suzuki x5 200 coil problems
toddyhell
PostPosted: 17:54 - 03 May 2014    Post subject: suzuki x5 200 coil problems Reply with quote
Think I have narrowed my fault down but can't understand the results. With only the rec/reg , stator and battery in the circuit I connected the charge coils and lighting coils together an got no voltage out of the stator to my terminals. But when I do this individual for each coil I get voltage. Anybody any ideas. Running out of mine.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:12 - 03 May 2014    Post subject: Reply with quote
There are two coils to trigger the ignition on the stator on an X5, a slow speed one and a fast speed one. If one is fucked, it won't work.
Not sure what a 'lighting coil' is....
Triumph Sprint ST 1050
toddyhell
PostPosted: 19:29 - 03 May 2014    Post subject: Reply with quote
The bike starts fine that's not the problem. The lighting coil is the coil that comes into the charging system when the headlight is switched on. The problem I have is I can't get voltage to the reg/rec when I have both coils in the circuit but they are fine when tested separately, with voltage being generated. Help!!!
Nobby the Bastard
Harley Gaydar
PostPosted: 19:50 - 03 May 2014    Post subject: Reply with quote
A second coil that starts working when the lights are turned on?
Are you sure?
How does this coil know the lights are turned on to start supplying leccy?
Pretty sure that it has a ballast resistor instead.
smegballs
PostPosted: 19:54 - 03 May 2014    Post subject: Reply with quote
Are you sure?
Check the other thread where I mapped out the charging circuit for him. One coil goes all the way up to the headlight switchgear, then when you turn the lights on gets switched into the Regulator rectifier.
https://i.imgur.com/3HxAM1g.png
toddyhell
PostPosted: 20:15 - 03 May 2014    Post subject: Reply with quote
Any idea why the voltage would disappear when both coils are in the circuit.[/i][/b]
moonzoomer
PostPosted: 22:31 - 03 May 2014    Post subject: Reply with quote
I can only suggest that one of the diodes in the reg/rec pack has gone faulty
toddyhell
PostPosted: 06:39 - 04 May 2014    Post subject: Reply with quote
I have done this as someone suggested but can't get any voltage out of generator but if I separate the coils I get on both coils.
The last post was made 12 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 53.96 Kb
