Scooter Headache
MudSweatnGear...
PostPosted: 13:20 - 09 Jun 2014    Post subject: Scooter Headache Reply with quote
Hi Guys,
Been racking my brains over a Kymco Super 9 (50cc) Scooter that just will not start... Ive been working through the possible problem but cant seem to find it.
Ive had the carb out, cleaned, rebuilt. Reeds Checked ( No Problems at first sight ), and replaced the plug and coil with a known working coil.
I seem to be getting spark, so I have ruled that out so far.
Im getting fuel to the carb, but from what I can see im not getting fuel to the plug, I crank the engine for 5-10secs and inspect the plug but it is dry as a nuns hoohaa.
Im thinking that it could be rings, but then the scoot has only done a relatively low milage.
Anybody got some knowledge with these things???
All the best!
www.adrenaline-motorcycles.com.
map
Mr Calendar
PostPosted: 13:36 - 09 Jun 2014    Post subject: Reply with quote
Has scoot overheated in the past and maybe nipped up (siezed) the piston? (as I've said before, I hate working on 2-strokes).
evoboy
PostPosted: 13:59 - 09 Jun 2014    Post subject: Reply with quote
Sounds like the carb is blocked.
Put a drop of fuel in the plug hole then try to start it.
If it starts, you need to strip the carb down for a clean.
APT Motorcycles
MudSweatnGear...
PostPosted: 14:01 - 09 Jun 2014    Post subject: Reply with quote
Could be a real possibility, I have no idea about the history of the scoot, but the poor thing has been tucked up in a farm barn with cows to keep it company...
MudSweatnGear...
PostPosted: 14:08 - 09 Jun 2014    Post subject: Reply with quote
Evoboy:
I forgot to mention that I tried that earlier today. Again when i squirt a little fuel in it almost seems like the plug is dry after cranking. Not even getting a hint of it starting.
evoboy
PostPosted: 15:58 - 09 Jun 2014    Post subject: Reply with quote
Pull the head and barrel off.
Itll probably be ruined inside.
APT Motorcycles
jjdugen
PostPosted: 16:14 - 09 Jun 2014    Post subject: Reply with quote
Crankshaft seals?
MudSweatnGear...
PostPosted: 20:39 - 09 Jun 2014    Post subject: Reply with quote
Evoboy: Im getting the same feeling, will inspect the barrel/head tomorrow sometime, will try and post up some pics.
jjdugen: could well be adding to the problem; it does certainly seem that the poor thing has had a hard up-bringing.
Thanks for the help everyone! Smile
craisin
PostPosted: 01:47 - 10 Jun 2014    Post subject: Reply with quote
i am agreeing with the Crankshaft Seals post
MudSweatnGear...
PostPosted: 12:22 - 11 Jun 2014    Post subject: Reply with quote
So heres the Sit-Rep so far:
Dug out my compression tester, fitted and turned over the engine, At first I though I had not fitted the tester properly because it just lifted the needle off its rest. Checked and tightened and same again... not even registering a number Shocked Whilst I had the tester in a sprayed the crankcase with soapy water, turned the engine over and its blowing all over the shop.
RUST IN PEACE Scooter. I think you deaad.
The last post was made 11 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 66.45 Kb
