| Mark65 |
 Mark65 World Chat Champion
 Posted: 19:41 - 06 Jun 2014 Post subject: New Cush Drive Bushes |
So at the start of the month I replaced my little CG125 cush rubbers with a set from Wemoto, 500 miles later my chain started snatching after adjustment so I remove the wheel and find this waiting for me.
The rubber had crumbled and the inners were still on the sprocket carrier, it took nearly a day to remove the old Hondas rubbers but these came out in 15 min, the metal was like cheese, Wemoto has already sent replacements but I don't know whether to use them, I think I may have to bite the bullet and buy Honda ones. Good job I did these and had not upplied them to a garage or I would be facing another bill.
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| Mark65 |
| arry |
 arry Super Spammer
| Mark65 |
 Posted: 16:09 - 07 Jun 2014 Post subject: |
| arry wrote: | I have some from wemoto to change out the ones on the Ybr - hope they're not made of similar dairy products! |
Ybr ones are completely different m8 just triangle shaped rubber blocks, mine are like bushes with metal inner and outer, also ybr is piss easy to change, mine have to be drilled, chiseled and or dremeled lol.
| mattfender666 |
 mattfender666 Nova Slayer
| map |
 map Mr Calendar
 Posted: 14:33 - 09 Jun 2014 Post subject: |
Your thread is timely as I need some fork seals and bushes.
Price wise I'd be better of getting aftermarket/non-branded.
Except I've heard a few horror stories of non-branded and it's a job I don't really want to do after only a few weeks.
BTW I was thinking of sourcing from Wemoto as I've had good service from them before. I'm thinking it'd save eBay supplier/quality guesswork (who aren't that much cheaper anyhow). ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Mark65 |
 Posted: 19:36 - 09 Jun 2014 Post subject: |
I think the first ones i got were a cheap version, the replacements were more meaty on the metal area and the inner was longer at one side to allow for the cup shape in the hub, also they needed tapping in with a socket but these were £12 each not £12 for four, so possibly Honda quality. To be fair this is the first problem with a product from them and they sorted it straight away, so buy from them in confidence or call them to check if you need info.
On the plus side I won a genuine Honda o-ring chain and sprocket kit for my CG on egay for £16 , away in a draw now for when my current set wears out.
| map |
 map Mr Calendar
| Mark65 |
 Posted: 08:41 - 10 Jun 2014 Post subject: |
It does indeed  ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
There is a gap of 347 days between these two posts... |
| Mark65 |
 Posted: 20:37 - 23 May 2015 Post subject: |
Well I have resurrected this post as my replacements have disintegrated, these where the £40 set from Wemoto that Ralph sent me, just under 12 months old so now I will need to order Honda ones, I expected a few years at least. only done about 6k on them, and spent 2 hours chiseling them out again so for any one else try Honda parts first.
The last post was made 11 years, 127 days ago. Instead of replying here, would creating a new thread be more useful? |
