where to get a long pry bar from
Random13
PostPosted: 06:59 - 27 May 2014    Post subject: where to get a long pry bar from Reply with quote
hi all,
does anyone know where I can get a 1 meter or 1.5 meter breaker or leverage bar ?
I don't want to spend £60 on a socket wrench which is 1 meter rather need some pry bar so can use it in my mechanic works.
sometimes with my 60cm bar it is very hard to move a wishbone etc in a car . need a longer bar.
many thanks
Formerly known as
P.
PostPosted: 07:32 - 27 May 2014    Post subject: Reply with quote
Old exhaust that is being thrown from a garage that swaps exhausts... cheapest place.
Random13
PostPosted: 07:35 - 27 May 2014    Post subject: Reply with quote
do you mean the exhuast pipe ?
it wouldn't be tough enough for the job if above is what you mean
Formerly known as
P.
PostPosted: 07:39 - 27 May 2014    Post subject: Reply with quote
Well, the only breaker bar my dad has is about 40cm long, you simply slide over the scaffold bar/exhaust pipe from a can and you get instant additional leverage.
If it works for my dad to do absolutely everything... I can't see why it wouldn't really work for you.
If you want the right tool for the job, buy the right tool, but if you want to use it once or twice, simple adding a piece of pipe should increase the leverage sufficiently.
andyscooter
PostPosted: 08:09 - 27 May 2014    Post subject: Reply with quote
old scaffold bar cut to decent lenth
map
Mr Calendar
PostPosted: 10:13 - 27 May 2014    Post subject: Re: where to get a long pry bar from Reply with quote
Random13 wrote:
...does anyone know where I can get a 1 meter or 1.5 meter breaker or leverage bar ?...
FWIW RS do galvanised steel tubes. 1000mm x 25mm bore.
See link here, or 2000mm, 25mm bore.
I'm sure available elsewhere if you look. Or ask at local breaker/scrap merchants perhaps?
bugeye_bob
PostPosted: 10:20 - 27 May 2014    Post subject: Reply with quote
slide the trolley jack handle over the T bar wrench
PostPosted: 10:26 - 27 May 2014    Post subject: Reply with quote
I use a fork tube but anything tube like will work.
PostPosted: 10:43 - 27 May 2014    Post subject: Reply with quote
Rigid tow-bar for me.
SQL
PostPosted: 11:37 - 27 May 2014    Post subject: Reply with quote
I use 2.8m scaffold tube
PostPosted: 11:40 - 27 May 2014    Post subject: Reply with quote
Scaffold tube here too.
mudcow007
PostPosted: 12:32 - 27 May 2014    Post subject: Reply with quote
yep ive used scaffolding pipes before now Thumbs Up
evilbond
PostPosted: 12:36 - 27 May 2014    Post subject: Reply with quote
41mm combo spanner, ring end usually does it for me
or a 2.1/2" OD x 1mtr stainless steel tube at work if the going gets tough:D
As to where to get one... give a builder a box of biscuits for for an old scaffold tube :p
Bike: K2 Bandit 600S
Car: Astra GTC
331X2
PostPosted: 14:37 - 27 May 2014    Post subject: Reply with quote
I think OP means a pry bar, not a crack bar/ratchet/allen key extension. Try getting in contact with a machinery moving company, they usually use them for shuffling things into final positions.
Something like this?
https://www.locationequipmentsupply.com/img/products/LES-0000-L-Pry-Bar.jpg
Bezzer
PostPosted: 15:01 - 27 May 2014    Post subject: Reply with quote
They usually call the large pry/crowbars wrecking bars. Screwfix, builders merchants etc do them
https://www.screwfix.com/c/tools/wrecking-crow-bars/cat831062
Busa1340R
PostPosted: 16:19 - 27 May 2014    Post subject: Reply with quote
Machine Mart are also good/reasonably cheap for that kind of thing........😉
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
PostPosted: 22:18 - 27 May 2014    Post subject: Reply with quote
Ah.
Do you know any farmers?
You need an old tine off a front-end loader. Most will have a few lying about.
Random13
PostPosted: 09:53 - 31 May 2014    Post subject: Reply with quote
@ lee wright,exactly what I was looking for. I have the 0.5 meter one and shall get the 1 meter one from screw fix.
on ebay it is something stupid like £40 which is not worth it
PostPosted: 10:19 - 31 May 2014    Post subject: Reply with quote
stinkwheel wrote:
Ah.
Didn't you just banhammer a begging pikey?
331X2
PostPosted: 22:02 - 31 May 2014    Post subject: Reply with quote
Ask any ex miners you might know, my dads came from the pit...
Raffles
PostPosted: 22:39 - 31 May 2014    Post subject: Reply with quote
Off-topic but I notice that you're from The Nottinghamshire area. Was/is your father a scab?
331X2
PostPosted: 10:38 - 01 Jun 2014    Post subject: Reply with quote
Do you mean in relation to the strikes? What makes you ask? Never really spoke about it in detail but I know he said things were a struggle financially in that time.
Random13
PostPosted: 13:29 - 02 Jun 2014    Post subject: Reply with quote
thanks, actually found this
https://www.amazon.co.uk/Silverline-PC64-Wrecking-Bar-900mm/dp/B000LFRRD2/ref=sr_1_1?ie=UTF8&qid=1401715728&sr=8-1&keywords=wrecking+bar+900mm
Jim Mc
PostPosted: 17:43 - 02 Jun 2014    Post subject: Reply with quote
Costco used to do a set called 'Gorilla Bars', set of three with the longest around 1m long.
Also on amazon: https://www.amazon.co.uk/Roughneck-64410-Gorilla-Bar-48-inch/dp/B0007YW2B4/ref=sr_1_4?ie=UTF8&qid=1401731034&sr=8-4&keywords=gorilla+bars
The last post was made 11 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 122.26 Kb
