| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 22:36 - 11 May 2014 Post subject: Excessive chainring wear? |
Had new chain, sprocket and chainring put on the ZZR in Jan/Feb
Was adjusting the chain earlier and noticed that the chainring has worn unevenly, a bit like this:
https://i.stack.imgur.com/Bf7lx.jpg
I know it's a bicycle one, but it illustrates nicely.
I'll have to look in the morning and check if it's worn from being under power or from braking
When I brake hard, such as an emergency stop I sometimes hear and feel a noise that I'm convinced is the chain skipping, usually stopped by pulling the clutch in (was taught to wait until nearly stopped), but my chain is never far off the recommended tension so is it really skipping?
Is my chain not tight enough? I'm trying to avoid over tightening it.
I do use engine braking a lot as there are a number of steep hills in 30mph limits, lots of filtering and I'll often close the throttle coming off the motorway allowing the bike to slow on engine braking when I should perhaps be using the brakes.
More info in the morning  ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| stonesie |
 stonesie World Chat Champion
| Wonko The Sane |
 Posted: 23:02 - 11 May 2014 Post subject: |
as far as I am aware it's steel,
It's the rear sprocket, at the wheel.
I didn't order it, I asked a garage I trust to get a new chain and sprockets, he knows I commute all year round on the motorway and I presume ordered accordingly.
It's possible I've allowed the chain to run slack a little, the bike's been sat over the weekend before adjusting the chain so perhaps better to do it on an evening after the bike's been used but allowed to cool? Foreheads and hot exhausts don't mix anyway! ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
| trevor saxe-coburg-gotha |
 Posted: 04:43 - 12 May 2014 Post subject: |
Look at the raised burrs on the sides of the teeth, I never saw that before anywhere. I'd say that sprocket is made from the wrong material, some kind of gummy soft alloy instead of a tempered one. Totally inappropriate. ____________________ a.k.a 'Geri'
| davebike |
 davebike World Chat Champion
 Posted: 06:49 - 12 May 2014 Post subject: |
Looks like an alloy race sprocket to me good for at most a (very) few thousand miles this one is completely K***ed !
For life you NEED JT steel sprockets a good DID chain and in my view a scottoiler or with a motorway commute daily maintenance ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| Wonko The Sane |
 Posted: 09:10 - 12 May 2014 Post subject: |
The wear is not from engine braking,
I do about 40 miles a day often in the wet as it always seems to rain in Manchester
I try and lube the chain twice a week (Monday and Thursday) but not if it's raining.
I've possibly put off adjusting the chain now and then (again due to rain) normally done every other month / when I remember, the one on my bike isn't as bad as the photo I posted now that I've looked again.
I'll try and get a photo up at lunch ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
| Wonko The Sane |
 Posted: 10:11 - 12 May 2014 Post subject: |
I've been using a wax based lube (muck-off), only been adding as there didn't appear to be a build up to clean off. Been applying it just after getting home when the chain is warm.
Should I be cleaning it all off or just a quick clean to remove any excess?
Would you recommend a different lube?
I'd guess I've done a minimum of 3500 miles on it ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
| davebike |
 Posted: 10:47 - 12 May 2014 Post subject: |
I like scottoil but I am lazy
A conventional chain lub in my view is better than the wax type
I still think that is a alloy sprocket or you really miss out on the lub bit a lot
I would recommend using more not less lubricant if it is raining !
It tends to get washed off
You might get away with just a rear sprocket but I not do so
I think the lesson is lots of lub and don't use a alloy sprocket on a Road bike that dose miles ____________________ Dave
[email protected] |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| Wonko The Sane |
 Posted: 10:57 - 12 May 2014 Post subject: |
I've had an issue with fling that's nearly had me off the bike, thankfully nothing coming the other way.
Just to clarify, the picture at the top is not my actual sprocket,
Snoosnoo, do you get much fling with your method?
Think I've only adjusted my chain twice since fitting, not including yesterday
Might get a scotoiler for it tbh. ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
| DrSnoosnoo |
| Scotsman37 |
 Scotsman37 World Chat Champion
 Posted: 11:12 - 12 May 2014 Post subject: |
I wouldn't be surprised he ordered the economy one for your bike?
Economy– is the basic chain grade required for this model. It is best suited to light and general use and is the Minimum acceptable quality for the model.
Recommended– is a higher grade and is the most appropriate for the model taking all aspects of use into account. This is the reason why we produce this recommended kit
High Performance – is Super Strong for the model and is suitable for more extreme use including Track Days and Racing (where specified).
Here's a suppliers statement on those as noted above
https://www.biketorqueracing.co.uk/chains-sprockets/afam-chain-sprocket-kits |
| Wonko The Sane |
| DrSnoosnoo |
 Posted: 12:14 - 12 May 2014 Post subject: |
Fixed
https://oi58.tinypic.com/a4qwkw.jpg
Does look slightly worn! I'll have a look at mine when I get home as a comparison. ____________________ I'm Sam; Northern, Ginger, Lover
Did have: '95 ZZR600 '83 CG125 '97 ZZR1100 '15 Hypermotard 821 SP Do Have: '10 ZX10R |
 Posted: 12:45 - 12 May 2014 Post subject: |
No where near enough lube on that chain. If you're worried about fling, then worry about where you're going to land when the bike flings YOU off after that bad boy has snapped and locked up your wheel or knocked a lump out of your engine.
Use a proper chain grease, not that dry wax rubbish. Mine is usually smothered in grease and it's never caused me to slide or crash. ____________________ a.k.a 'Geri'
 Posted: 13:58 - 12 May 2014 Post subject: |
That would not pass muster at these barracks.  ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Mobylette Type 50 ---> Raleigh Grifter ---> Neval Minsk 125 |
| Wonko The Sane |
| iMark |
 iMark World Chat Champion
 Posted: 15:12 - 12 May 2014 Post subject: |
https://www.brandedbiker.co.uk/img/products/Silkolene_chain_lube_500ml.jpg
Proper chain lube that has solvents in it so it sprays on and seeps in to the gaps properly.. then the solvent evaporates leaving the lube behind nice n sticky! -- Solvent isnt the right word is it .. what ever the thing is called where it makes it watery but evaporates off leaving behind the proper sticky residue!
if your chain rollers appear shiny it's way too dry (unless you've just soaked it in lube of course!)... they should look dull when lubed properly. ____________________ K8 GSXR 1000
"G" : you got him to have a look at a forum which seems to have established a picture of an erect penis in a cat's mouth as it's mascot and thought he might consider it ok? |
 Posted: 15:16 - 12 May 2014 Post subject: |
I use rock oil at the moment. It's very snotty but it does a good job. ____________________ a.k.a 'Geri'
The last post was made 12 years, 190 days ago. Instead of replying here, would creating a new thread be more useful? |
