| sabian92 |
 sabian92 World Chat Champion
 Posted: 18:43 - 02 Jun 2014 Post subject: G&C Motorcycles Preston UPDATE: Bike died |
Evening BCF,
Not long got back from visiting my brother and attempting to troubleshoot his bike. He's got a 1992 GPZ500 that he's had about 4 weeks but isn't allowed to ride yet (not long turned 19, he's got his mod 2 tomorrow), and has been itching to ride it since he was taken pillion on it before he bought it and brought it home.
2 weeks ago the clutch stopped working. Bike would start in neutral, pull the clutch in and select first and it'd jerk forward and stall every time without fail. We had the tank off, various bits of bodywork, adjusted the clutch cable, until I noticed that he had a little window to have a gander at his oil (and honestly, I wouldn't have noticed had my instructor not pointed it out when I was noseying at his new GXSR1200), only to notice it was a little too clear. So clear in fact, it looked like it was empty. he unscrewed the filler cap, scraped his finger around and it was dry. Not even a thin coating of oil, it was drier than a nun's gash.
Googled how much oil it took, nipped home and gave him the 4 litres of 10W40 I had left and it took the whole lot, so it was clearly pretty fucking empty. Screwed the filler cap back on, started it up, gave it 5 minutes to warm the oil through, and waddya know... it goes into gear and he rides away.
It's his first big bike (and we're both as handy with a spanner as a corpse) and we didn't have a Haynes but still, what sort of dealer doesn't put oil in a bike or at least check there's oil in it when they take it to sell? To be fair the dealer fobbed him off by lying to him about the state of the bottom fairing as it's cracked to buggery anyway, but he was too naive to check.
Lesson learned for him, always check there's oil in!
Serious question though, it's been ridden once and run a few times without oil - what sort of damage could be lurking in there? I advised him to change the oil ASAP as it looked pretty filthy once we'd filled it up.
He bought it from G&C Motorcycles in Preston - Annsdale, Coote Lane, Whitestake, Preston, PR4 4LJ.
Avoid these utter spackers.
| Shinigami |
 Shinigami World Chat Champion
 Posted: 18:49 - 02 Jun 2014 Post subject: |
ran without oil
 ____________________ Current: Honda City Fly CLR125 2003 Honda CB600F Hornet 2008 Yamaha FZ6 S2 + 1991 Kawasaki GPZ500
"Once you realize what a joke everything is, being the Comedian is the only thing that makes sense. |
| beardface |
 beardface Spanner Monkey
 Posted: 19:04 - 02 Jun 2014 Post subject: |
They teach you how to check oil on cbt and das ffs
You should of checked it in the shop tbf. |
| Alex A |
 Alex A World Chat Champion
| sabian92 |
| Alex A |
| sabian92 |
 Posted: 19:52 - 02 Jun 2014 Post subject: |
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:24 - 02 Jun 2014 Post subject: |
Ah, another "peace of mind" purchase from a dealer.
I'd expect you've got the square root of sod all chance of returning it because there might be something wrong with it.
If there's actually something wrong with it, something that another garage could identify and quote for repairing, then you might be on to something. Is there?
Expect a fair amount of clutch basket rattle from it. Does it quieten down at all when you pull the clutch in? ____________________ Biking is 1/20th as dangerous as horse riding.
| stinkwheel |
 Posted: 20:25 - 02 Jun 2014 Post subject: |
I have a strong suspicion you have overfilled the sump on that bike and you should ride it no further until you have checked because it could cause severe and permanant damage to the engine.
Couple of points to explain why.
The first of these is that a GPZ500 has a red, low oil pressure warning light on the dash. It ought to come on with the ignition and turn off when the oil pressure forces the switch back out (ie. as soon as it turns over, one engine revolution is normally sufficient).
If was so low it took 4l of oil, the oil light would 100% definately stay on. So either the oil pressure light is broken OR it was staying on and you ignored it OR (my personal suspicion) there was sufficient oil to give a head of pressure.
I wouldn't expect to be able to reach oil with my finger through the filler cap on that bike and I have long fingers. If you can now, the sump is too full.
A GPZ500 engine holds 3.8 litres of oil from TOTALLY empty. By totally empty, I mean a freshly rebuilt engine which has been degreased then reassembled. It would hold less if there was some oil hanging about. This is from experience of having stripped one to the crank then rebuilt it and having enough oil left in a 4l drum for topping up. Under normal circumstances I wouldn't expect it to even take as much as 3.5l and that would be with a filter change.
So. My suggestion. First check the oil light comes on with the ignition and goes out as soon as you push the starter button. I'd switch it off as soon as you see this happen at this point.
Next get the bike level and on the mainstand and double check the top of the oil level is visible between the lines on the sight glass with the engine off because I strongly suspect you have over filled it. If nothing else, 4 litres seems like way too much oil.
You can usually get an open spanner on the sump bolt or a socket and extension bar if you gently push the header over to one side slightly. Failing that, you ought to be able to (carefully and slightly) loosen the header and exhaust clamps and move it all slightly one way or the other.
A lack of oil would not make it stall in gear. Not immediately anyway, a motorcycle clutch will work for a fair while dry before it starts burning plates, then it would tend to slip and smoke if anything (I have deliberately run the primary/clutch dry when drag racing the Enfield before). The EX500 engines are well known for the clutch plates sticking when parked up for a while though.
If it had run low on oil, I'd expect the main bearings and cam surface to be the first to suffer. The latter is reasonably easy to visually check but does involve draining down the coolant and replacing a couple of o-rings. Checking the mains is more toruble than the bike is worth.
If it had been ridden 15 miles while being underfilled by 4 litres, it would have died. I'm sure of it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| iooi |
 iooi Super Spammer
 Posted: 20:29 - 02 Jun 2014 Post subject: |
4ltrs....
That is a lot for a bike.
I would get a manual and check just how much should be in there..... ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| J4mes |
 J4mes World Chat Champion
| sabian92 |
 Posted: 20:38 - 02 Jun 2014 Post subject: |
| Rogerborg wrote: |
Expect a fair amount of clutch basket rattle from it. Does it quieten down at all when you pull the clutch in? |
Honestly, I couldn't tell you off hand. It might do, but it wasn't dead obvious.
| stinkwheel wrote: | *words*. |
I should have explained, I gave him the 4 litres I had, but we didn't actually just dump 4 litres into the bike He looked up how much it took and we put that in (3.4 litres). I should have been more clear. We did it with a measuring jug anyway, so it was definitely right.
| iooi wrote: | 4ltrs....
I would get a manual and check just how much should be in there..... |
See above I didn't actually just whack 4 litres in.
| J4mes wrote: | Oh my you're gonna look like an almighty wanker if Stinkster is right!! |
I am, but I'm pretty sure he isn't (I hope ) I've already dropped his GPZ as well, when I tried to rock it off the centre stand
Honestly, it did look bone dry. I'm talking like having to scrape what was left out with a spoon. The viewing window was entirely white as well, even on the slant (they live on a fairly steep hill, and the window was pointing down hill), and it certainly didn't smell very engine oil-y.
It just seems very coincidental that it rode fine when he got it, stopped going into gear eventually then as soon as it's filled with oil it engages properly again.
| groovylee |
 groovylee World Chat Champion
| stinkwheel wrote: | I have a strong suspicion you have overfilled the sump on that bike and you should ride it no further until you have checked because it could cause severe and permanant damage to the engine.
If it had been ridden 15 miles while being underfilled by 4 litres, it would have died. I'm sure of it. |
this man speaks the truth - I got nowhere near 4 litres in mine at the last service.......  ____________________ Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R |
| Alex A |
| Joncrete Cungle |
 Joncrete Cungle World Chat Champion
 Posted: 20:56 - 02 Jun 2014 Post subject: |
If your brother needs a honest bike mechanic. The only ones in the Preston area I trust and use myself are Dave Helm on the docks and John Carr up at Garstang.  |
| Kickstart |
 Kickstart The Oracle
| stinkwheel |
 Posted: 21:04 - 02 Jun 2014 Post subject: |
I'm still interested in the oil pressure light.
Is it working? Was it staying on? It turns off when the pressurised oil feed from the pump forces a spring-loaded switch out. It's bright, red and pretty intrusive on the dash, I'd expect someone who was sat on their new bike with the engine running to wonder what it is and why it's lit.
If it was going out when the bike was fired up, there was probably sufficient oil pressure to feed the cams and mains.
If the sight glass was full of white mayonaise, how did you know how much oil to put in? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sabian92 |
| Quornholio |
 Quornholio World Chat Champion
| mailee |
 mailee Spanner Monkey
 Posted: 01:11 - 03 Jun 2014 Post subject: |
My mate bought a Daytona from them. It took a lot of starting when we went to look at it but assumed this was being stood a long time. It continued to be a hit and miss starter all the time he owned it and he couldn't trust it. It ended up not starting at all and he sold it for spares. Not a happy lad at all.  |
| TUG |
 TUG World Chat Champion
| sabian92 |
 Posted: 09:21 - 03 Jun 2014 Post subject: |
| Mk1GSF wrote: | My old chap bought a bike from them, and had no problems at all with it. Yes, they're tatty, but you're not paying 2014 R1 prices are you?  |
No, but regardless of if you pay 12k for an R1 or under 1k for a 21 year old GPZ, you expect it to be sold with oil in it, even if it's manky and needs changing.
Selling a bike with no oil in it isn't tatty, it's downright negligent. If it was sold as spares or a project then fair enough, but I'd still expect the seller to mention it - "It's got no oil in it, so don't start it without filling it up, by the way" takes less than 5 seconds to mention. I suspect it had been sat in their shop a while and wanted rid of it.
| mailee wrote: | My mate bought a Daytona from them. It took a lot of starting when we went to look at it but assumed this was being stood a long time. It continued to be a hit and miss starter all the time he owned it and he couldn't trust it. It ended up not starting at all and he sold it for spares. Not a happy lad at all.  |
See, that's the thing, it's mechanically sound (at least from what we can see), it starts first time, it's had new chain/sprockets fitted, it just had zero oil in it. I'm guessing somebody was changing it then forgot to refill it and it was sold like that.
| TUG wrote: | I live near Preston, my bike is currently off the road (same engine as yours) but if you still have it in a few weeks and want it looking at let me know and I could come take a look. PM me if you want a hand. |
Cheers for the offer but we don't live in Preston, we're in Runcorn on the M56. My uncle is a mechanic so he'll probably take it to him once he's passed (mates rates and all that ) |
| chris-red |
| Quornholio |
| chris-red |
The last post was made 11 years, 352 days ago. Instead of replying here, would creating a new thread be more useful? |
