensible answer, lets work it out together:
Answers in the wrong order first:
Just below the cell plates. ..... Hmm those cell plates do not work or conduct efficiently unless they are immersed in water.
Half way up the battery..... see above.
Top of the battery. What do vehicles do? Vibrate, roll around with innertia. Get yourself a glass full to the top of water and move it around, what happens? You get wet hands.
So just above the cell plates. That means the cells are going to perform at full capacity AND you have left a bit of room at the top to counter the natural movement of the vehicle.
djrikki
PostPosted: 11:22 - 29 Apr 2014    Post subject: Reply with quote
I got it right in the mock test by guessing but thats not ideal - plus theres other ones in there involving bike chokes and other stuff I've not encountered before. The instructor said everything is in the highway code book which is plainly bollocks as I've shown Very Happy
Was just wondering where the fountain of all knowledge is so Im best prepared ... rather than sit and blindly go through the 900 questions in the bank on the ipad getting some wrong and trying to remember the right answer lol
PostPosted: 11:26 - 29 Apr 2014    Post subject: Reply with quote
Don't look for any sense in it, it's a ridiculous test, particularly for bikes.
I was shown a tram sign and asked to identify the hazards posed to two wheeled vehicles by tram tracks the environmental benefits of that vehicle. Brick Wall
Must... not... rage quit.
You are sadly going to have to game your way through it by just rote-learning the bollocks in the practice tests.
Oh, and definitely learn how to play Hazard Perception Random Clickfest. You'll very likely click well before the arbitrary scoring zones. Thumbs Down
djrikki
PostPosted: 11:32 - 29 Apr 2014    Post subject: Reply with quote
Yeah Ive just been told to wait a second before clicking when I see something amiss or it might not recognise it.
The ipad app doesnt tell you much on what to do, I was tapping the screen where things were happening.
Load of balls
Scotsman37
PostPosted: 11:37 - 29 Apr 2014    Post subject: Reply with quote
•NORMAL: The normal fluid level is about 1/2 inch (1 cm) above the tops of the plates
The question is trying to tell if you have any basic vehicle maintenance knowledge about the vehicle!
Remember heat make things expand i.e. water will heat up while the battery is being recharged, and therefore you CANNOT fill the battery fluid to the brim!
map
Mr Calendar
PostPosted: 11:40 - 29 Apr 2014    Post subject: Reply with quote
I've found when looking through the questions for my lad if it's a tad confusing go for the common sense (or safest, as said above) option.
However, looking at some of his guesses I think common sense is in decline with the youth.
PostPosted: 11:55 - 29 Apr 2014    Post subject: Reply with quote
Thats why I said safest option not common sense. As it turns out, common sense is not that common after all.
Baffler186
PostPosted: 11:58 - 29 Apr 2014    Post subject: Re: Theory test questions Reply with quote
djrikki wrote:
Hello.
etc.
Thanks.
Rikki
What were the options for "what happens if you leave your choke on?" And what would your guess be?
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
map
Mr Calendar
PostPosted: 12:04 - 29 Apr 2014    Post subject: Reply with quote
pinkyfloyd wrote:
map wrote:
...However, looking at some of his guesses I think common sense is in decline with the youth.
That's why I said safest option not common sense. As it turns out, common sense is not that common after all.
Oh, I think you'd be shocked surprised at what he considers safe Shocked Wink
PostPosted: 14:15 - 29 Apr 2014    Post subject: Reply with quote
It's ancient history though. Even my Enfield has a sealed gel battery.
djrikki
PostPosted: 15:19 - 29 Apr 2014    Post subject: Reply with quote
Totally agree Roger, no questions about replacing the points and condenser on your car in the 4 wheels theory test.
evilbond
PostPosted: 20:45 - 29 Apr 2014    Post subject: Reply with quote
There was car specific questions in my bike theory test. Dafuq?
Bike: K2 Bandit 600S
Car: Astra GTC
djrikki
PostPosted: 21:32 - 29 Apr 2014    Post subject: Reply with quote
Latest belter from the question bank ...
https://i.imgur.com/U6BA2HJ.jpg
Grimeric
PostPosted: 21:46 - 29 Apr 2014    Post subject: Reply with quote
I downloaded the official theory test app on my iPhone and just spent a couple of days practising for ten minutes or so.
Keep doing mock tests and practising ones that you get wrong. If you spend enough time with the app then you will be confident that you can answer any question on test day correctly.
djrikki
PostPosted: 22:11 - 29 Apr 2014    Post subject: Reply with quote
Thats what Ive been doing the last few days fella - Ive now been through the entire question bank so repeating bits plus Ive screen captured questions I wasnt sure / got wrong to go over myself before test Smile
Grimeric
PostPosted: 22:14 - 29 Apr 2014    Post subject: Reply with quote
That was the best way for me to do it. I got them all correct with that technique. Although my bazaars perception side was a quick practice on some free online jobbies the day before. Still scraped through that part okay though.
Dave70
PostPosted: 00:08 - 30 Apr 2014    Post subject: Reply with quote
Another vote for this. Thumbs Up I used to browse through it in small chunks at a time while the adverts were on the tv and also had a couple of apps on my phone that I used to do on my breaks at work. Passed first time with only either one or two wrong answers.
Roger's right on some stupid questions you get. One that threw me was, What disability does a person have if their dog has a green harness? (Possibly not the identical wording). Got it right though.
The last post was made 12 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.24 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 129.62 Kb
