| dreamscape |
 dreamscape Derestricted Danger
 Posted: 20:17 - 23 May 2014 Post subject: Strange Varadero 125 ticking noise - Is this bike doomed? |
Hey all
Bought this bike not long ago for £800... It had a ticking noise which sounds just like tappets so i assumed it was just the clearances so went ahead with buying it...
https://www.xrv.org.uk/forums/attachments/varadero/48137d1395934014-my-new-varadero-125-my-new-issues-1.jpg
https://www.xrv.org.uk/forums/attachments/varadero/48145d1395934033-my-new-varadero-125-my-new-issues-2.jpg
Soon after getting it though I soon realised it had afew issues... most of which are fixed now but one is plaguing me
https://www.xrv.org.uk/forums/attachments/varadero/48153d1395934049-my-new-varadero-125-my-new-issues-3.jpg
Turns out after swapping out both cam chains and also cam chain tensionsers and doing the clearances the tapping noise still remains.
Heres the noise:
https://www.youtube.com/watch?v=JPjIsMa4BEE
Now I'm just curious if anyone else here with a varadero has had this noise? or anyone who could confirm what the noise is? As I'm currently thinking the worsed after taking it to a Honda dealer who told me after all the work i've done already its most likely the big or small ends which either way will involve a new crank... £505 for the crank alone...
They told me the Varadero has issues with condensation building up (when i first removed the cam cover on the front cylinder to do the clearances there was ALOT of milky crap on the cover so I can sadly say this has been the case with mine thanks to the previous owner) They said when this builds up it causes alot of problems with the oil and they have had afew in which have needed new cranks as a result of this issue.
I also read on another forum that the carbed models like mine have an issue with the air box getting water into them because the little clear pipe which is supposed to hold water is way too short. I can confirm mine was full and there was loads of water in the air box water chamber which also seemed to have oil in it (it was milky).
Is this Vara doomed?
Any help or advice greatly appreciated. |
| P. |
 P. Red Rocket
 Posted: 20:25 - 23 May 2014 Post subject: |
https://www.youtube.com/watch?v=gvwjwYJY_u4
My slightly higher revving single 125.
Cam bearing has lunched itself. Safe to say its top end on yours.. likely the valve/cam area. Look before it shits itself. |
| dreamscape |
| P. |
 P. Red Rocket
| dreamscape |
| P. |
 P. Red Rocket
| dreamscape |
| Robby |
 Robby Dirty Old Man
| dreamscape |
| P. |
 P. Red Rocket
| dreamscape |
| gavbriggs |
 gavbriggs Crazy Courier
| P. |
 P. Red Rocket
| gavbriggs |
| dreamscape |
| P. |
 P. Red Rocket
| dreamscape |
| gavbriggs |
| Robster |
 Robster World Chat Champion
 Posted: 09:04 - 28 May 2014 Post subject: |
Mine's doing it as well!
Took mine to the local garage today for an unrelated issue; as its hesitant to rev up and won't set off much faster than walking pace, figured the fuelling/firing is set up wrong.
Garage wasn't impressed by the ticking noise, bloke started looking online for a new engine, giving me numbers in the £££s to fix. etc. etc. left the bike with em today so they can check plugs, valve clearences etc.
This thread makes me feel a bit better, but my engine is very noisy/rattly at idle. If its not an easy fix i'll pass the bike on.
Best of luck with OPs fix  ____________________ Up the bum no babies. |
| P. |
 P. Red Rocket
| Robster |
| Robster |
| P. |
 P. Red Rocket
| Robster |
| P. |
 P. Red Rocket
 Posted: 09:54 - 29 May 2014 Post subject: |
Yeah, it wouldn't cause your engine to mess up. Some bikes don't like them but I'm sure they are perfectly fine in the Vara  |
The last post was made 11 years, 241 days ago. Instead of replying here, would creating a new thread be more useful? |
