| Deano41 |
 Deano41 L Plate Warrior
| Robby |
 Robby Dirty Old Man
| moonzoomer |
 moonzoomer World Chat Champion
| Deano41 |
 Posted: 10:03 - 18 May 2014 Post subject: |
As far as I'm aware the anti dive system only in the left hand for leg, the right leg just follows the action of the the left, this is why I think the anti dive is faulty because of the pull/dive to the left, but I think your right a full for rebuild could be in order  |
| Deano41 |
| moonzoomer |
| stirlinggaz |
 stirlinggaz World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 21:10 - 18 May 2014 Post subject: |
Hi, I had it on GPz550, the best thing to do is to take it off. I experienced what's it like a few times but then it got crappy and it started to be a bit unpredictable/dangerous. If I still had the bike, I'd put there some plugs instead of the antidive thing and put progressive springs into forks. I've actually never talked to anyone who'd liked the antidive system.
It is not worth the money nor your time trying to fix it.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| moonzoomer |
| Pete. |
 Pete. Super Spammer
 Posted: 22:11 - 18 May 2014 Post subject: |
I'd have the cam covers off and inspect the camshafts before spending too much money. Even if it isn't rattling not the cams could be well down the road to ruin. ____________________ a.k.a 'Geri'
| Kickstart |
 Kickstart The Oracle
 Posted: 22:16 - 18 May 2014 Post subject: |
The Honda anti dive system was about the only production one that didn't have a lousy reputation. The caliper hinged a bit, pushing on a piston in the fork.
Is that the system on your VF?
However, the forks should move pretty much together (there are plenty of forks around with one doing the springing and one the damping, or compression damping in one and rebound damping in the other). Check that the wheel spindle is secure, that the front mudguard / fork brace is in place, not rusted and secure (if it just has an aftermarket mudguard with no fork brace then I would expect that to be the problem). And check that the forks are not twisted in the yokes.
| moonzoomer |
| Deano41 |
 Posted: 02:56 - 01 Jun 2014 Post subject: |
Thanks guys for you help with this, I have got to the bottom of it the left hand leg had the incorrect amount of oil and the shrader valve core used to pump the fork up was faulty so a simple empty and re-fill of oil, new valve core, pump to the correct preasure and she's good to go .... Happy days .. Well it was! Whilst I had the front end off i decided to sort out the intermittent neutral light issue, I had the fuse cover off hoping it was a faulty fuse, I replaced one fuse switched the ignition on and bam one of the other keys touched the stearer and wiped everything out ... I know FM luck .. Has anyone else been this stupid (I doubt it) if so ha be I just blown the fuses or is it worse?
Again thanks for your help in advance |
The last post was made 11 years, 217 days ago. Instead of replying here, would creating a new thread be more useful? |
