Anti dive forks VF750
Deano41
PostPosted: 08:30 - 18 May 2014    Post subject: Anti dive forks VF750 Reply with quote
Hi there
I'm after some help Regarding my recently purchased VF750,
When I brake the front end dives to the left! As you can imagine this is quite disturbing.
As far as I can figure out the anti dive system is based in the left hand fork leg, my guess is that this is not activating causing the dive to the left
If anyone else has experienced this and has a solution it would be much appreciated
Robby
Dirty Old Man
PostPosted: 09:28 - 18 May 2014    Post subject: Reply with quote
Classic motorcycle mechanics magazine has covered anti-dive a few times. The general consensus is that it can be fairly tricky to make it work again. Expect to spend some money on hard to obtain gaskets and seals, and maybe have some fun shimming things.
Does it have anti-dive units on both fork legs? It could be that the anti-dive is working, but one leg just has no oil left in it.
If you want to fix it properly, the solution is going to be a full rebuild of both fork legs including anti-dive units. There used to be kits available to blank off the anti-dive, which were popular.
moonzoomer
PostPosted: 10:02 - 18 May 2014    Post subject: Reply with quote
Does your model have air assisted suspension, is there any air in the forks?
Deano41
PostPosted: 10:03 - 18 May 2014    Post subject: Reply with quote
As far as I'm aware the anti dive system only in the left hand for leg, the right leg just follows the action of the the left, this is why I think the anti dive is faulty because of the pull/dive to the left, but I think your right a full for rebuild could be in order Sad
Deano41
PostPosted: 10:07 - 18 May 2014    Post subject: Reply with quote
Not sure about the air ill check it out tomorrow,
Before I even start pulling them apart ill check the air and oil levels
I'm hoping its one of these ... A quick fix haha
moonzoomer
PostPosted: 10:08 - 18 May 2014    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Honda-VF750FD-VF750-FD-Interceptor-Chain-Drive-1983-Anti-Dive-Unit-/350940294515?pt=UK_Motorcycle_Parts_13&hash=item51b5abed73
stirlinggaz
PostPosted: 21:00 - 18 May 2014    Post subject: Reply with quote
hi,
i had these anti+dive forks on my 1986 vfr700 .
were useless when i got the bike and equally useless after i had them servced.
they seem to use some sort of ball bearing with a couple of seals.
used to make a helluva bang when going over potholes, which amused me.
was advised to ditch them / i did, still have the originals in my garage,
cheers,
RhynoCZ
PostPosted: 21:10 - 18 May 2014    Post subject: Reply with quote
Hi, I had it on GPz550, the best thing to do is to take it off. I experienced what's it like a few times but then it got crappy and it started to be a bit unpredictable/dangerous. If I still had the bike, I'd put there some plugs instead of the antidive thing and put progressive springs into forks. I've actually never talked to anyone who'd liked the antidive system. Thinking
It is not worth the money nor your time trying to fix it. Thumbs Up
moonzoomer
PostPosted: 21:24 - 18 May 2014    Post subject: Reply with quote
stirlinggaz wrote:
hi,
cheers,
Had the exact same experience with potholes on my CBX 550 with the anti dive, I was able to buy a blanking kit at the time for around 30 quid and simply replaced the fork oil with heavier gear curing the problem. I would forget about any repairs other than fork seals on the VF750 and try to remove the defective (from new) anti dive.
PostPosted: 22:11 - 18 May 2014    Post subject: Reply with quote
I'd have the cam covers off and inspect the camshafts before spending too much money. Even if it isn't rattling not the cams could be well down the road to ruin.
PostPosted: 22:16 - 18 May 2014    Post subject: Reply with quote
The Honda anti dive system was about the only production one that didn't have a lousy reputation. The caliper hinged a bit, pushing on a piston in the fork.
Is that the system on your VF?
However, the forks should move pretty much together (there are plenty of forks around with one doing the springing and one the damping, or compression damping in one and rebound damping in the other). Check that the wheel spindle is secure, that the front mudguard / fork brace is in place, not rusted and secure (if it just has an aftermarket mudguard with no fork brace then I would expect that to be the problem). And check that the forks are not twisted in the yokes.
moonzoomer
PostPosted: 23:04 - 18 May 2014    Post subject: Reply with quote
The earlier Honda system was not linked to the caliper in any way, it was total crap that simply stopped the flow on heavy braking locking the forks up, there was no linkage to braking in any way hence the problems.
Deano41
PostPosted: 02:56 - 01 Jun 2014    Post subject: Reply with quote
Thanks guys for you help with this, I have got to the bottom of it Smile the left hand leg had the incorrect amount of oil and the shrader valve core used to pump the fork up was faulty so a simple empty and re-fill of oil, new valve core, pump to the correct preasure and she's good to go .... Happy days Smile .. Well it was! Whilst I had the front end off i decided to sort out the intermittent neutral light issue, I had the fuse cover off hoping it was a faulty fuse, I replaced one fuse switched the ignition on and bam one of the other keys touched the stearer and wiped everything out ... I know FM luck .. Has anyone else been this stupid (I doubt it) if so ha be I just blown the fuses or is it worse?
Again thanks for your help in advance
The last post was made 11 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 77.79 Kb
