| Andy1994 |
 Andy1994 Derestricted Danger
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 23:11 - 19 May 2014 Post subject: Re: good old bike for a2 |
| Andy1994 wrote: | Hi all just wondering what old bike from around 1970 onwards i cam ride on a a2 license. I like the look of old bikes like the honda superdreams and yami rd. I was wondering what other old bikes i can ride which are not an arm and a leg to buy cheers for any help |
Most production bikes from the 70's might be made A2 eligible via restriction, as few, bar real exotica, made over 90bhp as standard; though few bikes over 500, and quite a few under, wont be naturally A2 complient without restriction.
What do you want one for? And how much do you value arms and legs at?
If you want a project to restore; reccomends would be very different to if you want one as an every day 'practical' rider, different again, if you want a Sunny Day promenader. Prices will vary significantly too.
And do you have any preferences; Jap, Italian; Brit-Bike, BMW?
Old Air-Head BMW's are plentiful and practical; as are Guzzi's; Brit-Bikes of that era would probably be a Meriden Bonnie or a Norton Commando; of which a Bonnies a good first classic; Japs? Well there's a lot more to choose from, and a lot more that are likely to be a bad choice.... of which a Super-Dream is probably the most common 'bad choice' unfortunately! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Az |
 Az World Chat Champion
| Andy1994 |
| Az |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 03:01 - 20 May 2014 Post subject: |
EVERY bike is 'restricted' whenever you ride it at anything but wide open throttle, at peak power rpm. All a restrictor does is limit how much air can get into the engine, just like the throttle does.
Absolutely no reason that a 'restricted' bike should be 'strained' in any way by having a 'permenant' restrictor in it; while reducing loading on parts from limiting power is actually going to reduce strain, and wear and tear.
Only bikes that wont take so kindly to restriction are two-strokes; which rely so much on 'resonance' tuning effects to work in the first place, and are tuned for higher power at the expense of low and mid range, giving harsh power delivery or 'power-bands', restriction, that simply clips the power peak, tends to make them rather... err... pointless... its usually that wild power ramp you want one for.
Anyway, if you don't want a restricted engine, but naturally A2 compliant bike... well... you are going to be a bit challenged.
1975, Moto-Guzzi has a pretty unsophisticated 500cc two-valve per cylinder, push-rod V-Twin engine. It makes bang on A2 licence power limit of 47bhp, BUT at 160Kg, even that is too light to meet power to weight criteria and would demand even that be clipped of a couple of ponies.
RD350LCs are off the menu; 50bhp, and again, less than 160Kg, and a two-stroke. You might just eek a 35bhp 250LC.
Of the old air-cooled smokers, the RD400 at 40bhp is under power limit, and at 200Kg over weight, so would be OK. But these are in what I would certainly consider 'arm a leg' price range, and 250's don't seem far behind.
Honda CB400 'four' of 1976, four cylinder four-stroke screamer; 37bhp and 185Kg, would just about eek in on A2;
500-four and 550'four are 200Kg, but an eek over power limits. So most four-cylinder bikes of the era are going to be out of bounds, UNLESS you are prepared to restrict.
Means that you would have to look at smaller capacities, twins and singles; and carefully. Honda CB250RS four-valve 250 single of 1981 vintage, made 31bhp, but weighed in at just 135Kg, so is only 'just' within A2 licence power to weight limits.
Means you would be looking at stuff like Yamaha XS250's; Honda Super-Dreams, Suzuki GSX400's; Kawasaki GPz250/305's; and the like,
And MOST of which will have spent the 70's 80's and 90's in Learner/Post Learner Commuter Hell as poor mans hacks, being run into the ground;
And what you are likely to find NOW, is most likely to be prettily painted scrap, tarted up on a budget by an optimist who wants a project but cant afford to do anything more exiting or valuable; so it'll be painted nicely, and might even have an MOT, but like as not, the mechanicals will all be bodged to buggery with reclaimed parts barely in better nick than what they replace from generally dire pool of source bikes... might be 'OK' for a couple of gentle sunny day excursions to a classic meet... but NOT what I would want to rely on as every day transport.
Meanwhile; parts... you want something that is easy to get bits for, but have a £2K budget?
- Do you want a Project Bike to restore?
- Do you want a Show-Rider / Parade bike to go to occasional classic meets on?
- Do you want a practical 'every day' classic you can ride to work in all weathers?
When it comes to restoring old bikes, where there's a will, there's a way, and you can almost always find bits, if you have the money, and the time to hunt them out.
That's the rub. time and money.
If you have a project, then you can usually take your time to hunt bits down, that's part of the challenge; and with a large lead time from taking a bike to bits, finding whats missing and whats unserviceable, easy to compile a shopping list to go hunt out, while you get on with other jobs.
If you have a Parade bike, that only ventures out the garage three or four times a year? Again, there's no great rush to find stuff, and no huge loss if you miss a meet.
If you have a classic as a daily rider; worse your SOLE way to work... then NOT being able to get the bit you need from wemoto 'next-day' can be severe pain in the arse.
SO, its all reletive... and what may or may not be more or less suitable for you REALLY depends on what you want the bike for.
You NEED to help us help you here!
What are your 'needs' what are your 'wants', and what is more important to you in that?
I'm going to take a guess from your user-name and fact query is hinging on A2 licence requirements that you were born 1994, so are 19/20 yrs. Which SUGGESTS, that you probably want a bike as every day 'sole' transport; not a sunny-sunday-show toy, or a big mechano kit.
If so; then with £2K in your pocket you have a GOOD budget to get a very useful motorcycle, with 'traditional' styling, or a very practical classic. BUT, you are going to have to restrict it.
I mentioned the Moto-Guzzi V50. This was my top choice for my O/H, when she was still planning to do her tests on a 125 for a 33 restricted licence.
Genuinely 'old' and of the era; its a very simple and easy to work on air-cooled push-rod engine. Conveniently has shaft drive, which means its low maintenance and what maintenance it may need is all VERY DIY friendly. Bike was in production for over ten years and sold well, here and in Europe; and with pretty stable design year on year, and very good model support, its very easy to get bits for.
Snowie actually didnt get one; she got a V750 Strada which is a later, bored out derivative, as a 'project' she's currently working on and blogging in show and tell if you want to have a look.
But, whole range of 'small-block' Guzzis share same basic engine, drive line and chassis, in capacities from 350 to 750, and most bar the latest 750's are likely to fall into your price range.
Its a good starting bench-mark; BUT, old bikes demand frequent care and attention. Living with a 'classic' is NOT for every one, and as an every day rider, can be a challenge, especially if you lack mechanical abilities or facilities.
I ride an 'old' Honda CB750... not the really desirable chrome mudguard and wire wheel Single-Over-Head-Cam 'K' unfortunately; they are rather expensive in good fettle, and even as basket cases for restoration, can fetch as much as my 199's 'Retro' is worth!
However, as an every-day 'ish' classic, its a pretty good bike. It was never a particularly inspiring machine; but it was very all-round capable. Air-Cooled four cylinder motor is not amazingly powerful, but it does have a nice, is somewhat small, surplus of power (not that this would be an issue for you, as you would have to restrict it anyway), and most of it in real world usable low and mid-range. Built in the 90's, it got then modern 17" wheel sizings, so benefits from a wide range of relatively good value, if not necessarily 'so' cheap 'modern' and radial tyres, unlike earlier models, for which choice is much more limited, and of poorer old fashioned construction. Likewise, has modern brakes; sourced I believe from the CBR600. Parts are on the shelf at weemoto or Dave silvers spares, and if I call before four in the afternoon and pay the expedited delivery, can be on my doorstep by ten the next morning.
Mine is now 21 years old and eligible in its own right for 'classic' insurance, while retaining modern bike spares support for new parts as well as good back-up from plenty being in the breakers for more expensive or unavailable bits.
And, where a wire wheel SOHC CB750 might fetch £6-7K and even scruffy comstar andplastic body SOHC's can make £3K+... and 8V DOHC FII's from the early 80's often have £2K asking prices... you can pick up a useful if not pristine example like mine for as little as £800 ready to ride, and pretty immaculate mid-life-crisis rider owned examples, for under £1500.
All the 'looks' and style of a traditional bike, all the day to day practicality and livability of a more modern one... without the added risks and complications of being clad in plastic and having a radiator infront of the header pipes.
It is NOT the only motorcycle in this same class.
Kawasaki GT550/GT750. Shaft drive, accross the frame air-cooled four; they were, in the 90's the Despatch riders favourite; comfy, low maintenance, and 'cheap'. Some real dogs about, but, folk that buy them, usually more interested in maintaining real mechanics than they are the pretty bits; so the scruffy 'heap' often proves to be well looked after gem, when you scrub away the layers of matt-black and ACF50, where you get something like an RF600 or ZZR600, you find that under shiney plastic, everything is red rusty and siezed, having been out of sight and out of mind and never been touched. these tend to be really cheap, sub £500 clunkers, but you can find nice tidy ones for around a grand.
Kawasaki Zephyrs. they did a 550 and a 750; 1100 is the one people want, though and still command good money. 550 and 750, are the unloved, and again, can be a bargain; 90's bike, 70's styling; simpler air-cooled motor and still in the spares listings, while taking modern 17" tyre sizes. And the 550's tend to be the cheapest, at at 50bhp and 180Kg they dont need much by way of restriction to make them A2 complient.
As AZ says, you have the more usual 'first big bikes' like the XJ600 Diversion; Bandit 600, and the early Fazers. Andmore if you look at larger twins. £2K might just eek you an early Kawasaki W650, or Triumph Bonaville... in fact either modern 'Hinkly' one, or the real deal, last of the line and least loved 'Meriden' T140's... would demand a bit more looking after, but possibly just as day to day practical, with a lot more genuine 'classic' cudos attached.
What about a 90's Ducati Monster? M600's are reletively plentiful, and well priced. Not the most reliable machines in the world, BUT, in the real world, a mid 90's Monster is probably no harder to live with than a less common late 70's Jap, like, I dont know... a Honda CB400N Super-Dream! PURELY because its fifteen twenty years younger!
I dont know... I'm chucking chaff in the wind to see what settles... maybe give you a few ideas... BUT you need to help us help you here, and end of the day, its your money, your bike; but a few clues as to what you want and need from it; could help us better offer suggestions. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Andy1994 |
| Conzar |
 Conzar World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 18:25 - 20 May 2014 Post subject: |
| Andy1994 wrote: | You are right i am 20 and would be using it as an everyday commuter. |
Your only way to work?
How many miles?
Regular office or inconvenient hours?
What 'back-ups' or fall-back do you have? Lift of co-worker, mum/dad/partner/house mate? Bus, train, taxi, push-bike?
In short, how 'crucial' is it it starts on the button every morning, and dont piss oil on your work cloths?
| Andy1994 wrote: | Now i would like an old bike because i like the shape |
Aesthetics are subjective, and that's not all that helpful for us to figure what sort of style you really preffer. 60s & 70's bikes tend towards wire spoked wheels and chrome mudguards, what I would call 'traditional' styling. But, there are a lot of more unconventionally styled bikes in that era, lots of bikes with more 'dated' styling hanging around from the 50's, and more avante-guarde ones preceeding the cast wheels and plastic bodies of the 80's. WHILE, the 'traditional' wire wheel and chrome has survived even to modern bikes in the form of more or less 'costom' style cruisers, or in more mundane budget commuters. THEN we get the 90's fad of the 'Retro' and the later 90's and 00ies 'Factory Classic', like the Enfield or the W650 or Triumph Bonaville.
There are a lot of 'old' bikes out there now, that are genuine classics that have 'modern' styling. 1985, Kawasaki kick-started the 600 Sports Class with the GPz600R, Honda offered the first CBR600 just eighteen months later with fully enclosed, full-fairing body-work; these are now pushing 30 years old; yet dont look hugely different to a modern 600, and are a lot more 'contemprary' than say a Honda VT750 Shaddow, 'Cruiser'.
| Andy1994 wrote: | and would rather one where parts can be bought in a couple of days so rarer bikes would be out the question. |
Hmm, preconceptions and predjudice can be unhelpful here;
I have a pretty 'rare' and obscure trials bike; My 1981 Montesa Cota 248. Now owned by Honda, the marque is probably the most popular in the sport; but my bike was built in the brief years when the company was in financial trouble, before Honda bailed them out and then absorbed them into the group. The bike was based on the previouse years championship winning machine, and as such, was 'almost' a completely new design with little commonality with the earlier 247 model that had lasted over a decade reletively unchanged, and had a lot of commonality with 'sister' models for road or scrambles. They made about five thousand of my bike, in total, of which barely three hundred made it to the UK. This doesn't bode well for being able to procure parts very easily... BUT; its as much who you know as what you know; and with such an obscure motorcycle, it IS possible to run one, and not have major problems... you only need ONE parts supplier, as long as they have what you want on the shelves and you are prepared to pay what they ask..... I've owned my bike since 1986, and was competing on it regularly, as in twice a month, in classic 'Twin-shock-Trials' right up till about ten years ago. Tyres are 'standard' and still readily available; as are inner tubes; the bits that are unique to the model, like genuine akront Montesa badged hanlebar levers and handle-bars and lighting kit were all bagged and boxed, should I ever want to restore it for concourse, and replaced with generic after-market bits; likewise plastic mudguards; and when stuff has got broke... I have usually known what I'm most likely to break and got spares ahead of time, or can get them after falling off on a Sunday, calling Sammy-Millers-Spares or Jim Sandiford on Monday, by Thursday, so I could fix it on Friday after work, practice on Saturday, and fall off again following Sunday!
BUT....I had the advantage of a decade of experience, and knowing what was what, and what I needed and who would have it. AND the tools and know-how to be able to pull that bike to bits and completely rebuild it within a week.
You dont need to be 'scared' of uncommon or more exotic machines, on the presumption that they are going to be 'more' difficult to live with. There's enough scare stories of folk with current listed under warranty modern bikes that have given more grief and been less 'available' to use, in and out of dealers, trying to find anomolouse faults, doing diagnostics by replacement, and dragging it out, waiting for parts on 'back-order'.
BUT, you DO, really have to be clued up about what you are buying before you buy it, and get clued up on what common issues and faults may be, find out who the 'experts' on that bike are; who has the bits, and know what to do with them when you get them.
Like I said, to live with an old bike (or car for that matter), you have to have the enthusiasm and be prepared to put in the effort to get clued up on them, and get elbow deep in nuts, bolts, grease and oil, if needs be.
| Andy1994 wrote: | I would mind one to take to classic meets at all i would be up for that. | If you rate my waffle 'interesting' rather than boring... buy a pipe, grow a beard and you'll fit RIGHT in
| Andy1994 wrote: | One thing i have been told that having a restriction will increase insurance cost as its classed a modification is this true. | Depends on the insurer. And, even if they do deem it a 'mod' whether they deem it one that effects premium price is another question beyond.
But, to allay your fears, its not a huge concern; you'll be able to get insurance, its just a question of cost; and in that huge variable, small matter of restriction, will be small potatoes compared to what bike you choose, where you keep it, and what your rider record is. Picking older, lower performance 'classics' you are likely to be looking at lower premiums to begin with, so no great 'worry'.
What IS likely to be more worry, is that you may not be able to get the 'best' policies for classics, that discount premiums for machines over, twenty or twenty five years old, depending on thier own policy; either because the bike isn't garaged, or because you want '+commuting' on your cover, or because of the annual mileage you are likely to want, or simply your age.
Insurance is a minefield, they work to thier own ever shifting rules, with little rhyme or reason; and we just have to shift as best we can.
Be worth you bench-marking quotes on something like a 1998 Suzuki GS500; its bang on 47bhp and I think its listed as 'naturally' A2 complient, though specs slap it on the boarder line, power to weight may be a tad over. One of teh few more 'contemprary' bikes that you can get a straight quote on, and a common enough 'restricted rider' to get an idea of what's 'reasonable' premium for your circumstances.
| Andy1994 wrote: | If not i wouldnt mind a more modern bike like what you stated (bandit, xj600 and others) i know that the bandit is a work horse as i looked at information on the before. I like the old bikes as its what ive been brought up around howevrr would it be more ideal to get one later as a restoration project instead of getting one now. Im not ruling out modern bikes at all. |
Little confused by that; I THINK you mean forget 'classics' as a daily rider for the moment; get a Bandit or Divvy as a rider, and look at getting a 'classic' as a project for when you have an unrestricted licence? If so, then yeah. Sensible idea; build a classic how you want it, as you can afford it; and on a limited use insurance policy as second bike, could be as cheap top insure two bikes than one trying to 'do-it-all'.
But; hold that thought; 'older' modern bikes can still demand a lot of attension and maintenence; and boundry between 'Old' and 'classic' is very fuzzy. Like I said, my CB750 'retro' is just an 'old' bike, but, its eligible for classic insurance! The enfield fans will tell you their 21st century machines aren't eligible for classic insurance, but demand almost as much maintenence and attension as thier 1950's counter-parts!
If you get clued up, you CAN have a bit of the best of both worlds.... but you can, far more easily get the worst of both!
| Andy1994 wrote: | As for the ducati ive heard good things and bad are they anymore unrealible then a bandit or xj. |
VERY subjective. And it depends on the bike and how its been looked after and how YOU look after it as much as anything else. There's plenty of folk riding more aged Bandits and Divvy's, on a shoe-string budget, botched beyond credance who have nothing but niggling troubles; while there are folk who have Monster's that have been treated as garage trophies, been lavished with care, not done mant miles and been well 'sorted' to make them more reliable than they were when new.
With ANY older bike, its a bit of a lottery.... I've not lived with a Ducati, there are a couple of folk who can say better; I think its Pits who's run a 750ss as an every day rider for a few years who could say better; but, I've looked at Monsters a couple of times, and while I dont have to rely on one as sole transport; I reckon that if you are a BIT clued up and not TOO eager to hand over good money for a shitter; and pick one that looks more likely; you stand a fair chance of having a bike that's no greater risk of being a lot of hassle or a money pit than a typically 'well used' Bandit or Divvy; I looked at them more seriousely a couple of summers ago, and the bench-mark at the time was a £1500 VFR750... VFR has reputation for clock-work reliability, BUT tempered with risk that if one needs attension, it could be a money pit. Monster, reputation for being a bit tempremental and prone to electrical hissy fits, BUT, if you are a little clued up, being reasonably fixeable. Swings and round-abouts. I would give one a chance... BUT as said, I wouldn't have to rely on it to get to work every day.
| Andy1994 wrote: | Are they more expensive to insure and maintain. |
Does Daz wash Whiter? Whats the comparison. Insurance is always anomolouse. For ME, quotes on a Monster 600 were much of a much what they want from me for ANY bike... I pay little more for insurance than I do my tax-disk... 20% is niether here not there on my quotes; more likely £'s differences will be more significant for younger rider as daily rider. BUT; lots of young loons crash Bandits.... some bikes get curiouse loadings... Monster could be in an insurance blind-spot and quotye low for you, or be one that gets a hammering, I dont know.
As for maintenence; all bikes need it. Monsters have more involved and demanding double knocker valves that are finickity to set up; but other wise they aren't too commplicated and do only have two cylinders to worry about.
| Andy1994 wrote: | The monster is one of my favs of the ducatis so i wouldn't say no as long as its no more expensive to run then the other 600 bikes. |
Like I said, I would give one a chance; in the greater scheme of things, the 'variables' are huge, and there are risks all which ways round. Lucky fella might be able to ride a Bandit for years never doing much more than change oil and tyres; unlucky one could end up with a scrap Divvy at the side of the road before even getting it home! I wouldn't bank on a Monster being 'cheap'... but if it inspires you? and you get added pleasure from one? Well, there's worse ways of wasting your money, ent there?
| Andy1994 wrote: | Would getting the bandit with the faring be better for day to day |
Wouldn't really bother me in the slightest; but, back to top and how useful a fairing may or may not be would depend on how many daily miles you do, what roads you do them on, and whether you have to get the bike down a narrow passage to park or anything.
| Andy1994 wrote: | also have you had any experience with the bandit, the xj |
Not owned either. Personally I wouldn't touch a Bandit 6. Far too many have been thrashed and 'fightered' and had more attension by way of horrid paint jobs, loud pipes and anodised tat, than new brake pads and decent chains; divvy's? Tend to atract more concervative and contientiouse owners, and they tend to more often get regular oil changes instead of dominator headlamps!
| Andy1994 wrote: | i would have a ducati |
Well... go get clued up on them then.. from some-one who knows more specifically about'em as I do... you only live once; it looks like it ticks a lot of boxes; and 'concerns' hanging over it are not really much different to any other... so bottom it out... no reason you shouldn't have one... it's just making it work for you rather than against, and THAT is doen to getting genned up, and keeping your head when you have money in your pocket and bike infront of you. Chase the dream... you only live once, and we dont ride bikes because its the most sensible thing to do... so its ALL merely managing our mania! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:25 - 20 May 2014 Post subject: |
| Andy1994 wrote: | Wow that was a lot more information then i expected |
It's certainly a lot of words.
Only if you're insured by idiots, and it's best to stay away from them. Many insurers only distinguish between "provisional" and "full" licenses, and an A2 (or for that matter, A1) license can only be "full" by that definition.
If they don't ask about restriction, you don't tell. If you're riding in accordance with your license, you're good to go.
The Bandit in its various guises is the most common bike in the UK. If you want one, get one, you won't go far wrong. ____________________ Biking is 1/20th as dangerous as horse riding.
| MC |
 MC Banned
| Andy1994 |
| Az |
| Andy1994 |
| Andy1994 |
| Az |
| Andy1994 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 02:21 - 21 May 2014 Post subject: |
One of the things that appealed to me about the Monster over other ducatis is they are carbed not fuel injected... at at least SOME were. I'm not too clued up on them.
Anyway, a carbed one would merely need a couple of restrictor washers dropped into the carburettor rubbers... and carbs re-fitted, and if you cant DIY that... dont bother buying an old bike, let alone a 'classic' The 'expensive' FI kit's I believe are about £150 or so, and you get a cirtificate that has absolutely no legal standing what so ever; but if you get a dealer to fit the kit they can stamp the cert and make an insurance bod or plod happy... or maybe a bit less miserable.
Efi bikes.. I dont know; likely that Ducati offer 'restricted' ECU's for them, you might be able to get new or off e-bay, or there may be a throttle-body washer kit similar for carbs available.
LEGALLY you are merely required to ensure that motorcycle you ride is within your licence entitlement; how you do that is entirely up to you. You do not have to have ANY proof what so ever that the bike is restricted to ride it or if stopped by plod.... BUT if the manufacturers declared specs say the bike makes more power than you are allowed, you are guilty until proven innocent and will have to justify how you ensured bike is within licence entitlement.
Such comments as "Well its twelve years old and old engines loose a bit of power, dont they, through wear and tear" is probably NOT going to cut it.
Having a reciept for a restrictor kit, even a stamped FI cert, to suggest you at least bought a restrictor kit 'believed' to bring bike within limits shows you have done something, but doesn't prove kit was actually fitted, or hasn't subsequently been removed.. it would take physical inspection and or testing of the bike, to actually deturmine if its restricted or not.
So, practically; the first 'authority' of concern is your insurance co. You enter a contract with them, and they may demand an approved (by them) restrictor kit be fitted as part of that contract; they could ask for a reciept from a mechanics to show a restrictor has been fitted or a dyno print, or pretty much anything really... they could ask for photo-copies of both your parents birth cirtificates and a sworn statement from a practicing Rhabi that the sky is blue if they want to make that a contractual requirement! But it's NOT a requirement of 'law'. Thing is, they may ask for nothing, they could ask for something, and that something might not be what you got.
So you choose what you are going to do; then offer that to your ins co; if they accept it great, if not find ins-co who will accept it.
After that; only be an issue if you get pulled by plod; and again, they can ask for whatever the heck they like... they may not ask for bog all; BUT, you are not required to even carry your driving licence in the UK, you don't have to show them fuck all at the side of the road, if stopped.
They can demand whatever they like, and they can threaten to impound the bike as uninsured; BUT if you have insurance... they would be on a sticky wicket without proof that its unrestricted to do so; and up to THEM to prove thier suspicion, not for you to prove them wrong. all they can do is give you a producer for driving licence, MOT and insurance cert. And possibly to make apointment at your convenience for a vehicle inspection by thier representative.
So, its a question of avoiding dropping yourself in it, when talking to them; they can talk you into incriminating yourself very easily; so try and keep your mouth shut as much as you can, and dont get thier backs up with 'smart' answers.
Remember its up to you to ensure bike is restricted; so tell them whatever sensible strategy that is; retrictor kit, ECU, throttle stop; and if they ask for a certificate you dont have, be straight, tell them its not required, you dont have one. And having told them, that the bike is restricted, and supported that with the 'how', then they can believe what they like, up to them to prove you a liar from that point, not for you to prove them wrong; And unless you GIVE them reason to believe you aren't telling the truth or that your reasons to suggest the bike is restricted isn't 'reasonable, all they can do is default to a producer and vehicle inspection appointment.
And having a bit of paper of some sort, can do a lot to shut them up and make them go away.
But not riding like a tit in the first place, can do an awful lot more to stop them tugging you in the first place!
After that; only other place it may become an issue, is back with ins co's, if you have had an accident, and some-one is looking to wheedle out of paying.
It is a concern; but ultimately shouln't be a huge one; there's lots of restricted licence holders out there who have never even been challenged for proof of restriction, and I'm sure an awful lot of them are riding bikes they dont actually hold entitlement to ride!
If you have taken 'reasonable' precautions to ensure bike is within licence entitlement, as required by the Road Traffic Act, THAT ought to be enough, and you should have good enough answers for any-one who takes an interest.
And bottom line, a £150 FI International kit may be a rip off; but, it's a 'reasonable precaution' that would take an awful lot of arguing against, and STILL come down to inspection and test if any-one wanted to seriously challenge it. Its not a HUGE saving to do nothing or forge a Paddy-Cert on your PC; while backing that up buying stuff fitting stuff or getting bike pre-emptively tested is only going to erode that small saving; so could be a 'convenience' worth its cost.
So, its not a HUGE worry, its just money and how much risk you want to run, and again, getting a bit clued up.
FWIW, Snowie, my O/H has about five months of 33bhp restrict left to run; she's just bought a Guzzi 750, its not restricted.. well, the engine isn't... has zero RWBHP at the moment as the gearbox is in bits scattered around my living room! But, she has it insured and was never even asked for proof of restriction. She's also named rider on my 750 policy, again, bikes not restricted, I was never asked for any proof of restriction for her.
Unlikely she will ride either until her restriction lapses; but if this gearbox goes back together, it could be on the road before she has full entitlement for it... insurance has been dealt with, she has some... so our 'restriction' strategy, if she wants to ride it before her restriction lapses is to fit a throttle limiter.... I could DIY that with a few penny washers in the carb slides to limit how far the throttle may be opened, and make a fair guess of how much I would need to stop it opening to get it under 33bhp....
I would have absolutely no way to prove that made the bike A2 compliment, nor paper work to support it, BUT its a 'reasonable precaution' and could answer plod at side of the road. Though they could challenge it and still demand testing, as suggestion might not be 'convincing' enough in their opinion.
So, I have mate at the end of the road who is registered bike mechanic... he's in the yellow pages and like everything... "Here Nick, stick these washers on Snowies carb slide tops for me, and print me off a receipt to say you have fitted a restrictor kit!"
Same unwarranted 'restriction'... but I got a bit of paper from registered mechanic, that says he fitted it... doesn't say he warranted it to A2 compliance... JUST he fitted a restrictor... and two washers limiting throttle slide travel IS a restrictor....
Back to the coppa at the side of the road; "Yes officer its restricted, Here I have receipt from mechanic that says he restricted it" They may still be of the opinion its unconvincing... but, they have some third party support that the bike was at some point restricted... so bottom line they would STILL have to get the bike tested to find the truth.
And, of course could be that my DIY 'restriction' doesn't restrict it enough to be A2 complient.....
So, having got Nick to give me a bit of paper, I COULD take bike to a Dyno House and find out how much power it made, and pre-emptively test it to be sure it would pass a police inspection. Might take a couple of rund, if it was over, adding more washers, though.
And another bit of paper to wave around to support 'restriction'... and as long as washers left in, IF the bike got tested by any-one.. well, engines rarely gain power by wearing out or bits breaking... AND even if shown to be over limit on another dyno... court could be shown enough paper and physical evidence in a restriction mechanism in place on the bike, to support suggestion that 'reasonable precautions' had been taken to ensure licence entitlement. IF it ever went that far.
And in all probability it never would; in all probability, snowie will never even get pulled by plod while she's still on restricted licence; she hasn't been pulled in four years on her 125 while on L-Plates or off them; little reason to believe she'll get pulled on her 750. And even if she DID, reciept from Nick the Mechanic saying he fitted something resembling a power restrictor, likely to end the matter, at side of road, or at counter when showing her docs.
There's no right or wrong answer to restriction strategy; law rightly in my opinion, merely requires you do 'something' to endure vehicle is within licence entitlement; up to you how stringent you want to be in that assurance; its no different to the stipulation that its your responsibility to ensure that the vehicle is insure, taxed, if required MOT's AND 'in a road-worthy condition'....
Few people will get a pry bar out to check play in their steering, suspension or wheel bearings before they pop to the shops in their car.... which is what a MOT man would do to ensure the vehicle is 'road worthy'
So comes down to what is 'reasonable precaution'.... we are frequently reminded that possessing an MOT isn't reasonable assurance that a vehicle will remain road worthy for the entire validty period of the MOT cert... and its the same thing here. Its YOUR responsibility, and for YOU to judge how much is 'enough' and what a court might deem 'reasonable'. And how much its worth.
You could wing it with nowt; and you might never get challenged.
You could do 'something', that some might deem 'reasonable' that might even genuinely make bike genuinely A2 compliment, and that could give you enough to answer any-one challenging you, without ever having a bit of paper to support it.
You could get some bits of paper that might or might not support your suggestions, that shut up any-one who challenges you.
Or.. you could just buy an over priced pair of washers with a certificate, that insurance co's and plod are familiar with from FI , much more likely to shut them up if challenged.
You just have to have the strategy and the answers before they are asked. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 02:55 - 21 May 2014 Post subject: |
| Andy1994 wrote: | [fair enough bandits in my opinion are good as long as they are treat well just every time i see one its a young kid revving the bollocks off it and im just cringing haha |
HOW OLD are you again?
Given that you now have to be 19 to ride anything over a 125, chances are most of them 'young kids' are older than you are!
As for other Q's what years; quick check on MCN, all M600's seem to have been carbed and made 53bhp as stock...Apparently they went fuel injected in 2002 as the M620, and gained a few bhp.
so I think I would stick the carbed models to the top of my list;
Power is close enough to the 47bhp that if you took a second hand example to a Dyno-house, and told them you wanted to check that the sellers claim it had been restricted was true, they could hand you a chart saying so, without lifting a spanner to it. Difference small enough to be within the limits of 'experimental error' on the machine and manufacturing tolerences of original claims. and its bang on 175Kg so would not need under restricting to meet power to weight limit if any-one challenged that.
But carbs are a known quantity; easily DIY diagnosed and serviced; and easy enough to fit an approved washer restriction to one, or DIY your own.
Italian electrics have always been a little questionable; ducati's even more so; and on an older bike, PERSONALLY a complication I could hapily live without.
They reckon that the carbed 600 is reletively 'simple' mechanically, so avoiding unnecessary elec-trickery? All helps keep it within realms of garden shed mechanics; or back street mechanics; which as an every day all-round bike gives you better chance to take control of maintenence and keep costs down.
The older models are also likely to be the cheaper to buy. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| MC |
 MC Banned
| Az |
 Posted: 18:53 - 21 May 2014 Post subject: |
| MC wrote: | | Az wrote: | You slate the Bandit a lot, so i'm assuming you've ridden one long enough to form a valid opinion or are you just going by what others say? |
Did my test on a Bandit. Didn't realise I was slating it a lot (sorry), thought I normally just pointed out it's a heavy bike... which it's. Think this topic is the first time I've called it bland, and that's mainly cos I couldn't think of another word & find it funny others call it a blandit
It handles alright, it stops alright, if you want a bike that's alright then go for a Blan... Bandit. However IMO its not a bike that's good for a restricted license, all that a weight with 46bhp, when there are lighter/nicer bikes out there. |
Riding a bike at 20-70mph and sensibly isn't going to give you the best idea.
Funnily enough, I did my tests and training on an MT-03, but I never had the chance to ride it properly (only sensibly at test standards) and therefore I can't give you a real judgement of the bike, unless you were unleashed to do as you wanted with the bike I wouldn't be quick to judge it
But, you aren't far from the truth haha, but it can be made into a capable bike and it does have a lot of pro's. Comfort, smooth and reliability being a few of them and if that was a genuine 'sorry', there was no need to apologise  |
| MC |
 MC Banned
 Posted: 19:44 - 21 May 2014 Post subject: |
Well the instructor on my DAS had a liberal attitude towards speed, on country roads he rode off into the distance & we had to try to keep up, then heading back down the motorway after our tests we stayed the sensible side of a ton but weren't doing 70
Not going to say I exploited the bike to its limits, but I got a pretty good feel for the Bandit, and did a lot of miles. The sorry was purely if you thought I was bad mouthing your bike (I know that can be annoying)
Probably going a bit off topic/thread hijacking but what did you think of the MT-03? I really miss mine Only the clunky gearbox & jerky power delivery would stop me having another, but the handling was amazing. Seeing as it can be ridden without being restricted on an A2 license it's an example of the sort of thing that's worth looking at. ____________________ Yamaha MT-03 '08 (crashed)
Honda XR-125L '04 |
| Commuter_Tim |
 Commuter_Tim World Chat Champion
The last post was made 12 years, 40 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.36 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 169.65 Kb
