| Rick_C |
 Rick_C L Plate Warrior
 Posted: 19:03 - 10 Jun 2014 Post subject: 2009 Kaiser (Lexmoto) XTR 125 turns but won't start |
Hello All,
I have been looking at past posts on this forum about none starting bikes and this post in particular https://www.bikechatforums.com/viewtopic.php?p=3865459
I bought the bike June 2012 and used it over the summer, tightening nuts and bolts as I went, then remembered lock nut! ha
I parked the bike up and it was in full running order and it sat outside during the winter covered up and not touched till the summer. It started 1st time and did a service on it.
Winter came and same again parked up in full running order then
I come to move house it would just not start and I have just left it till now.
Just did a service on it.
It turns over on the starter.
There is a spark.
There is compression.
Checked all the electric connections
Also after reading other posts read about the fuel. I took the fuel tank off and it was full of crap. Drained and flushed out with new fuel and thought.... right here we go it's going to start..... Still no start.
If anyone can advise it would be much appreciated.
I am thinking maybe the fuel is not getting to the engine?
Maybe the carb is full of crap based on what was in the fuel tank?
How is the fuel pumped on these engines? How can I that fuel is being pumped?
Or should I be looking elsewhere?
Thanks,
Rick |
| gavcarter |
 gavcarter Could Be A Chat Bot
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:11 - 10 Jun 2014 Post subject: |
Yup, get the carb off and clean it out thoroughly. Idle jets are particularly clone to clogging up. Also, I'd stick an inline filter in the fuel line to help prevent future issues. ____________________ Biking is 1/20th as dangerous as horse riding.
| Rick_C |
 Posted: 20:49 - 10 Jun 2014 Post subject: |
Thanks for the replies!
Will give that a go, looked in the manual section but the links for Chinese engine of this type don't work.
Anyone know where I can find one for this carb/engine? Or are they easy enough? Think the engine is a 156FMI Balanced Shaft Engine ?
Thanks, |
| Rick_C |
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:18 - 11 Jun 2014 Post subject: |
How did you clean out the idle jet? They're tiny, any blockage is going to cause trouble. ____________________ Biking is 1/20th as dangerous as horse riding.
| Rick_C |
 Posted: 20:28 - 11 Jun 2014 Post subject: |
What one is that on this diagram I found on page 2?
https://bit.ly/SO2rpG
Thanks,
Rick |
The last post was made 11 years, 229 days ago. Instead of replying here, would creating a new thread be more useful? |
