West midlands - Anyone fancy showing me how to change chain?
sharpenough23
PostPosted: 12:54 - 03 May 2014    Post subject: West midlands - Anyone fancy showing me how to change chain? Reply with quote
I have the chain, just don't have a clue what I'm doing.
£15 in it for you!!!!
nathan k
PostPosted: 14:11 - 03 May 2014    Post subject: Reply with quote
It's not hard mate, what bike do you have?
This might help https://www.youtube.com/watch?v=-lFFePQlVc4
Teflon-Mike
tl;dr
PostPosted: 14:22 - 03 May 2014    Post subject: Reply with quote
If its an SR125, it ought to be a split-link chain... do you have the split link?
If so, it ought be a two minute job, requiring little more than a pair of pliers.
If the bike is ridable, and you fancy pottering towards Coventry, I'm about all week-end faffing with my bikes...pm me and I'll pm you an address; happy to loan pliers and point at stuff for you while you have a crack at it.
Else, just make sire that the U end of the split link clip is towards the back wheel when its on the bottom run of the chain, pointing at the front wheel when on the top run, and is properly seated in the grooves.
Tristan.
PostPosted: 15:52 - 03 May 2014    Post subject: Reply with quote
If you bring it to Coventry I'm happy to, no need for monies
sharpenough23
PostPosted: 16:19 - 03 May 2014    Post subject: Reply with quote
In all honesty I don't know if it's a split link or not.
I probably could get it too Coventry just abit risky as whenever I Change down to 1st I can hear it bouncing around & Its on the last groove of the adjustment plate so I can't even bodge it .
Tristan.
PostPosted: 16:32 - 03 May 2014    Post subject: Reply with quote
It almost certainly will be a split link. Dint try to identify the chain on the bike. Look at your new one. The box will have a chain and a single extra link in bits
If that extra link is a plate with two pins attached and another plate with two holes it's meant to be riveted on. If it's a plate with two pins, a plate with two holes and a spring steel retainer plate with a slot most of the way through its a split link
Cut the old chain off, loop the new chain on, put in the half link with pins, put the plate on the ends of the pins then slide the retainer onto the grooves on the exposed ends. It should go most of the way by hand, then use pliers to pop it on the rest of the way. I would watch a YouTube video before though if your not confident.
The retainer plate should go so the the closed end will travel forwards.
PostPosted: 16:44 - 03 May 2014    Post subject: Reply with quote
https://www.msgroup.org/forums/mtt/images/chainlink.jpg
sharpenough23
PostPosted: 16:46 - 03 May 2014    Post subject: Reply with quote
Yeah that's the one, I need cut 2 links out of the new chain aswell, gonna be fun without the correct tools!
Andy9934
PostPosted: 17:47 - 03 May 2014    Post subject: Reply with quote
Aren't you supposed to change the sprockets at the same time?
PostPosted: 18:16 - 03 May 2014    Post subject: Reply with quote
A worn sprocket will wear the chain more rapidly but not essential to do so if the sprockets are still within reason.
All the bet
TheCatSatOnTh...
PostPosted: 21:23 - 03 May 2014    Post subject: Reply with quote
I understand what you're saying, but the sprockets aren't the expensive bit of the kit. Isn't it a bit of a false economy in; not changing the cheap bit at the expensive of wearing the expensive bit faster? Eh?
PostPosted: 21:36 - 03 May 2014    Post subject: Reply with quote
Depends on the bike. Large bikes certainly yes (ie, large bike where a C&S is say £80, of which £20 is the sprockets), but on a small bike the chain can be relatively cheap compared to the sprockets. Eg, my GSXR50 where a new cheap chain is £7.58 and a set of sprockets is £10.14, or the Aprilia AF1s where the rear sprocket is a bit odd and hence a pair of sprockets is close to the price of a chain (but the original sprockets are tough and will outlast a couple of chains).
i.p.phrealy
PostPosted: 23:06 - 03 May 2014    Post subject: Reply with quote
How I used to change my chain on my 125.
bike in neutral on centre stand.
moved split link to rear sprocket.
loosened rear axle, loosened chain adjusters (equally!)
pushed the wheel forwards.
removed split link and drop the bottom half of the chain onto the floor.
attach new chain to old chain, put the plate on, but not the split link.
pull the bottom chain gently so it passes through and over the front sprocket until it reaches the rear sprocket.
remove the old chain and bin it.
use the rear sprocket to hold both ends of the chain and push the link through from the back, put the front plate on, then the split link, making sure the closed end of the link is facing the direction of travel.
re-tension your chain, tighten the back wheel up, check it's all in line, add some oil.
go ride! Mr. Green
The last post was made 12 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.11 - MySQL Queries: 13 - Page Size: 83.99 Kb
