CBR125 Issue
Radds
PostPosted: 14:52 - 13 May 2014    Post subject: CBR125 Issue Reply with quote
Hi Guys, ive been working on a CBR 125 fuel injected model and can not sort the main problem.
It starts and runs well, but if i do not keep revving the engine it will die. it will tick over then the revs go up and it dies.
It does have an after market stainless exhaust fitted.
Any ideas??
Cheers.
davebike
PostPosted: 07:42 - 14 May 2014    Post subject: Reply with quote
Fuelling !
need a dyno run or at least a Wide band fuel air meter and a good test run then Power commander to sort fueling for the exhaust
Dave
NC750Xdct + others at work !
davebike1@gmail.com
Radds
PostPosted: 09:21 - 14 May 2014    Post subject: Reply with quote
davebike wrote:
Fuelling !
Thanks. With that said, would it make sense to fit a standard pipe?
Nexus Icon
PostPosted: 12:39 - 14 May 2014    Post subject: Reply with quote
Yes. There's not much to gain, power wise, from tricking out a 4T 125 with an exhaust and new FI controller so it'd be cheaper to return to a standard pipe and take it from there.
If it then doesn't run properly you might have another issue. If you start pissing about with power commanders, etc. you're gonna spend huge amounts of £££ and, if there's an underlying issue, it still won't run right.
Greetings from Shitsville!
Radds
PostPosted: 14:50 - 08 Jun 2014    Post subject: Reply with quote
So to date I have changed the injector, the fuel pump and now put a standard exhaust on it, but the problem persists.
When I first start it, it starts straight away and then ticks over, but only for 5-10 secs then it dies. It does restart but not as easy. Once running I need to keep the revs up or it dies. If I try riding it it's sluggish and then dies. If I slip the clutch it runs a bit longer but with little power.
The FI light throughout is not on.
Any ideas?
Cheers Guys.
Copycat73
PostPosted: 16:55 - 08 Jun 2014    Post subject: Reply with quote
does a CBR 125 have a fuel filter ?
this is one from an R1 its inside the fuel pump.. it was full of crap when I pulled it out.
https://i867.photobucket.com/albums/ab232/copycat73/24k%20Service%2014th%20jan%202013/Photo0955_zpsea1a7ba3.jpg
caveat emptor
The last post was made 11 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 15 - Page Size: 47.48 Kb
