Fork Pinch Bolt (Allen Head) truly fubared.
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4  Next
iMark
PostPosted: 17:31 - 28 May 2014    Post subject: Fork Pinch Bolt (Allen Head) truly fubared. Reply with quote
https://i.imgur.com/88idr1B.jpg
So, the fork seals are shot and I have my MOT in just over a week and I can't get this bloody pinch bolt out...
Tried hammering progressively bigger torx bits in and it still won't turn (it's been done up way too tight, a lot more than the manufacturers recommended 20nm!)
Trying to turn it just strips it out further or the torx bit doesn't want to grip inside.
Tried hammering it with a big flat head screwdriver to break it loose and it's still not budging even after several good whacks with a hammer at an angle to knock it counter clockwise and still no luck.
Any ways onto my actual question
Would welding a nut on to the top of the pinch bolt work or is that just going to snap the head off it?
Or would I be better drilling the head off it and drilling a smaller hole in the actual thread once the head is off the bolt and forcing a another torx bit into the threaded part only?
K8 GSXR 1000
CaNsA
PostPosted: 17:33 - 28 May 2014    Post subject: Reply with quote
One of the two will always be easier to undo.
If the one on the left is super tight, then the one on the right will be less tight. Unless you do them up at the same time.
Try tightening the one on the right a tiny bit, then give the left one another try.
P.
PostPosted: 17:51 - 28 May 2014    Post subject: Reply with quote
If you not manage to get it out and MOT time comes round... fit some gaiters. Don't remove the forks, just cut plastic gaiters vertically, wrap around fork, compress and cable tie them top bottom and 2 in the middle.
Obviously you'll need to sort the seal but will buy you some time and keep you on the road
PostPosted: 17:52 - 28 May 2014    Post subject: Reply with quote
I'd go for a left hand drill bit but then I've got a set. A worthwhile investment if you plan on working on bikes.
iMark
PostPosted: 18:00 - 28 May 2014    Post subject: Reply with quote
I bought some of these neoprene fork savers to do that Paddy, but I still need to take the forks off the bike to get them on which I don't have a yoke paddock stand for that, so I may resort to just laying the bike on it's side while I take the front end off the bike to get them on.
Obviously I don't want to leave the fork seals leaking though Smile
Tried tightening the other one, no avail, hammering it is just cutting the head off the bolt Laughing
https://i.imgur.com/q5VoWXR.jpg
https://i.imgur.com/Tpi9My5.jpg
K8 GSXR 1000
P.
PostPosted: 18:02 - 28 May 2014    Post subject: Reply with quote
Got car jack? Block of wood under sump, jack up, axle stands under engine. Boom.
I'm too lazy to get full on stands to do so. Thumbs Up
PostPosted: 18:03 - 28 May 2014    Post subject: Reply with quote
They are through-bolted. A right hand drill will do the same job.
I'd apply penetrating oil to both sides of the bolt for a couple of days. Then I'd apply lots of direct heat to the alloy casting using a blowlampand try tapping it round with a hammer and punch or impact driver.
If I was going to drill it, I'd hacksaw the bolt in half from underneath. The "front" half of the clamp isn't threaded so that bit of bolt should come out. I'd then find a bit of metal tube that fits in the hole to use as a drill guide so it's dead square. Once you've drilled some way into it, I'd expect the drill bit to bite and screw the stub out through the back of the clamp.
EDIT: Hacksawing the dodgy one in half then simply clamping it together with one bolt and gluing a cut-down bolt head in the other hole to get it through the MOT would be an horriffic bodge that i simply could not condone. I would NEVER glue a bolt head to my bike in order to conceal a sheared, non-critical bolt from an MOT tester because you're only cheating yourself by doing such a thing.
Fisty
Heat. Lots of heat..
Fatter and faster than Fret
iMark
PostPosted: 18:08 - 28 May 2014    Post subject: Reply with quote
I wish I had a car jack Rolling Eyes
Kind of stuck with primitive techniques for this one..
Don't have any thing that can heat it up either Rolling Eyes the torch I had decided to stop working!
Using a normal RH drill bit from the wrong end makes a bit of sense Thumbs Up
Don't think I can hacksaw it from underneath stink, the bolt isn't fully exposed from underneath, half of it is still inside the alloy casting of the fork, but I have had WD40 sprayed on it from all angles a few days ago from the head, underneath and at the back.
Hammering it after trying to tighten the other bolt didn't work, I'm actually cutting off the head of the bolt trying to get it undone that way Sad
EDIT:
Wait a minute, I understand what you mean by hacksawing it now, cus of the grove in the actual pinch part of the fork Thumbs Up Karma
K8 GSXR 1000
PostPosted: 18:13 - 28 May 2014    Post subject: Reply with quote
I mean hacksawing up through the "split" of the clamp. Then you only have half as much bolt to drill through compared to starting at the head. That split should go all the way up to the hole for the spindle.
iMark
PostPosted: 18:17 - 28 May 2014    Post subject: Reply with quote
Yeah, I figured that out after reading it again and edited the post hehe Very Happy
Will give that a shot, dunno if I'll attempt that tonight though as it's starting to rain Thumbs Down
K8 GSXR 1000
SQL
PostPosted: 19:16 - 28 May 2014    Post subject: Reply with quote
lift dust seals and use a seal mate, if that doesn't work get to MOT station ten mins early then kitchen roll under the dust seal replace dust seal
iMark
PostPosted: 19:36 - 28 May 2014    Post subject: Reply with quote
Pinch bolt no longer has the grip of death, Cut through it with a hacksaw blade... Only took about an hour cus of the tiny bit of movement I could do Rolling Eyes
So I should be able to get the axle nut thing off from that side now to get the fork seals done Thumbs Up
Will remove the rest of the bolt when I get chance, one pinch bolt is enough Mr. Green
Currently it's not letting me pull it out, it's just turning the hole , pliers won't grip it very well in that position so it can stay there for now!
Big thank you for that suggestion Stinkwheel Karma
https://i.imgur.com/ZDr7mBH.jpg
K8 GSXR 1000
CaNsA
PostPosted: 20:43 - 28 May 2014    Post subject: Reply with quote
iMark wrote:
I am going to die on the way to the MOT station
EFA Thumbs Up
iMark
PostPosted: 21:04 - 28 May 2014    Post subject: Reply with quote
both parts of the bolt are still in, the part with the head is turning but won't pull out with pliers, so I can't get a drill in to thread the other part out at the moment.
Will need to wait for daylight to remove it Smile
K8 GSXR 1000
Raffles
PostPosted: 21:36 - 28 May 2014    Post subject: Reply with quote
Don't forget to tell the lawyers that it was Stinky who suggested that you hold everything together with Blu-Tack.
1cyl
PostPosted: 21:42 - 28 May 2014    Post subject: Reply with quote
Glad to see progress has been made Thumbs Up .
Perhaps now you could try and gingerly knock the tip of a sharp flat head in underneath the head of whats left of the bolt, for leaverage while attempting to wind it out.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
bugeye_bob
PostPosted: 22:00 - 28 May 2014    Post subject: Reply with quote
I know it needs to come out one day but id have borrowed a trolley jack and bit of wood to support the bike and just changed the fork seals with the wheel attached, drop the forks out the yokes and do what you need to do,
Gets you sorted safely for the MOT with no risks imo.
iMark
PostPosted: 22:44 - 28 May 2014    Post subject: Reply with quote
There is a thing inside the forks that stops them over extending and ripping out the fork seals which is held at the bottom by a bolt underneath the fork above where the nut is that holds the axle in place on that fork so the pinch bolt needed to be removed to be able to replace the fork seals Smile
Else this would have been a lot easier Mr. Green
K8 GSXR 1000
PostPosted: 23:04 - 28 May 2014    Post subject: Reply with quote
Use an old cheap flat blade screw driver. Put the blade in the slot you have cut in the bolt and twist. Hopefully should push the head of the bolt out.
PostPosted: 23:06 - 28 May 2014    Post subject: Reply with quote
merquis00
PostPosted: 23:10 - 28 May 2014    Post subject: Re: Fork Pinch Bolt (Allen Head) truly fubared. Reply with quote
https://media.tumblr.com/tumblr_m4rkvlSocZ1qb8lzh.jpg
Current: 2010 WR125X, Carrera crossfire-E.
Project's: '88 GL1500 Trike, Chinese 170cc Monkey
Previous: X9-500, XT125, DNA125, CBF125, YZF-R125, '98 K1200RS, '99 St1100, fantic245
The last post was made 11 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 133.39 Kb
