Any double glazing fitters about?
PostPosted: 19:54 - 03 May 2014    Post subject: Any double glazing fitters about? Reply with quote
Had a bit of a problem with a window this evening - little did I know that someone had jammed a stick between the window and the frame so when I tried to close it the arm that moves in the runner has bent.
https://www.bikechatforums.com/files/photo_135.jpg
Now the problem is that I can't close the window. The runner is held onto the window frame by three screws, if I take this off I'd be able to close the window. However, if I do this is the window going to fall out?
Thanks
PostPosted: 19:55 - 03 May 2014    Post subject: Reply with quote
Sorry, the photo is 90 degrees out.
PostPosted: 20:08 - 03 May 2014    Post subject: Reply with quote
Seems to me that those screws are all that's holding the window to the frame. Maybe you could remove just the bent bit and have a go at straightening that? I have straightened one before after it got bent by someone fooling about.
PostPosted: 20:12 - 03 May 2014    Post subject: Reply with quote
That's what I was planning to do but was wondering if taking that runner out will put too much pressure on the remaining one and damage that side as well.
PostPosted: 20:56 - 03 May 2014    Post subject: Reply with quote
It will if you don't support the window.
PostPosted: 20:57 - 03 May 2014    Post subject: Reply with quote
Fair enough, thought as much, will give it a go, thanks for the pointers.
clancy
PostPosted: 23:55 - 03 May 2014    Post subject: Reply with quote
Keep hold of the bottom of the window, unscrew the hinge that's damaged and pull it shut and lock it. Then obviously don't open the window until you have a new hinge to go on. Once it's shut it won't go nowhere
You say about damaging the other one, as long as you hold the window leaf ad you unscrew the damaged hinge it will be fine. Just don't let go. The hinges will take a lot of bend before they are damaged though so don't be afraid to get a bit rough
Just so you don't get mugged off when replacing the hinge. . I charge £50 to supply and fit a pair of hinges. It's easy as shit to do though so just buy the hinge and fit it yoursel, screw it in the existing holes then you won't need to mess around lining the hinge up to get the window to shut
KLX 300r
defblade
PostPosted: 09:56 - 04 May 2014    Post subject: Reply with quote
Shocked
I first saw that birdbath as some sort of extractor vent coming out of a wall, with pebble-dash above it... looking harder, I can see that would mean someone had a brick "roof" below it, but isn't it weird how you see what you expect to see... (SMIDSY?)
Sorry, as you were...
The last post was made 12 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 55.97 Kb
