| DanceLikeAMon... |
 DanceLikeAMon... World Chat Champion
 Posted: 11:22 - 09 Jan 2005 Post subject: The eternal blackness of my oil! |
I was checking the oil level on my SR125 this morning, and all I could see through the window was blackness.
Assuming that there was a leak somewhere, I poured about 1/2 liter of oil in, ran the engine then checked again - still nothing but black!
With the enging running, I shone a torch in and had a look. This time I could make out some really dark, gritty looking fluiding floating past. It was above the level, so it didn't need the top up.
Is this just a really dirty oil filter / oil, or could it be something more serious has gotten in there?
I have emailed the guy I bought it from (Dodsi) to see when he last changed them, but is there something else I should be looking out for?
Cheers! |
| Flip |
 Flip Super Spammer
 Posted: 11:36 - 09 Jan 2005 Post subject: |
If it's gritty change it and filter. Don't forget, you only see the oil when the engine is warm  |
| DanceLikeAMon... |
| Kickstart |
 Kickstart The Oracle
| DanceLikeAMon... |
 Posted: 12:29 - 09 Jan 2005 Post subject: |
Accoring to Mr Haynes, it should be changed every 1000 km . Good job it only takes a litre of oil each time!
If the engine hadn't been running, I wouldn't have made out a thing, it was only because of the little gritty bits I could see moving that I knew there was anything in there! Even when using the torch I couldn't see anything.
I take it that the oil should be changed waaaay before it goes black? Otherwise it would get a bit tricky to view it in the window bitty. |
| dodsi |
 dodsi Dirty Carny
| Guest |
 Guest Brolly Dolly
| DanceLikeAMon... |
| Bomberman |
 Bomberman World Chat Champion
 Posted: 14:44 - 09 Jan 2005 Post subject: |
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 17:08 - 09 Jan 2005 Post subject: |
| Bomberman |
| Flip |
 Flip Super Spammer
 Posted: 18:18 - 09 Jan 2005 Post subject: |
@ ZXR61 or whatever the hell your name is. According to my Haynes for a Gixxer 750, you warm the bike to operating temp on a centre or paddock stand allow it to cool for a min before checking the oil. That'll be a warm engine. The same works on my ZXR400.
Wasn't saying the bike should be running  |
| tatters |
 tatters Exxon Valdez
 Posted: 18:29 - 09 Jan 2005 Post subject: |
warming the oil up for a few mins is for when you drain it, checking cold is best beacuse the oil has setled to the bottom of the sump ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Flip |
 Flip Super Spammer
 Posted: 18:39 - 09 Jan 2005 Post subject: |
Maybe I'm getting confused then. Haven't even seen my bike for nearly two months  |
| Flip |
 Flip Super Spammer
 Posted: 18:47 - 09 Jan 2005 Post subject: |
Just checked the Gixxer Haynes book and that what it says to do. So I'll carry on doing it  |
| Kickstart |
| DanceLikeAMon... |
 Posted: 19:47 - 09 Jan 2005 Post subject: |
According to my Yamaha manual, it is best to check the oil after running the engine for a few minutes, and it holds 1 litre of 10w/40w oil.
It's overfilled now so it has to be drained anyway. If the refill doesn't help, I will be back for more advice - you have been warned!
Cheers for the help everyone! |
| kasandrich |
 kasandrich Trackday Trickster
 Posted: 19:52 - 09 Jan 2005 Post subject: |
Black oil just means its dirty, so change it. a small engine with only a litre in it will dirty the oil quickly.  ____________________ Richard
CBR1000FM |
| mchaggis |
 mchaggis World Chat Champion
| kasandrich |
 Posted: 21:28 - 09 Jan 2005 Post subject: |
With a 4 stroke the oil is lubricating and cooling the engine and gearbox, and there will be some combustion gunk, (carbon etc) get past the piston and into the oil, with a 2 stroke the oil is only lubricating the gearbox and not subjected to the same dirt /crap.
Find a source that is reasonable priced and change it regularly.
I have heard of people using diesel as a flushing agent, by draining the old oil out, refilling with diesel instea of oil, running it around the bloke, then draining that, but I don't like the sound of it
But you can buy flushing agents you add to the old oil, drive for a bit and then drain, but you wouldn't need a whole can for a little bike. ____________________ Richard
CBR1000FM |
| Bomberman |
| Kickstart |
| pipnet11 |
 pipnet11 Brolly Dolly
 Posted: 23:58 - 09 Jan 2005 Post subject: |
| Quote: | I have heard of people using diesel as a flushing agent, by draining the old oil out, refilling with diesel instea of oil, running it around the bloke, then draining that, but I don't like the sound of it |
Yer seen people do this before. You can run the engine with it in as it is also quite a good lubricant, but only for a few mins. The Problem my mate had after doing it was that he had to fluch the diesel out with oil afterwards, so he had to use two lots of oil.
My GS125 oil got dirty very quickly. I changed the oil every 1500 miles and it hardly burned any unless i was canning it. I always changed the filter too, but the oil was always black again by 100 miles. I never had any problems with it, I have done over 6000 miles on it and the milage stands at a grand 52,502, however I have no idea how much was done to the engine before i got it.
It holds 1.2 litres of oil if its totaly empty, usually took 900CC to fill it to the full line. The suzuki manual says check the level window when the bike is cold. You can see why as just kicking it over 4-5 times makes the oil dissapear from the window. ____________________ I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves |
| Git |
 Git Brolly Dolly
 Posted: 10:14 - 10 Jan 2005 Post subject: |
Diesel is ace at flushing the shit out of the cases and the smell is fantastic , if I have ever run out of engine flush I use a dash of diesel, the amount depends on sump capacity so I usually end up leaving 3/4 of oil in there and just topping up 1/4 the volume with diesel.
If the engine is really that mucky do you really want to disturb all that muck inside the engine and risk blocking an oil way or similar?
I think flushing an engine is best done bit by bit, instead of adding shit loads of flushing agent and loosening all the muck that will get spread all over just add a small amount of the flush to the oil over a few oil changes and try and move it over time and not in one hit.
NB I have only ever used diesel to flush the cases on diesel engines, not sure I would do it on a petrol lump. |
| ZRX61 |
The last post was made 21 years, 7 days ago. Instead of replying here, would creating a new thread be more useful? |
