Tubed tire replacement
Ottocle
PostPosted: 23:41 - 17 May 2014    Post subject: Tubed tire replacement Reply with quote
My wheels are spoked so I have bought new tyres, tubs and rim strip.
How much should my garage charge for their labour?
Teflon-Mike
tl;dr
PostPosted: 23:48 - 17 May 2014    Post subject: Re: Tubed tire replacement Reply with quote
Nothing.
You should do it Yourself.
Come on, its just a big push-bike tyre. Get a pair of levers and some rim protectors of e-bay for under a tenner; and have them done in less time than it would ride to a garage, have mechanic scratch his beard, and tap your details into his computer!
AND you'll have tools to do it next time, and or fix a puncture should you unfortunately have one.
Instructions, if needed are in the Haynes manual or widely on the web.
Give it a go.
Ottocle
PostPosted: 00:02 - 18 May 2014    Post subject: Reply with quote
You make it sound so easy! Would like to self service. Will look into it. Thanks.
PostPosted: 01:10 - 18 May 2014    Post subject: Reply with quote
Jesus is my personal lord and rim protector.
sidewinder
PostPosted: 17:44 - 18 May 2014    Post subject: Reply with quote
Get some lube like washing up liquid on the tyre to.helps ease it on Thumbs Up
smegballs
PostPosted: 18:34 - 18 May 2014    Post subject: Reply with quote
After fucking about with horrible cheap tyre levers, that literally had sharp edges. I just manned up and bought a pair of lovely well made ones for a tenner each these ones actually have a smooth finish and radiussed edges to avoid ripping shit. Funnily enough my last tyre change was painless with no cut inner tube.
slowlydoesit
PostPosted: 20:19 - 18 May 2014    Post subject: Reply with quote
Do you remember what it was you bought? I'm considering changing my own tyres soon, not without a slight sense of dread.
Kawasaki KMX200 with broken fixed powervalves and a stutter
Teflon-Mike
tl;dr
PostPosted: 20:49 - 18 May 2014    Post subject: Reply with quote
Is worth the mention; get 'good' tyre levers for a bike; weedy push-bike ones often bend and buckle trying to get a push-bike tyre off!
AND... apologies... looking at e-bay, you might struggle to get a set for a tenner.... maybe £15ish, but still not talking daft amounts of money, and as said, worth having; sods law says when you need a puncture fixed shops'll all be shut!
Been a while since I bought a tyre lever... but last one I did, was like this:-
https://i.ebayimg.com/t/New-Extra-Long-370MM-Tyre-Tire-Lever-Curved-Motorcycle-Motorbike-Enduro-KTM-sxf-/00/s/MzAxWDUwMA==/$T2eC16ZHJHwE9n8ii1i(BQIn(4HJpg~~60_12.JPG
https://www.ebay.co.uk/itm/New-Extra-Long-370MM-Tyre-Tire-Lever-Curved-Motorcycle-Motorbike-Enduro-KTM-sxf-/191148032543?pt=UK_Motorcycle_Parts&hash=item2c814f821f
Which is a tenner on its own, from there, and you would need two.
It has rather small 'pry' ends that are nice and easy to wiggle under the bead, while its long so you get lots of leverage, and the bowed end gives you a couple of extra chances to work around disc brakes or sprockets and stuff. Mine sees a lot of use... rarely for taking tyres on and off though! Wonderful for wiggling stubborn stuff into or out of place, like exhausts or engines and 'stuff'.
These are the rim protectors:
https://i.ebayimg.com/t/3-ALLOY-WHEEL-RIM-EDGE-PROTECTORS-MOTORBIKE-MOTORCYCLE-/00/s/NDc2WDQ3OQ==/z/n-MAAOxyvuVSHhM5/$(KGrHqJ,!lgFH5tvneM6BSHhM438uQ~~60_12.JPG
This set of three is a fiver on e-bay. Not essential, but of you are spooning tyres onto an alloy rim, they do stop the tyre levers denting the soft metal.
The last post was made 12 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 60.82 Kb
