| MudSweatnGear... |
 MudSweatnGear... Two Stroke Sniffer
 Posted: 13:20 - 09 Jun 2014 Post subject: Scooter Headache |
Hi Guys,
Been racking my brains over a Kymco Super 9 (50cc) Scooter that just will not start... Ive been working through the possible problem but cant seem to find it.
Ive had the carb out, cleaned, rebuilt. Reeds Checked ( No Problems at first sight ), and replaced the plug and coil with a known working coil.
I seem to be getting spark, so I have ruled that out so far.
Im getting fuel to the carb, but from what I can see im not getting fuel to the plug, I crank the engine for 5-10secs and inspect the plug but it is dry as a nuns hoohaa.
Im thinking that it could be rings, but then the scoot has only done a relatively low milage.
Anybody got some knowledge with these things???
All the best! ____________________ www.adrenaline-motorcycles.com. |
| map |
 map Mr Calendar
 Posted: 13:36 - 09 Jun 2014 Post subject: |
Has scoot overheated in the past and maybe nipped up (siezed) the piston? (as I've said before, I hate working on 2-strokes). ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| evoboy |
 evoboy World Chat Champion
 Posted: 13:59 - 09 Jun 2014 Post subject: |
Sounds like the carb is blocked.
Put a drop of fuel in the plug hole then try to start it.
If it starts, you need to strip the carb down for a clean. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| MudSweatnGear... |
 Posted: 14:01 - 09 Jun 2014 Post subject: |
Could be a real possibility, I have no idea about the history of the scoot, but the poor thing has been tucked up in a farm barn with cows to keep it company... ____________________ www.adrenaline-motorcycles.com. |
| MudSweatnGear... |
 Posted: 14:08 - 09 Jun 2014 Post subject: |
Evoboy:
I forgot to mention that I tried that earlier today. Again when i squirt a little fuel in it almost seems like the plug is dry after cranking. Not even getting a hint of it starting. ____________________ www.adrenaline-motorcycles.com. |
| evoboy |
 Posted: 15:58 - 09 Jun 2014 Post subject: |
Pull the head and barrel off.
Itll probably be ruined inside. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| jjdugen |
 jjdugen World Chat Champion
| MudSweatnGear... |
 Posted: 20:39 - 09 Jun 2014 Post subject: |
Evoboy: Im getting the same feeling, will inspect the barrel/head tomorrow sometime, will try and post up some pics.
jjdugen: could well be adding to the problem; it does certainly seem that the poor thing has had a hard up-bringing.
Thanks for the help everyone!  ____________________ www.adrenaline-motorcycles.com. |
| craisin |
 craisin Derestricted Danger
| MudSweatnGear... |
 Posted: 12:22 - 11 Jun 2014 Post subject: |
So heres the Sit-Rep so far:
Dug out my compression tester, fitted and turned over the engine, At first I though I had not fitted the tester properly because it just lifted the needle off its rest. Checked and tightened and same again... not even registering a number Whilst I had the tester in a sprayed the crankcase with soapy water, turned the engine over and its blowing all over the shop.
RUST IN PEACE Scooter. I think you deaad. ____________________ www.adrenaline-motorcycles.com. |
The last post was made 11 years, 235 days ago. Instead of replying here, would creating a new thread be more useful? |
