My Honda CG125 51plate
jenkatz68
PostPosted: 18:21 - 08 Jun 2014    Post subject: My Honda CG125 51plate Reply with quote
Hi, Im a girl and am having trouble with my bike!!! The bike is over run, in that, when you shut off the throttle the engine keeps revving!!!
Is this to do with the mixture screw, or air getting into the carb?
What do you reckon?
Any advice gratefully received
Love Jen xx Embarassed
DMCpro
PostPosted: 19:57 - 08 Jun 2014    Post subject: Reply with quote
Can you post a video?
Seen it before with these bikes where the throttle slider has been put back on the wrong way round
Honda CB-1, TS125X
VW Golf Estate
moonzoomer
PostPosted: 20:18 - 08 Jun 2014    Post subject: Reply with quote
Check for air leaks between the carb and the cylinder head, it is not uncommon for the manifold/heatshield to crack or work loose.
Davo
Davo To The Rescue!
PostPosted: 21:21 - 08 Jun 2014    Post subject: Reply with quote
The test I used to use for extra air being sucked in to the carb/inlet manifold is to let the bike idle & spray a little bit of WD40 on the rubber tubing
If the engine revs up when you do this it's sucking in air there. Then you just need to check the condition of the rubber & the tightness of the jubilee clips etc..
moonzoomer
PostPosted: 21:27 - 08 Jun 2014    Post subject: Reply with quote
The cg 125 tends to have a solid plastic inlet manifold which can crack due to expansion /overtightening or age, this manifold is simply slipped over the 6mm carb mounting studs which can also work loose. I agree with the WD40 on the rubber inlet manifolds, works a treat.
Mark65
PostPosted: 07:08 - 09 Jun 2014    Post subject: Reply with quote
Sticking accelerator cable?, frayed a touch maybe.
Mark
davebike
PostPosted: 08:41 - 09 Jun 2014    Post subject: Reply with quote
If you had the throttle cable off slide in wrong way around
If the slide is sitting properly and returning as it should it will be an air leak
What have you had apart??
Dave
Dave
NC750Xdct + others at work !
davebike1@gmail.com
jenkatz68
PostPosted: 09:58 - 09 Jun 2014    Post subject: Reply with quote
Aww thanks guys will give each of these tips a go!
Thanks for your help, will let you know result
xx Jen xx
The last post was made 11 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 54.06 Kb
