Cowboy Job!
DukeRed
PostPosted: 18:17 - 08 Jan 2005    Post subject: Cowboy Job! Reply with quote
I hate doing things to my bike when its been so neglected. Is this normal?? I have a nasty feeling that it isn't as in it shouldn't be welded.
I bought honda pattern wrench for the chain adjustment and it doesn't fu**ing work, think the adjuster has been screwed
https://predator.bikepics.com/pics/honda-nsr125-01-bikepics-270207.jpg
https://predator.bikepics.com/pics/honda-nsr125-01-bikepics-270208.jpg
I am so pissed off with this, I want a new bike Mad . ARgghHHhHh! <rant>
Jan
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
NickD
PostPosted: 18:19 - 08 Jan 2005    Post subject: Reply with quote
Hmmm.
Welded on sprocket........nice. Rolling Eyes
I was only doing what it said on my licence officer....
Tear along the dotted line!
Sparks!
Sir Tart-a-lot
PostPosted: 18:21 - 08 Jan 2005    Post subject: Reply with quote
WTF!!!!!!!!!! Laughing Unlucky Laughing
Weld the rear one on too, just for good measure Laughing
shellshock
PostPosted: 18:30 - 08 Jan 2005    Post subject: Reply with quote
OMG Thinking Nice welding though, think they'd come and do my bathroom pipes Question
DukeRed
PostPosted: 18:34 - 08 Jan 2005    Post subject: Reply with quote
Why would someone do this!? Why?
Could I just grind it off or shall I just buy a cg.
Minky_monkey
You're lucky he welded it, I would've used cable ties........
DukeRed
PostPosted: 18:36 - 08 Jan 2005    Post subject: Reply with quote
Couldn't he just of used a bolt like normal people. Evil or Very Mad Evil or Very Mad
NickD
Because the splines were knackered, and replacing the output shaft would be expensive....... Find whoever sold it to you, and hurt 'em. Twisted Evil
Minky_monkey
That's far too easy! Confused
PostPosted: 18:38 - 08 Jan 2005    Post subject: Reply with quote
Not that uncommon, but a horrible idea. Done normally when the splines on the shaft out of the gearbox are wrecked.
Only real fix is likely to be a complete engine rebuild to replace that shaft.
What bike is it?
Sparks!
Sir Tart-a-lot
PostPosted: 18:41 - 08 Jan 2005    Post subject: Reply with quote
Sounds expensive, unlucky mate.
DukeRed
PostPosted: 18:42 - 08 Jan 2005    Post subject: Reply with quote
Dave Bliss Motorcycles.
I advise all to not go there.
Unfriendly bad service is manageable but a crap bike from a dealer is not.
It's a Honda Bros
Jan
WildGoose
White Van Man
PostPosted: 22:28 - 08 Jan 2005    Post subject: Reply with quote
also bought a dud bros from a dodgy dealer
althought nothing that.....terminal, its not the kinda thing you would check on your average looking over the bike pre purchase really, but its pretty low
how do output shaft splines get fucked exactly?
[edit] just had a thought, seems like a perfect excuse to drop an africa twin engine in there mate Twisted Evil
PostPosted: 22:45 - 08 Jan 2005    Post subject: Reply with quote
Front sprocket coming off from not being secured properly. Happens with Yamahas where the large nut holding the front sprocket on comes loose.
DukeRed
PostPosted: 22:58 - 08 Jan 2005    Post subject: Reply with quote
I think I'll just try and recoup my losses and sell it back to him.
Like the idea of the africa twin but the workshop forum might get a tad overloaded. I think a bicycle till I get the funds for the CBR.
Jan
He sold it for 700 reckon I could sell it back for 200?
WildGoose
White Van Man
PostPosted: 23:30 - 08 Jan 2005    Post subject: Reply with quote
fuck making that loss mate, i'd be interested for 200 quid..
africa twin job, isnt as hard as you might think
https://www.d-murray.co.uk/severe.htm
its a simple engine
Robby
Dirty Old Man
PostPosted: 00:51 - 09 Jan 2005    Post subject: Reply with quote
That front sprocket has loads and loads of life left in it.
The rear hub probably needs taking apart and cleaning. Don't put in loads of lube on reassembly, but a squirt of WD40 should be ok.
Ride the bike for another 7000 miles and sell it before you come anywhere near needing to look at that sprocket. And screw the next owner, not your problem.
DukeRed
PostPosted: 01:15 - 09 Jan 2005    Post subject: Reply with quote
Yeah it's got life left in it but I can't adjust the chain because it appears to have seized/ the spanner doesn't fit cos the teeth have been worn down on the adjuster.
Cheers all, helped me alot.
Jan
WildGoose
White Van Man
PostPosted: 16:06 - 09 Jan 2005    Post subject: Reply with quote
never adjusted the chain once on the bros, the hub was also worn on mine, and i couldnt get a socket on the pinch bolt cos all my tools were too big
so i just dismissed it, as it was being difficult it obviously didnt want me to adjust its chain
dont reckon it suffered any adverse affects, its not as if the performance of a bros wrenches on the chain enough for you to notice that its really slack, i was never fussed anyway
you could probly adjust it using a copper drift pin and hammer, if you can find the right kind of size, or just grind it down to size, the idea being copper being softer than the hub material, with damage the drift pin rather than the hub
PostPosted: 16:19 - 09 Jan 2005    Post subject: Reply with quote
The sprocket looks OK for the moment. If you are keeping the bike, I would wait until it is worn out then grind the weld off and weld a new one on. You can probably do this indefinatley. It ain't pretty, but it is functional.
WildGoose
White Van Man
PostPosted: 16:23 - 09 Jan 2005    Post subject: Reply with quote
did a bit of research for you
gearbox output shaft is 74 quid from honda, which was less than i was expecting, will involve some gaskets as well i would imagine which can be expensive depending on what they are
the rear hub is 112 quid from honda inc bearings and seals, which is a bit more serious money
200 quid to put it right, is a lot considering what its worth but depends how long you want to keep it, unfortunately i spent 10 times that sorting my bros when i got it, became a bit of an obsession i think
DukeRed
PostPosted: 18:53 - 09 Jan 2005    Post subject: Reply with quote
Cheers for that, I'll get round to that once I've got the CBR for a winter hack.
Well went out today and bought a bicycle for 50 quid. Get healthy and get there quick. Now I can be the irritating bicyclist everyone bitches about, can't wait Razz .
Jan
The last post was made 21 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 116.08 Kb
