Brake Light Does Not Come On When Front Brake is Activated
Bike Chat Forums Index -> Biking News & Rumours
Cody.J
PostPosted: 18:19 - 23 May 2014    Post subject: Brake Light Does Not Come On When Front Brake is Activated Reply with quote
Hello,
I just bought a 2007 Suzuki GS500. When i apply the rear brake, the brake light comes on. However, when i apply the front brake, the brake light does not come on.
Any suggestions as to why this may occur?
Thanks for your help!!
Copycat73
PostPosted: 18:24 - 23 May 2014    Post subject: Reply with quote
just had exactly the same happen to me on me 796 (Tuesday)
was the switch on the brake lever needed freein up wit some silicone spray & greased up
caveat emptor
map
Mr Calendar
PostPosted: 18:34 - 23 May 2014    Post subject: Reply with quote
As above.
Check micro switch on brake lever.
If disconnect wires you can short to test light comes on.
That would eliminate any breaks in the loom.
Replacement switch if required can be had from the likes of WeMoto or eBay.
HTH Thumbs Up
Cody.J
PostPosted: 18:36 - 23 May 2014    Post subject: Reply with quote
Which switch on the brake lever are you talking about? I'm completely new to bikes.
Thanks!
map
Mr Calendar
PostPosted: 19:07 - 23 May 2014    Post subject: Reply with quote
Thanks!
If you look at the brake lever.
On the underside is a little black box. That is the micro switch.
Should have 2 wires going to it and held in place with a screw.
If you gently squeeze the level you should hear a faint click. That the switch switching.
map
Mr Calendar
PostPosted: 19:14 - 23 May 2014    Post subject: Reply with quote
See this link for a fiche picture to see where switch is.
Part number 5.
HTH Thumbs Up
The last post was made 12 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 49.11 Kb
