| iMark |
 iMark World Chat Champion
 Posted: 17:31 - 28 May 2014 Post subject: Fork Pinch Bolt (Allen Head) truly fubared. |
https://i.imgur.com/88idr1B.jpg
So, the fork seals are shot and I have my MOT in just over a week and I can't get this bloody pinch bolt out...
Tried hammering progressively bigger torx bits in and it still won't turn (it's been done up way too tight, a lot more than the manufacturers recommended 20nm!)
Trying to turn it just strips it out further or the torx bit doesn't want to grip inside.
Tried hammering it with a big flat head screwdriver to break it loose and it's still not budging even after several good whacks with a hammer at an angle to knock it counter clockwise and still no luck.
Any ways onto my actual question
Would welding a nut on to the top of the pinch bolt work or is that just going to snap the head off it?
Or would I be better drilling the head off it and drilling a smaller hole in the actual thread once the head is off the bolt and forcing a another torx bit into the threaded part only? ____________________ K8 GSXR 1000
"G" : you got him to have a look at a forum which seems to have established a picture of an erect penis in a cat's mouth as it's mascot and thought he might consider it ok? |
| CaNsA |
 CaNsA Super Spammer
| P.addy |
 P.addy Formerly known as P.
 ........................ Spanner Monkey
| iMark |
 Posted: 18:00 - 28 May 2014 Post subject: |
I bought some of these neoprene fork savers to do that Paddy, but I still need to take the forks off the bike to get them on which I don't have a yoke paddock stand for that, so I may resort to just laying the bike on it's side while I take the front end off the bike to get them on.
Obviously I don't want to leave the fork seals leaking though
Tried tightening the other one, no avail, hammering it is just cutting the head off the bolt
https://i.imgur.com/q5VoWXR.jpg
https://i.imgur.com/Tpi9My5.jpg ____________________ K8 GSXR 1000
| P.addy |
 Posted: 18:02 - 28 May 2014 Post subject: |
Got car jack? Block of wood under sump, jack up, axle stands under engine. Boom.
I'm too lazy to get full on stands to do so.  |
| Fisty |
 Fisty Super Spammer
| iMark |
 Posted: 18:08 - 28 May 2014 Post subject: |
I wish I had a car jack
Kind of stuck with primitive techniques for this one..
Don't have any thing that can heat it up either the torch I had decided to stop working!
Using a normal RH drill bit from the wrong end makes a bit of sense
Don't think I can hacksaw it from underneath stink, the bolt isn't fully exposed from underneath, half of it is still inside the alloy casting of the fork, but I have had WD40 sprayed on it from all angles a few days ago from the head, underneath and at the back.
Hammering it after trying to tighten the other bolt didn't work, I'm actually cutting off the head of the bolt trying to get it undone that way
EDIT:
Wait a minute, I understand what you mean by hacksawing it now, cus of the grove in the actual pinch part of the fork  ____________________ K8 GSXR 1000
| Vincent |
 Vincent Banned
| iMark |
 Posted: 18:17 - 28 May 2014 Post subject: |
Yeah, I figured that out after reading it again and edited the post hehe
Will give that a shot, dunno if I'll attempt that tonight though as it's starting to rain  ____________________ K8 GSXR 1000
| SQL |
 SQL World Chat Champion
| iMark |
 Posted: 19:36 - 28 May 2014 Post subject: |
Pinch bolt no longer has the grip of death, Cut through it with a hacksaw blade... Only took about an hour cus of the tiny bit of movement I could do
So I should be able to get the axle nut thing off from that side now to get the fork seals done
Will remove the rest of the bolt when I get chance, one pinch bolt is enough
Currently it's not letting me pull it out, it's just turning the hole , pliers won't grip it very well in that position so it can stay there for now!
Big thank you for that suggestion Stinkwheel
https://i.imgur.com/ZDr7mBH.jpg ____________________ K8 GSXR 1000
| CaNsA |
 CaNsA Super Spammer
| Vincent |
 Vincent Banned
| iMark |
 Posted: 21:04 - 28 May 2014 Post subject: |
both parts of the bolt are still in, the part with the head is turning but won't pull out with pliers, so I can't get a drill in to thread the other part out at the moment.
Will need to wait for daylight to remove it  ____________________ K8 GSXR 1000
| Raffles |
 Raffles World Chat Champion
| 1cyl |
 1cyl World Chat Champion
 Posted: 21:42 - 28 May 2014 Post subject: |
Glad to see progress has been made .
Perhaps now you could try and gingerly knock the tip of a sharp flat head in underneath the head of whats left of the bolt, for leaverage while attempting to wind it out. ____________________ Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable |
| bugeye_bob |
| Vincent |
 Vincent Banned
| iMark |
| merquis00 |
 merquis00 Nova Slayer
The last post was made 11 years, 263 days ago. Instead of replying here, would creating a new thread be more useful? |
