Strange Varadero 125 ticking noise - Is this bike doomed?
dreamscape
PostPosted: 20:17 - 23 May 2014    Post subject: Strange Varadero 125 ticking noise - Is this bike doomed? Reply with quote
Hey all
Bought this bike not long ago for £800... It had a ticking noise which sounds just like tappets so i assumed it was just the clearances so went ahead with buying it...
https://www.xrv.org.uk/forums/attachments/varadero/48137d1395934014-my-new-varadero-125-my-new-issues-1.jpg
https://www.xrv.org.uk/forums/attachments/varadero/48145d1395934033-my-new-varadero-125-my-new-issues-2.jpg
Soon after getting it though I soon realised it had afew issues... most of which are fixed now but one is plaguing me
https://www.xrv.org.uk/forums/attachments/varadero/48153d1395934049-my-new-varadero-125-my-new-issues-3.jpg
Turns out after swapping out both cam chains and also cam chain tensionsers and doing the clearances the tapping noise still remains.
Heres the noise:
https://www.youtube.com/watch?v=JPjIsMa4BEE
Now I'm just curious if anyone else here with a varadero has had this noise? or anyone who could confirm what the noise is? As I'm currently thinking the worsed after taking it to a Honda dealer who told me after all the work i've done already its most likely the big or small ends which either way will involve a new crank... £505 for the crank alone...
They told me the Varadero has issues with condensation building up (when i first removed the cam cover on the front cylinder to do the clearances there was ALOT of milky crap on the cover so I can sadly say this has been the case with mine thanks to the previous owner) They said when this builds up it causes alot of problems with the oil and they have had afew in which have needed new cranks as a result of this issue.
I also read on another forum that the carbed models like mine have an issue with the air box getting water into them because the little clear pipe which is supposed to hold water is way too short. I can confirm mine was full and there was loads of water in the air box water chamber which also seemed to have oil in it (it was milky).
Is this Vara doomed?
Any help or advice greatly appreciated.
P.
PostPosted: 20:25 - 23 May 2014    Post subject: Reply with quote
https://www.youtube.com/watch?v=gvwjwYJY_u4
My slightly higher revving single 125.
Cam bearing has lunched itself. Safe to say its top end on yours.. likely the valve/cam area. Look before it shits itself.
dreamscape
PostPosted: 20:44 - 23 May 2014    Post subject: Reply with quote
Christ yeah! that sounds just like it...
Did you manage to fix yours? If so what did you do?
Thanks that's given me hope its not a £600+ repair job
P.
PostPosted: 21:48 - 23 May 2014    Post subject: Reply with quote
£8 bearings from a local bearing specialist. Dad sorted it really but I paid for bearings Laughing
Not a hard job though, but would highly recommend speaking with bearing specialists, it needs to do in excess of 12,000rpm and is lubricated so can be open. They will know what you would need if you take yours in. Surprised this wasn't changed with the cam chain being removed n all..
dreamscape
PostPosted: 09:08 - 24 May 2014    Post subject: Reply with quote
Excellent and that solved the noise issue completely?
Good news, I will order some Honda camshaft bearings and see what happens
P.
PostPosted: 09:30 - 24 May 2014    Post subject: Reply with quote
That solved everything and the bike ran perfectly for another 10,000 miles before I sold.
dreamscape
PostPosted: 10:28 - 24 May 2014    Post subject: Reply with quote
Excellent, although I've been in touch with Honda and apparently they don't sell the bearings seperate you have to buy the entire camshaft at 104+VAT a piece! Christ!
Was this the same for you and the reason you went to a bearings specialist?
Robby
Dirty Old Man
PostPosted: 10:29 - 24 May 2014    Post subject: Reply with quote
Do change the exhaust gaskets before opening up the engine.
dreamscape
PostPosted: 10:39 - 24 May 2014    Post subject: Reply with quote
P.
PostPosted: 11:20 - 24 May 2014    Post subject: Reply with quote
Is indeed why I went locally.
Robby, I'd like to say its the exhaust gasket but that is far too similar to my one, doubt they use the same cam but if they do they have a habit of failing with late or no oil changes!
dreamscape
PostPosted: 16:20 - 24 May 2014    Post subject: Reply with quote
Yeah i'm 99% sure its not exhaust gasket related... it's a mechanical noise. Just like tappet noise when the clearances are out.
gavbriggs
PostPosted: 21:17 - 24 May 2014    Post subject: Reply with quote
My varadero had this tappy noise and it was perfectly fine. I think it's the air induction to the exhaust the reed valves
Recent bikes: Varadero 125 - Mod 2 3/2/14 - Bandit 1200 SK4
P.
PostPosted: 22:06 - 24 May 2014    Post subject: Reply with quote
Wut.
gavbriggs
PostPosted: 23:04 - 24 May 2014    Post subject: Reply with quote
I've just watched the vid and I can't remember it sounding as loud as that but the engine puts clean filtered air into the exhaust to burn off unburned fuel and can sound disastrous if they stick open.
I changed rocker covers on mine and it quietened down a lot but never went away. It may be worth checking the pipes to the air box are connected to the front cylinder I think it is and that the cover's reed valves are operating correctly
It's the secondary air system like an egr valve, suzuki called theirs the PAIR system. Can't remember what honda called it on the vara but I still have the manual so will look it up tomoz if req'd
dreamscape
PostPosted: 10:14 - 25 May 2014    Post subject: Reply with quote
Thanks for the suggestion I've checked my workshop manual and yeah its the PAIR system. I will check the valves soon.
Could that really cause that sound though?
P.
PostPosted: 10:26 - 25 May 2014    Post subject: Reply with quote
Mine sounded like valves, it wasn't. However new chain and tensioners...I'd be amazed if the clearances were not checked.
dreamscape
PostPosted: 14:22 - 25 May 2014    Post subject: Reply with quote
I meant the valves on the PAIR system on the cam covers.
gavbriggs
PostPosted: 18:53 - 25 May 2014    Post subject: Reply with quote
You've checked an it's that? Or it has it fitted. Just check the pipe work and then the actual reeds.
The reeds are a direct pathway into the exhaust so yea it could make that kind of noise. Easy way to check is remove the pipe from the cam cover and put finger over hole. It should not blow and if it is a stuck reed will quieten off
Robster
PostPosted: 09:04 - 28 May 2014    Post subject: Reply with quote
Mine's doing it as well! Sad
Took mine to the local garage today for an unrelated issue; as its hesitant to rev up and won't set off much faster than walking pace, figured the fuelling/firing is set up wrong.
Garage wasn't impressed by the ticking noise, bloke started looking online for a new engine, giving me numbers in the £££s to fix. etc. etc. left the bike with em today so they can check plugs, valve clearences etc.
This thread makes me feel a bit better, but my engine is very noisy/rattly at idle. If its not an easy fix i'll pass the bike on.
Best of luck with OPs fix Thumbs Up
Up the bum no babies.
P.
PostPosted: 09:08 - 28 May 2014    Post subject: Reply with quote
Got a video of yours??
Robster
PostPosted: 09:49 - 28 May 2014    Post subject: Reply with quote
no, left it with Garage today, if it aint sorted there i'll get a vid done when I get the bike back. It tends to rattle quite a bit to be honest, hot or cold, so perhaps the whole engine is lunched.
Robster
PostPosted: 09:02 - 29 May 2014    Post subject: Reply with quote
Double check which plugs are in yours. Mine had iridium ones which are apparently a big nono for this engine, is apparently what's mullered mine...
Second opinion welcome on that. Garage swapped mine out for correct non-iridium ones, part no.CR8EH9, some fresh oil, and bike runs a lot better now aside from clattering still.
P.
PostPosted: 09:29 - 29 May 2014    Post subject: Reply with quote
That is a negative sir, they run fine.
They would not cause the boom town that is your cooked engine. Sad
Robster
PostPosted: 09:39 - 29 May 2014    Post subject: Reply with quote
Oh really? garage was convinced thats why it was running poo. Well whatevs its running a bit better now. Previous owner was using them for ages apparently and bike's still running. Will get a vid up later tonight
P.
PostPosted: 09:54 - 29 May 2014    Post subject: Reply with quote
Yeah, it wouldn't cause your engine to mess up. Some bikes don't like them but I'm sure they are perfectly fine in the Vara Thumbs Up
The last post was made 11 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 123.24 Kb
