Bike feeling wobbly during corners
Lyam
PostPosted: 17:50 - 25 May 2014    Post subject: Bike feeling wobbly during corners Reply with quote
Ever since i changed the tyres to pilot road 3s the bikes been feeling a bit weird during corners, i dont know if it's to do with the tread pattern on the pilot roads flexing more under load? has anyone experienced something similar with pilot roads?
map
Mr Calendar
PostPosted: 17:57 - 25 May 2014    Post subject: Reply with quote
Have you made sure tyre pressure is right?
Have you checked there isn't a different recommend pressure for the pilots on your bike?
I would check simple stuff like that first.
Rigga
PostPosted: 18:05 - 25 May 2014    Post subject: Reply with quote
How new are the tyres? Do they still need scrubbing in?
Current bike: Honda CBR 1100xx
Aff
PostPosted: 18:24 - 25 May 2014    Post subject: Reply with quote
New rubber may have highlighted a head bearing problem you didn't notice because of square tyres.
Electric Bike Project
Lyam
PostPosted: 18:40 - 25 May 2014    Post subject: Reply with quote
Set pressures to standard i will have a look at the head bearing, and the tyres have done about 1000 miles now, im just not enjoying riding the bike, no confidence just doesn't feel as planted as it should, feels like you dance round a corner even when there's not alot of lean angle.
Llama-Farmer
PostPosted: 19:57 - 25 May 2014    Post subject: Reply with quote
Wobbly, or just leans and unleans much easier? Could be the fact that the tyres are much rounder than you're used to. Or it could highlight a wheel bearing or head bearing problem
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
Lyam
PostPosted: 20:03 - 25 May 2014    Post subject: Reply with quote
no definately wobbly, when holding a line it feels as if it's skating about
Llama-Farmer
PostPosted: 21:40 - 25 May 2014    Post subject: Reply with quote
Possibly bearings. Do you have centre stand or paddock stands? If so, check the wheel bearings by getting wheel up in the air and rocking from side to side... shouldn't be any play or knocking. If there is that's your answer.
If there isn't, check head bearing by moving the bars when the front wheel is on the ground... again, play or knocking indicates bad news.
evoboy
PostPosted: 21:45 - 25 May 2014    Post subject: Reply with quote
What pressures are you running exactly?
What bike is it?
APT Motorcycles
Lyam
PostPosted: 00:40 - 26 May 2014    Post subject: Reply with quote
fireblade 954
36F 42R
PostPosted: 00:54 - 26 May 2014    Post subject: Reply with quote
Quick search reveals those pressures to be on the high side. Fine if you're a big lad or carrying a pillion.
Checked those bearings yet? I'd include wheel bearings.
If fine then check compression and rebound settings, check the tyre has been put on the right way...longshot.
Then I'd try lowering the pressures a couple of psi.
UrbanRacer
PostPosted: 01:36 - 26 May 2014    Post subject: Reply with quote
Lyam wrote:
fireblade 954
36F 42R
Those tyres pressures are quite high and will make the bike feel nervous when leant over.
When i had PR3's i ran them at 33F 31R (Cold)
Lyam
PostPosted: 13:46 - 26 May 2014    Post subject: Reply with quote
UrbanRacer wrote:
Lyam wrote:
fireblade 954
36F 42R
im 15 stone, but 15 psi out the rear?
UrbanRacer
PostPosted: 15:32 - 26 May 2014    Post subject: Reply with quote
I've given you a starting point for a person weighing 10.5 stone.
Lyam
PostPosted: 15:58 - 26 May 2014    Post subject: Reply with quote
the bearings seem fine, I'll play about with tyre pressures then and thanks everyone for there help so far
Suntan Sid
PostPosted: 17:17 - 26 May 2014    Post subject: Reply with quote
Have you checked that the tyre rotation arrows are pointing in the right direction?
Had that before, although the fitter noticed it before the wheel went back in!
bladerunner
PostPosted: 18:27 - 26 May 2014    Post subject: Reply with quote
Aye might be worth checking tires are seated correctly and maybe they need a balance not that I'd expect them to need balancing but worth a check if you've done the rotation and bearings check.
Lyam
PostPosted: 19:00 - 26 May 2014    Post subject: Reply with quote
balamcing seems fine, 100+ with no hands it feels straight and smooth.
Lyam
PostPosted: 19:01 - 26 May 2014    Post subject: Reply with quote
bladerunner
PostPosted: 00:16 - 27 May 2014    Post subject: Reply with quote
If everything else has checked out....a new set of rubber and see what happens!
Lyam
PostPosted: 03:16 - 27 May 2014    Post subject: Reply with quote
i just spent 250 on these tyres Sad gonna let my friend ride it and see what he thinks
trevor saxe-coburg-gotha
PostPosted: 04:46 - 27 May 2014    Post subject: Reply with quote
When you say "dance around a corner" do you mean it's twitchy, jumpy, as in going up and down? Because if so that sounds more like a suspension issue rather than either a tyre or head race problem. So have you lost any fork oil? You surely would have noticed - yet from your description of the symptoms I'm still thinking suspension.
Islander
PostPosted: 10:40 - 27 May 2014    Post subject: Reply with quote
UrbanRacer wrote:
Lyam wrote:
fireblade 954
36F 42R
Meh.
I run both my Hornet and my Ducati M900 at 36F 42R and have no problems. The Hornet has PR3s and is rock steady at that pressure.
I'd be looking at suspension and head/wheel/swingarm bearings.
Lyam
PostPosted: 15:28 - 27 May 2014    Post subject: Reply with quote
yeah its twitchy, i havent seen any tell tail signs of fork oil leaking but i did notice the other day the front end feels clunky going over small bumps on the motorway
Jonathan A
PostPosted: 22:06 - 29 May 2014    Post subject: Reply with quote
This probably sounds a bit stupid, could it simply be that the new tyres are new and have no squareness? I found my bike a bit twitchy after a tyre change (I checked all the bearings etc), but got used to it eventually.
Hyosung GT650R
The last post was made 11 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 124.99 Kb
