| Frostdog |
 Frostdog Nova Slayer
| map |
 map Mr Calendar
| Az |
 Az World Chat Champion
| Frostdog |
| clancy |
 clancy World Chat Champion
| Frostdog |
| tbourner |
 tbourner World Chat Champion
 Posted: 16:05 - 14 May 2014 Post subject: |
I believe that in the wet the issue of lifting off / braking / clutch-in when cornering is far more dangerous than it is in the dry, so you DO need to be confident in the wet and trust the tyres - just obviously don't be a plank and go flat out.
You can't do the same things you do in the dry but you can do more than you think.
Having said that; I have no experience so don't trust my judgement I do remember coming back soaking wet from my MOD2 ride and suddenly realising that I hadn't actually worried about the rain at all!  ____________________ Trev, now a biker?
Looking for first big bike. |
| Frostdog |
 Posted: 16:13 - 14 May 2014 Post subject: |
Yeah it was wet throughout my mod 1 and mod 2 and i never gave it a passing thought, more on my mind I guess!
Just recently, since getting my new bike a few doubts crept in thought I'd ask.
Had a baptism of fire, did exactly what you should not do, bought bike from a guy in kirkcaldy a couple hours away, got a lift down from him and left there at ten pm, first time on it, navigating my way home in the freezing cold unfamiliar big bike, took wrong road, pissing rain, first time riding at night blah blah blah!!
3 hours later made it home, wife going mental worried sick, survived it tho 😜 ____________________ YBR 125, Bandit 600, Er6N, Honda CB400 Super Four |
| Monkeypony |
 Monkeypony World Chat Champion
| thx1138 |
 thx1138 World Chat Champion
| Frostdog |
| barrkel |
 barrkel World Chat Champion
 Posted: 17:20 - 14 May 2014 Post subject: |
My riding changes completely in the wet.
| clancy wrote: | Other than that there's not a huge amount to worry about, don't worry about cornering at all, even at speed. As long as your smooth, the tyres will still far out perform you. |
This is not necessarily true, especially in urban areas, or places where there has been diesel spilled (e.g. near petrol stations).
I've lost traction on both tyres, almost straight up, constant throttle, on a wet country road with apparently good clean surface. Only momentarily, but a scary moment; the bike drifted to the side.
I've had a fishtail moment on a roundabout near a petrol station - very little acceleration prompted it.
I've had a lowside from a manhole hidden under a pothole when I was pulling out of a junction. Gentle enough acceleration, gentle enough lean, but it was too much.
I've had a (small) high-side pulling out of a junction, tar banding combined with a little bit of diesel / road crap and the rear swung right around, then found grip and slammed me hard into the road.
I've lost count of the number of times the rear has lost a bit of traction turning into junctions in the wet. Doesn't phase me much these days, I have the rear brake on to minimize drive line lash and I don't do anything sudden.
I've started an unintended burnout on my scooter at a traffic light - I pulled up my legs, turned up the throttle ever so slightly too much and went nowhere. This is a bike that is putting out about 22hp or so at the wheel.
I've drifted sideways while braking with both wheels, but stayed upright due to ABS.
In the wet, I don't do anything suddenly or swervy. I still lean a bit if I'm confident in the road surface, but I don't do anything quickly or jerkily.
When overtaking, I pull out before applying throttle. I try to be straight up when accelerating or braking. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| Scotsman37 |
 Scotsman37 World Chat Champion
| thx1138 |
 Posted: 18:13 - 14 May 2014 Post subject: |
That's several things. You said it was the only thing.  |
| Scotsman37 |
 Posted: 18:16 - 14 May 2014 Post subject: |
| Clanger |
 Clanger Stirrer
 Posted: 19:17 - 14 May 2014 Post subject: |
If its been dry for a long time, then it drizzles, I do take it easy - and take extra care on roads / roundabouts where large vehicles might have lost a bit of diesel.
I watch out for and avoid manhole covers (especially on roundabouts / corners) if possible. Use the back brake more. Keep a bit of distance between myself and other traffic.
It will become easier and more like second nature in time. Don't tense up and also don't beat yourself up if you find yourself making mistakes... you're only human.  ____________________ Be who you are and say what you feel, because those who mind don't matter, and those who matter won't mind - Dr. Seuss |
| Clutchy |
 Clutchy World Chat Champion
 Posted: 19:25 - 14 May 2014 Post subject: |
Had a fair few back end wiggles when really pushing in the wet if you drop down a gear into say 6k rpm. SO potentially bear that in mind
But I don't often go fast in the wet  ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| sabian92 |
 sabian92 World Chat Champion
 Posted: 19:30 - 14 May 2014 Post subject: |
The only time I rode in the proper pissing down rain I binned it on Halfords car park (which has the lowest grip asphalt known to man, apparently). People saw, pretty mortifying
Now I brake loads earlier and avoid white lines  |
| Frostdog |
Good advice from everyone, cheers. I had a good dry ride home but sure it won't be long to put it all into practice 😁
I got a way with a lot more on 125, gear wise, which I could be smoother with now, working on it now tho. Main thing was I was going down through gears, instead of just clutch in, going down a few that way, I can't remember what it's called, doing it now tho and becoming more natural ____________________ YBR 125, Bandit 600, Er6N, Honda CB400 Super Four |
| Az |
| sidewinder |
 sidewinder World Chat Champion
 Posted: 19:37 - 14 May 2014 Post subject: |
I was told " if it looks slippy it probably is "  |
| Llama-Farmer |
 Llama-Farmer World Chat Champion
 Posted: 20:53 - 14 May 2014 Post subject: |
A tyre will provide vast amounts more grip on the lean than you realise in the wet.
The fact is, the acceleration force during a turn pushes the tyre into the tarmac, providing more grip than keeping the bike upright.
That isn't to say you should go trying to get your knee down when going round town in the rain.
The key is to be smooth with everything.
Smoothly and softly apply the front brakes, that'll load the front suspension which in turn will increase the grip on the front tyre.
Then you can apply even more braking force. Do it right (i.e. smoothly and progressively) and you can easily stoppie in the wet, it's when snatching the brakes or applying them too quickly when the bike is leant over that causes problems.
According to multiple different sources of statistics, diesel spills account for far less accidents than we may like to believe. Diesel spills mean it wasn't our fault right?!
Well the truth is that most of the time it is our fault, and diesel played no part.
Avoid metal drains where possible as they are like ice when wet, particularly around where I live they seem to be mid cross-junction as you're turning and accelerating after pulling out the side roads, so with lean angle and acceleration you're much more likely to encounter problems.
The biggest problem I've found is whilst you are advised to use more rear brake in the wet, the rear brake becomes less effective in the wet relative to the dry, than the front does. So instead of 80/20 or 70/30 F/R in the dry, it's more like 50/50 that you're advised to use. But with the weight shift forwards under deceleration, the rear becomes light and the back tyre can lock up much more easily. Not so bad as the front locking up, but unless you're anticipating it, can make life a bit more difficult. ____________________ Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R |
| MC |
 MC Banned
 Posted: 21:43 - 14 May 2014 Post subject: |
Felt the same thing when going to a big bike. For some reason the grip difference felt less between wet & dry on my 125 than with a big bike. Dunno if knobbly tyres had something to do with it, but with the added weight on a big bike it seems to make the front end more nervous. ____________________ Yamaha MT-03 '08 (crashed)
Honda XR-125L '04 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 22:38 - 14 May 2014 Post subject: |
First, to deny the oft suggested presumption more tyre = more grip... it doesn't. Actually often the opposite, especially in the wet.
A tyre's 'grip' the amount of lateral force they can transmit through friction depends on two things;
1/ the co-efficient of friction between the material of the tyre, and the material of the road.
2/ The clamping force pushing the two materials together... ie the weight on the rubber.
Tyre width, tyre contact patch area, doesn't really come into the equation.
Where it does come into the equation is in the wet, where the more rubber you have in contact with the road, more water you need to shift out of the way for rubber to grip tar.
Otherwise... wet road riding oughtn't be much if any different to dry road riding.... if it IS... you are either over-confident in the dry, or under-confident in the wet... and niether is good.
Look at Race-Bike lap times for wet and dry races; they are NOT hugely different; Mallory is about a mile long, and pretty much all corners, and for years was ball-park a 60mph circuit, or a minute a lap. Difference for wet and dry? Maybe +/- two or three seconds 1/20th or 5% difference in 'The limit'.
If you are riding THAT close to the ragged edge on the road? Wont be long before you cross it, will it?
Road bike, road tyres, Swift and smooth; wet OR dry, with sufficient margin for error that WHATEVER hazards are chucked your way... you have grip to spare to try avoiding them.
Rain or shine, ought make little odds.... think about it.... if you are backing off either the throttle or following distance 'cos its raining... rather than worrying about the rain, you should be worrying about the shine, and asking whether REALLY you ought to be 'backing off' there.
Stats show more accidents happen in close to 'ideal' conditions as do in less than ideal ones.... more fair weather riders do go out to play then, but this bizare 'risk compensation' also plays a large part.
So if you feel the need to change how you ride when its wet... change how you ride in the dry, to more like you ride in the wet, and ride like that rain or shine! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| blade023 |
 blade023 Trackday Trickster
The last post was made 12 years, 123 days ago. Instead of replying here, would creating a new thread be more useful? |
