Excessive chainring wear?
Wonko The Sane
PostPosted: 22:36 - 11 May 2014    Post subject: Excessive chainring wear? Reply with quote
Had new chain, sprocket and chainring put on the ZZR in Jan/Feb
Was adjusting the chain earlier and noticed that the chainring has worn unevenly, a bit like this:
https://i.stack.imgur.com/Bf7lx.jpg
I know it's a bicycle one, but it illustrates nicely.
I'll have to look in the morning and check if it's worn from being under power or from braking
When I brake hard, such as an emergency stop I sometimes hear and feel a noise that I'm convinced is the chain skipping, usually stopped by pulling the clutch in (was taught to wait until nearly stopped), but my chain is never far off the recommended tension so is it really skipping?
Is my chain not tight enough? I'm trying to avoid over tightening it.
I do use engine braking a lot as there are a number of steep hills in 30mph limits, lots of filtering and I'll often close the throttle coming off the motorway allowing the bike to slow on engine braking when I should perhaps be using the brakes.
More info in the morning Smile
stonesie
PostPosted: 22:52 - 11 May 2014    Post subject: Reply with quote
"Chain, sprocket and chainring"
What do you mean by chainring? Rear sprocket? Did you have a fancy alloy one fitted because on the road those can get destroyed as if made of cheese (cheap ones especially) and winter riding will only add to wear with all the salt dust and wet weather.
I usually fit AFAM steel sprockets and they last well, using engine braking shouldn't cause excessive wear as there's only a fraction of the energy going through the chain/sprockets as there is on hard acceleration.
Wonko The Sane
PostPosted: 23:02 - 11 May 2014    Post subject: Reply with quote
as far as I am aware it's steel,
It's the rear sprocket, at the wheel.
I didn't order it, I asked a garage I trust to get a new chain and sprockets, he knows I commute all year round on the motorway and I presume ordered accordingly.
It's possible I've allowed the chain to run slack a little, the bike's been sat over the weekend before adjusting the chain so perhaps better to do it on an evening after the bike's been used but allowed to cool? Foreheads and hot exhausts don't mix anyway!
PostPosted: 23:09 - 11 May 2014    Post subject: Reply with quote
If as worn as the one in your picture it is knackered. However it should last quite a while, so how many miles have you done since it was fitted?
I would second the possible wear with an alloy sprocket. Might be worth using a magnet to check if it is steel or not.
trevor saxe-coburg-gotha
PostPosted: 03:44 - 12 May 2014    Post subject: Reply with quote
Op - three questions: how often do you ride in the wet (I'm assuming regularly if you're a commuter)? How often do you clean and lubricate the chain? And what lube do you use?
PostPosted: 04:43 - 12 May 2014    Post subject: Reply with quote
Look at the raised burrs on the sides of the teeth, I never saw that before anywhere. I'd say that sprocket is made from the wrong material, some kind of gummy soft alloy instead of a tempered one. Totally inappropriate.
PostPosted: 05:07 - 12 May 2014    Post subject: Reply with quote
Pete. wrote:
I'd say that sprocket is made from the wrong material, some kind of gummy soft alloy.
I was thinking brie.
davebike
PostPosted: 06:49 - 12 May 2014    Post subject: Reply with quote
Looks like an alloy race sprocket to me good for at most a (very) few thousand miles this one is completely K***ed !
For life you NEED JT steel sprockets a good DID chain and in my view a scottoiler or with a motorway commute daily maintenance
Dave
NC750Xdct + others at work !
[email protected]
PostPosted: 07:55 - 12 May 2014    Post subject: Reply with quote
Afaict that is NOT the OP's sprocket, nor even a motorbike sprocket.
Wonko The Sane
PostPosted: 09:10 - 12 May 2014    Post subject: Reply with quote
The wear is not from engine braking,
I do about 40 miles a day often in the wet as it always seems to rain in Manchester
I try and lube the chain twice a week (Monday and Thursday) but not if it's raining.
I've possibly put off adjusting the chain now and then (again due to rain) normally done every other month / when I remember, the one on my bike isn't as bad as the photo I posted now that I've looked again.
I'll try and get a photo up at lunch
PostPosted: 09:18 - 12 May 2014    Post subject: Reply with quote
So how many miles have you done on the chain/sprox?
Regardless, I'll go out on a limb and say yours is not abnormal wear... unless you clean and EP90 it every day. Doesn't have to be a more than a literally 2 minute job - spray w/ paraffin / diesel / petrol - wipe off with clean rag (kitchen roll or bog roll is actually preferable imo), repeat thrice, then squirt the thick stuff on - can be liberal imo.
Wonko The Sane
PostPosted: 10:11 - 12 May 2014    Post subject: Reply with quote
I've been using a wax based lube (muck-off), only been adding as there didn't appear to be a build up to clean off. Been applying it just after getting home when the chain is warm.
Should I be cleaning it all off or just a quick clean to remove any excess?
Would you recommend a different lube?
I'd guess I've done a minimum of 3500 miles on it
PostPosted: 10:25 - 12 May 2014    Post subject: Reply with quote
Well, with the caveat that I know jack shit compared to many here, I'll just say that imo a lot of the owners of chain-driven bikes seem very neglectful of their chains. For, although I don't see many particularly rusty ones, I do see a fuck load of dry, dull ones. Personally, I want to see a quite shiny, very clean, oily moist chain on me own bikes - not some parched matt finish affair that looks utterly starved of any liquid that's going to help keep sprockets in good shape, not to mention all those links and rollers on the chain itself. And so for me it can only be EP90 or similar.
davebike
PostPosted: 10:47 - 12 May 2014    Post subject: Reply with quote
I like scottoil but I am lazy
A conventional chain lub in my view is better than the wax type
I still think that is a alloy sprocket or you really miss out on the lub bit a lot
I would recommend using more not less lubricant if it is raining !
It tends to get washed off
You might get away with just a rear sprocket but I not do so
I think the lesson is lots of lub and don't use a alloy sprocket on a Road bike that dose miles
Dave
[email protected]
DrSnoosnoo
PostPosted: 10:49 - 12 May 2014    Post subject: Reply with quote
I don't do too many miles on mine.
Done about 3k miles since I did my chain and sprox. Started lubing with the wax stuff then when that ran out, I've been using 10w40 oil with an old toothbrush. Give it a good apply and brush it in.
Then if any starts dripping I'll catch it in an old rag.
My sprockets look to be doing ok and I haven't had to change the chain tension in about 1.5k miles.
Wonko The Sane
PostPosted: 10:57 - 12 May 2014    Post subject: Reply with quote
I've had an issue with fling that's nearly had me off the bike, thankfully nothing coming the other way.
Just to clarify, the picture at the top is not my actual sprocket,
Snoosnoo, do you get much fling with your method?
Think I've only adjusted my chain twice since fitting, not including yesterday
Might get a scotoiler for it tbh.
DrSnoosnoo
PostPosted: 11:01 - 12 May 2014    Post subject: Reply with quote
Tbh I don't really think there's any issue. I get it on while the chain is warm (After a run) and wipe the toothbrush around the chain and then spin the back wheel by hand a few times to run it all in.
Any brig drips I'll catch but last night there were no big drips. Think my rear rim must get some build up but never noticeable.
It's all a personal preference in the end. I liked wax at first for ease but it starts to cake on and I didn't like it in the end. The oiling method looks cleaner and I'll use more oil and more scrubbing to try clean it if it looks dirty.
Scotsman37
PostPosted: 11:12 - 12 May 2014    Post subject: Reply with quote
I wouldn't be surprised he ordered the economy one for your bike?
Economy– is the basic chain grade required for this model. It is best suited to light and general use and is the Minimum acceptable quality for the model.
Recommended– is a higher grade and is the most appropriate for the model taking all aspects of use into account. This is the reason why we produce this recommended kit
High Performance – is Super Strong for the model and is suitable for more extreme use including Track Days and Racing (where specified).
Here's a suppliers statement on those as noted above
https://www.biketorqueracing.co.uk/chains-sprockets/afam-chain-sprocket-kits
Wonko The Sane
PostPosted: 11:46 - 12 May 2014    Post subject: Reply with quote
Http://tinypic.com/r/a4qwkw/8
It doesn't look as bad as yesterday!
It's certainly worn a bit and as it has only been on a few months I wasn't expecting to see any noticeable wear.
Sorry for photo being wrong way round, the uploader turned it, I'm using my phone to post.
DrSnoosnoo
PostPosted: 12:14 - 12 May 2014    Post subject: Reply with quote
Fixed
https://oi58.tinypic.com/a4qwkw.jpg
Does look slightly worn! I'll have a look at mine when I get home as a comparison.
PostPosted: 12:45 - 12 May 2014    Post subject: Reply with quote
No where near enough lube on that chain. If you're worried about fling, then worry about where you're going to land when the bike flings YOU off after that bad boy has snapped and locked up your wheel or knocked a lump out of your engine.
Use a proper chain grease, not that dry wax rubbish. Mine is usually smothered in grease and it's never caused me to slide or crash.
PostPosted: 13:58 - 12 May 2014    Post subject: Reply with quote
snoosnoo wrote:
Fixed
That would not pass muster at these barracks. Laughing
Wonko The Sane
PostPosted: 14:12 - 12 May 2014    Post subject: Reply with quote
Care to recommend a specific product?
iMark
PostPosted: 15:12 - 12 May 2014    Post subject: Reply with quote
https://www.brandedbiker.co.uk/img/products/Silkolene_chain_lube_500ml.jpg
Proper chain lube that has solvents in it so it sprays on and seeps in to the gaps properly.. then the solvent evaporates leaving the lube behind nice n sticky! -- Solvent isnt the right word is it Thinking .. what ever the thing is called where it makes it watery but evaporates off leaving behind the proper sticky residue!
if your chain rollers appear shiny it's way too dry (unless you've just soaked it in lube of course!)... they should look dull when lubed properly.
K8 GSXR 1000
PostPosted: 15:16 - 12 May 2014    Post subject: Reply with quote
I use rock oil at the moment. It's very snotty but it does a good job.
The last post was made 12 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 134.05 Kb
