Removing rubber/plastic off an exhaust?
EazyDuz
PostPosted: 15:54 - 05 Jun 2014    Post subject: Removing rubber/plastic off an exhaust? Reply with quote
What is the best way?
I read on US forums that a product called 'goof off' is supposed to be good. I tried it on a cold and hot pipe and it did next to nothing.
I'm hesitant to use 0000 grade wire wool as that would be the most abrasive.
So I did read oven cleaner works well, anyone had experience with this? Of so any particular brand?
Thanks
Moxey
PostPosted: 16:46 - 05 Jun 2014    Post subject: Reply with quote
I've used a heat gun before to heat it up then scrape it off once its become viscous, try running the bike and getting it hot enough if you don't have access to a heat gun.
fatjames
PostPosted: 19:23 - 05 Jun 2014    Post subject: Reply with quote
Is this melted textiles on the exhaust bend on the virago? I had that, couldn't get it off so wrapped the exhaust! (then got a mans bike.. Wink )
EazyDuz
PostPosted: 19:30 - 05 Jun 2014    Post subject: Reply with quote
No its on my new bike which came with some louder pipes. The colour is kind of light browny looking quite high up (suggests leg touched it). I know wire wool and elbow grease will get it off but its a bit iffy. They're Vance and Hines pipes and they're pretty mint apart from the burnt shit.
Llama-Farmer
PostPosted: 19:32 - 05 Jun 2014    Post subject: Reply with quote
Get it off with something abrasive like fine grit glass paper and keep using a finer grit then autosol/wire wool until it's polished out?
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
ZRX61
Victor Meldrew
PostPosted: 19:36 - 05 Jun 2014    Post subject: Reply with quote
Razor blade used as a scraper.
They're not one night stands, they're auditions.
delsol
PostPosted: 19:51 - 05 Jun 2014    Post subject: Reply with quote
Scalpel, much care, much patience and autosol.
Rush it and minor scratches in chrome make you wish you had not rushed it.
Takes less than a second to make a scratch, feels like eons to polish the scratch out.
yen_powell
PostPosted: 19:53 - 05 Jun 2014    Post subject: Reply with quote
I have heard that getting it hot and using oven cleaner is good.
XT1200Z and a DR350 in bits
i.p.phrealy
PostPosted: 23:17 - 06 Jun 2014    Post subject: Reply with quote
but enough about what you get up to in the bedroom! Wink
as far as the exhaust goes, try cheap poundshop nail polish remover, it's mostly acetone.
ripzay
PostPosted: 00:14 - 07 Jun 2014    Post subject: Reply with quote
Depending on whether it is actually plastic, and also on the type of plastic.. You could try acetone (from a pharmacy (strong solution) , not a supermarket)
Current: 2005 KTM SuperDuke 990
Previous: 1996 Suzuki Bandit 600
Previous: 1994 Suzuki GSX-R 400
Suntan Sid
PostPosted: 00:28 - 07 Jun 2014    Post subject: Reply with quote
I got some melted plastic off a stainless steel link pipe using a stanley knife blade, to scrape the worst off, the rest polished off with Autosol, a plastic scourer and elbow grease.
The whole process took about 40 mins and left no scratches!
The last post was made 12 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 67.57 Kb
